The spitting spark plugs was due to not enough threads cut into the head. Not putting them in wrong.
The heads didn't have as many threads as before (or after), but if installed properly they will not shoot out. The problem was people changing plugs, or installing them at the factory, in aluminum heads when they have never put them in anything but cast iron heads. You can't put plugs in an aluminum head the same way you put them in a cast iron head and expect them to stay in the head. It is very easy to cross thread or over torque them if you don't know what you are doing.
That just made it easy to mess up. If you use the right plugs, with anti seize and torque them right they will not blow out.
Wrong plug, too much or too little torque or cross threading and they will come out. They should have more theads so its more of an idiot proof design IMO, but its not the ticking time bomb PSD owners make it out to be.
Very true!
Rep sent.
Dude these are factory installed plugs. Not reinstalled plugs. I never said or have a seen any other PSD in this thread say the v10 was a time bomb. I commented when someone said there was no known issues w/ the v10s. I've said a few times that I think the v10 was a great engine. What I'm saying Bill is you will not out pull me. Now argue that I'm done w/ it.
Just to add me and my best friend each purchased brand new Ford 350 SD his a v10 mine 7.3 the price was only 7800 difference and I'm still on my original drive train and have hardly touched it except for basic maintenance he has rebuil his tranny twice and the front end twice I have 170,000 miles he has 145,000 miles I have replaced most of my front end and my shocks he has also had to replace his computer due to error codes that the stealer couldn't fix. I tow a 10,000lb trailer every day for work he drives on the highway and we both pull campers for the family out of state where he gets around 7 miles a gallon I get 14 with a bigger heavier camper. The only draw back is I have to plug mine in when its cold.
V10 or 7.3 PS?
Why did they ever eliminate the 7.3 just imagine where it would be now.....It would be grate smoking a duramax!
At least we have the 6.7 now, I never had the 6.0 or 6.4, but this will smoke any truck out of the gate/off the lot. Okay no smoke stock, no matter how much I load it and run it.
What? I should drive to 50 states and have it inspected because my state isn't good enough? Duh???
What he is saying is that there is a big difference in you passing an emissions test with a USED truck with over 130k miles and Ford having to pass 50 state emissions tests for NEW vehicles. As your truck ages, the standards it has to meet go down.
People from the factory make mistakes too. If a guy has been installing plugs for 20 years on cast iron heads and then you roll out an aluminum head with half as many threads, there is a good chance he is going to continue putting in plugs the same way he has for the last 20 years. I have a lot of relatives that work for two GM plants, and trust me, the people they have assembling these things are far from being certified mechanics of any kind. One of my cousins can't change her own oil or tire, but she works for GM assembling cars......
Until you introduce the supercharger to equalize the turbocharger. My cousin did that very thing, and pulled in the same truck pulls as I do in Illinois. I'm not going to brag or give details that nobody will believe, but he whipped everybody, and there were more than 10 trucks.
They new he wasn't stock enough, so he didn't enter to win the money or trophy. But he outpulled them by a lot.
His son was banned from driving his truck because he was seen burning out all four tires, and there was black rubber in all the wheel wells when he got home. I'm just saying adding the supercharger, changing intake, injectors, exhaust, program, etc it is wicked strong and fast! Not saying it will beat yours but I wouldn't bet against him.
I agree with you 100% that a v10 with those mods is a mean ****, but thats not really what i would consider a basic mod. Those mods on a v10 would probably make more power then where im at now, but i could toss in somethin like 190mm sticks and run the stock turbo, it would be smoky and hot, but it could be done. Now put an A/M turbo, hell even a cam and vavle train upgrade to bring the hp peak up to 5000rpm. Im gettin a chubby just thinkin about it. lol
I understand that. I didn't get the feeling Bill was talking about workers making the mistakes. Just like he's denied that there was a problem. Now he says there was a torque issue. Bill just wants the v10 to be Tebow,untouchable, and clear as crystal. He'll say anything to convince hisself it so. I just remember reading when the problem happened that ford said it was the threads in the head.
Either one will just keep making more power as long as you have money to throw at it.
Originally Posted by exiled
I understand that. I didn't get the feeling Bill was talking about workers making the mistakes..
I was talking about that and owners/shops changing them.
Untill I blow a plug I will keep thinking its not a problem.
At last count I have owned 10 4.6s and 2 V10s. Non of them ever had a problem. Do the job right and they will not come out.
I would rather my V10 did not start crying.
I've had 3 5.4s, in trucks 2 where 3v heads. 4.4.6 in mustangs. 2 where 3v heads. On had sparkplug issues out of the 04 and 05 F150s. Since then then I change them out before 20k miles.
I asked where did I EVER CALL you an idiot? Still ain't getting it are you. I don't have the questions, I have the answers and you have you're momma's advise, right, I think it was you. Yep I told you go to webshots.com and you'll see the PROOF, but you can't handle the truth!
Now, I say "Good Day"
I said good day!
When you offered the website it was your 6.7 coming in thir, which is believable. But post a link to your v10 results.
Got me thinking. While in Europe I drove, or seen lot of cheap cars like Fiat, not mentioning about Communism era Pobjedas, Trabants, Wartburgs, Syrenkas and so on.
None of them ever had common problem of plugs shooting out.
How Ford having 100 years of experience did allow it to happen on their prime gasoline engine?
