Sponsored by: Real Truck
Gas vs PSD
Old Sep 4, 2010 | 11:43 PM
  #8011
FORDTUF1's Avatar
FORDTUF1
Originally Posted by tgreening
Actually most diesels are at a disadvantage in sled pulls. Since traction is not all that great performance in those events rely HEAVILY on wheel speed, something diesels are not incredibly good at. Gas engines on the other hand can be made to crank out some rpm relatively easy. Again, lots of variables. Diesels can be made to perform but gassers are easier and cheaper.
It is I who is "him". The 400EX guy just can't get this through his head, even though you are now the 2nd or 3rd person who understands what it is about.
He figures if he can't see it it won't/can't happen.
Old Sep 5, 2010 | 12:01 AM
  #8012
FORDTUF1's Avatar
FORDTUF1
Okay can we get back on topic? The GA Bulldogs are the best football team in the world!!!!
Old Sep 5, 2010 | 12:04 AM
  #8013
bill11012's Avatar
bill11012
Modular motor junkie
My V10 can pull more.
Old Sep 5, 2010 | 12:25 AM
  #8014
2001400ex's Avatar
2001400ex
Nice Vid!!!! (though where is the 2002 v10???)
And if you read my original post about the topic, I agree that due to EGTs and airflow, yes that is not where the diesel shines. However, I still don't think it is possible a 2002 V10 is going to outpull a 6.4 in any scenario. (okay, if the V10 was built, with better suspension, and other things maybe). Even Bill says that.
Old Sep 5, 2010 | 02:26 AM
  #8015
exiled's Avatar
exiled
Originally Posted by Jrfish007
That's either a very low quality plug or you live by the sea. But rust has nothing to do with spiting a plug. I've pulled rusted plugs out of all kinds of things from Honda's to Buick's, the actualy retainingpart of the plug is around an 1/8" or more thick and won't give out that easily.
It would be nice if you would do some research before you open your mouth. The plugs in my trucks that had started to rust where factory plugs. I've nevr had any more problems. Though I do change them out around 20k miles. There's no ocean in North Al. Don't you know moister is in the air when it enters the combustion chamber? But that's not what started the rusting. It was the contact of unlike metals. Nickel anti sieze helps to stop this from happening. Then I still have the carbon building up around the groundsheild to. Sieze" the plugs. My cure? Change the damn things. $8 a piece is cheap for peace of mind.
Old Sep 5, 2010 | 02:34 AM
  #8016
exiled's Avatar
exiled
Not what I call work but aight. Was that a good pull? I'd like to see how it handles 20k lbs of hay thru the field and down the road.
Old Sep 5, 2010 | 02:43 AM
  #8017
mountaineer27's Avatar
mountaineer27
galvanic corrosion if i remember correctly. could be wrong. maybe its intergranular corrosion? theres to many different types of rust lol.
Old Sep 5, 2010 | 07:12 AM
  #8018
superglide04's Avatar
superglide04
Originally Posted by Cory281
I'll say it right now, a PSD will pull more then a V10, but a V10 still will comfortably pull most loads anyone will every have. But when PSD's owners start talking about V10's blowing plugs, making them sound out to be nothing but POS's, that's just dumb. I know a couple of former 6.0 owners that won't buy Fords again because of those motors.
I agree I would have never got my Ford if I wasnt able to find a left over 7.3 I would have paid the extra for a Duramax. I guess im not a ford Enthusiast I am a common sense type I race a Chevy because they are much easier cheaper to make fast and also much more simple.
Old Sep 5, 2010 | 07:57 AM
  #8019
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by Kajtek1
Leaving underdeveloped, uneducated people behind is not my way.
LOL!!!....
Old Sep 5, 2010 | 07:58 AM
  #8020
ChargersFanInCO
Originally Posted by bill11012
Name one thing that a PSD can pull that a V10 can't.
Vail Pass with a load...lol
Old Sep 5, 2010 | 08:12 AM
  #8021
ChargersFanInCO
Don't forget my fuel is cheaper too.
Why do you bring up a point that's been proven time and again as MOOT? The diesels get better mileage, and it more than offsets the price difference between gasoline and diesel fuels.
Old Sep 5, 2010 | 09:18 AM
  #8022
FORDTUF1's Avatar
FORDTUF1
It's fun and competition.
It was a near perfect pull, great speed in the first 50 feet and continued down the track (notice flag on sled sticking straight out). I know the tranny was in at least 3rd maybe 4th during mid track lost count, focused more on listening to the engine.
No hop or drifting down the track, only problem was tires spinning out at the very end, hard to see on video. You can see a steel pole stuck in the ground near the end of my truck, it sorta looks white but it's because of the video and distance away from camera. Anyway that marks the farthest pull and I was real close.
It handles 10,500 down the road better than my V10 pulled my 3000 pound boat. I'm sure 20,000 would not challenge the engine much at all, although technically it would be overloaded. I think my truck is rated for 16,500.
Old Sep 5, 2010 | 09:44 AM
  #8023
PorchFarms's Avatar
PorchFarms
I was reading through some of the back pages and talking about grasping at straws. The gassers are trying to use paper to beat us oil burners. Saying a 5.4 will start moving a load faster than a diesel is crazy. Ford needs to issue a recall on gas engines because the fumes must be affecting brain cells!
Old Sep 5, 2010 | 10:10 AM
  #8024
bill11012's Avatar
bill11012
Originally Posted by PorchFarms
i am down in south texas right now so if bill wants to put his v 10 up against my 6.0 then come on down. Mine even has a stuck turbo right now but i still will beat him pulling my trailer. Fully loaded it alone weighs 36000 pounds. I will be nice and even tow him back when we get done.
Where are you?
Whats the pin weight on that trailer?
Old Sep 5, 2010 | 10:12 AM
  #8025
bill11012's Avatar
bill11012
I still think that under my use the mileage would be close enough for it to matter.
