Sponsored by: Real Truck
Gas vs PSD
Old Sep 3, 2010 | 08:26 PM
  #7951
Johnny Langton's Avatar
Johnny Langton
Originally Posted by FORDTUF1
What? I should drive to 50 states and have it inspected because my state isn't good enough? Duh???
Besides, how many times do you see regular DD's have cat failures and they never did a thing?
Ford has to meet 50 state requirements for their vehicles. Aftermarket tuners do not.
I've seen many failed OE cats with not a single modification to the vehicle. Failed cats is not the concern with EPA emissions certification. Catalysts have precious metals in them that over time with use deteriorate which makes the cats less effective. The EPA makes manufacturers use a set of 120K mile catalysts for full certification (along with a load of other little tests). These are tests that aftermarket tuners do not have to comply with.
JL
Old Sep 3, 2010 | 09:36 PM
  #7952
Jrfish007's Avatar
Jrfish007
Originally Posted by Kajtek1
Got me thinking. While in Europe I drove, or seen lot of cheap cars like Fiat, not mentioning about Communism era Pobjedas, Trabants, Wartburgs, Syrenkas and so on.
None of them ever had common problem of plugs shooting out.
How Ford having 100 years of experience did allow it to happen on their prime gasoline engine?
Uhmmm.... Are you actually comparing a Ford to a Fiat? I mean Alfa's don't spit plugs either, but what the point in comparing an Alfa to a Ford, one of those will actually drive off the dealer lot when bought.
Old Sep 3, 2010 | 09:39 PM
  #7953
Jrfish007's Avatar
Jrfish007
JL
the metals don't detoriate, they conglomerate and sinter together, which causes all kinds of problems. But that is just details...
  #7954
Kajtek1's Avatar
Kajtek1
Originally Posted by Jrfish007
Uhmmm.... Are you actually comparing a Ford to a Fiat? I'm pretty sure I would take any of the Ford gas engine trucks in a reilabilty test versus any of the Fiat gas engines.
That's exactly my point. The Fiat engines 25 years ago had 150k km life expectancy, yet never spit the plug. Trabant 2-cycle engine required overhaul abut every 50k km, or 30k miles. No problems with plugs spitting neither.
Old Sep 3, 2010 | 09:55 PM
  #7955
Cory281's Avatar
Cory281
I've known a lot more people have problems with their 6.0 PSDs' over any Ford gas motor by far.
I hope 6.0 owners don't take that personal, if yours has been a good truck, then that's great. I don't like hearing about broken down Fords.
Old Sep 3, 2010 | 10:29 PM
  #7956
2001400ex's Avatar
2001400ex
Yup and no one argues that. But a v10 is not going to outpull a 6.0.
Old Sep 3, 2010 | 11:39 PM
  #7957
Sand_Man's Avatar
Sand_Man
It will while the 6.0 is back in the shop (again).
Old Sep 3, 2010 | 11:40 PM
  #7958
Sand_Man's Avatar
Sand_Man
Sell your Ford, buy a plane ticket, go away...
Old Sep 4, 2010 | 12:08 AM
  #7959
Kajtek1's Avatar
Kajtek1
Leaving underdeveloped, uneducated people behind is not my way.
Old Sep 4, 2010 | 09:11 AM
  #7960
Fishin76's Avatar
Fishin76
Originally Posted by phillips91
People from the factory make mistakes too. If a guy has been installing plugs for 20 years on cast iron heads and then you roll out an aluminum head with half as many threads, there is a good chance he is going to continue putting in plugs the same way he has for the last 20 years. I have a lot of relatives that work for two GM plants, and trust me, the people they have assembling these things are far from being certified mechanics of any kind. One of my cousins can't change her own oil or tire, but she works for GM assembling cars......
Good point, Assemblers don't make good mechanics......
Old Sep 4, 2010 | 09:38 AM
  #7961
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by 1975StroppeBaja
Maybe you should make the drive from there to TX to put him in his place. Why does the pull off have to happen where you're at?
Or maybe you could meet halfway somewhere.
Because HIS signature makes the claim that he can outpull blah blah blah, but in his posts he still claims he makes more power and more torque. I never realized his 2V made more than my 350/650...So I'm intrigued...
Old Sep 4, 2010 | 09:39 AM
  #7962
ChargersFanInCO
Originally Posted by Fishin76
You'll lose if he has shorter gears than you.........no comparison. 3.73 in PSD, 4:30's in V10. He'll win, by gearing alone.....
Speaking of gearing, I was looking at 2010 6.4L with the snow prep pack, It had 3.55 gears! and a torqshift. ......
I have an 09, with 350hp/650lb/ft of torque.
Old Sep 4, 2010 | 09:47 AM
  #7963
ChargersFanInCO
Originally Posted by bill11012
When you add in the cost to buy the PSD, the V10 can make much more power for the money. Its only a matter of time until DPF deletes will fail inspection too.
I wonder if the same can be said for the 5.4 vs V10 since the V10 is nothing more than 2 cylinders added to a 5.4...
Old Sep 4, 2010 | 10:05 AM
  #7964
bill11012's Avatar
bill11012
Modular motor junkie
I say I can outpull the same age truck.
A 3V will out pull you, not my 2v.
Old Sep 4, 2010 | 10:47 AM
  #7965
2001400ex's Avatar
2001400ex
Bill, a 3v v10 will NOT outpull a 6.4. I am just staying in this thread to repeat that every time you say it. Then other dude will say his 2v v10 will outpull anything at a sled pull but a dmax wit 100 hp tune.
