Sponsored by: Real Truck
Gas vs PSD
Old Sep 2, 2010 | 10:37 AM
  #7831
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by exiled
Why wouldn( the 6.0 be able to use the torque multiplier? I don't know that it does or don't. My goodness. A torque multiplier takes torque on one side multiplies and outputs it on the other. Nothing special there. Can't be something in the TC locking up cause in tow/haul. The TC lockes in every gear soooo. I don't understand where your going with this question.
You can put much more torque to the ground in a lower gear.
The V10 can run a lower gear than a PSD and will pull hills better.
Its not about whats at the flywheel, its about what it can put to the ground.
Old Sep 2, 2010 | 11:00 AM
  #7832
bucci's Avatar
bucci
Originally Posted by Krewat
He can have better tires, a better balanced truck, not over-apply the go-pedal, or a host of other things that allow him to tractor-pull better on dirt than the rest.
Or, it is simply the fact that he can stay in a lower gear and/or get higher speed because of his higher RPM range.
Thanks for the explanation, but I wasn't looking for an explanation on how he could have beaten everyone. I was wondering why he referred to a person (2001400ex) asking for proof as an idiot.
Old Sep 2, 2010 | 11:06 AM
  #7833
krewat's Avatar
krewat
FTE Leadership Emeritus
Because it's either the same person, or one in agreement with another, who will not take videod proof of a V10 doing the same job as a PSD.
Denial and rationalizations are amazing things.
Old Sep 2, 2010 | 11:34 AM
  #7834
Jrfish007's Avatar
Jrfish007
Your above post basically says your 2002 V10 with no tuner outpulled a stock 6.4l PSD and beat everything else except a duramax with a 100 hp tune.
Tuners do almost nothing for non-turbo engines. The only way a tuner will do anything substantial for a V10 is if you have a ton of other mods done to the engine.
The only way I've seen to make any substantial gains from the V10 is to put a turbo or supercharger on it, and then only a few people have done that.
As far as mods go, the PSD has the V10 beat in every way. You can make far more power by modding your PSD than modding your V10, unless you want to tear into the internal re build the entire engine with exotic materials.
Old Sep 2, 2010 | 11:48 AM
  #7835
krewat's Avatar
krewat
Depends on your definition of "substantial" - I went from 10 second 0-60 down to a 9 second 0-60 with 5-star Mike's 87 octane performance tune. A bit more power, and different shift patterns made all the difference. That's a 10% reduction in 0-60. Not bad. A gear change from 3.73's to 4.30's is about 15% although that doesn't correlate to a direct acceleration improvement.
Of course, it doesn't hold a candle to what you can do by forcing more fuel/air into a diesel.
Old Sep 2, 2010 | 11:58 AM
  #7836
Jrfish007's Avatar
Jrfish007
That is more or less what I was comparing. Any turbo engine is far easier to get more power because you can just turn up the boost until the the turbo won't go any more or the fuel system can't take any more.
I've seen plenty of Saab's that toss a chip in their car (the turbo V6 ones) and go from 250 (or 280 depending on the year) to 400 hp and 500 ftlb torque.
But yes, you can adjust shift points and such. But actually producing say 25% more power from the engine from a tuner alone, not going to happen on a V10.
  #7837
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
A modded PSD is considered taboo in this thread.
Old Sep 2, 2010 | 12:02 PM
  #7838
Jrfish007's Avatar
Jrfish007
Yeah I know...
The original point I was making was that a tuner on a V10 just isn't going to help on a tractor pull that much.
Old Sep 2, 2010 | 12:07 PM
  #7839
dkf's Avatar
dkf
Yeah I know...
I take it you've never driven any gas vehicle with a good tune in it? I'm not talking about the craptastic off the shelf tuners with canned tunes either. When tugging on something real heavy the 1-2 shift and converter lockup can make a big difference and a safer A/F ratio is nice at such high loads.
Old Sep 2, 2010 | 01:00 PM
  #7840
Jrfish007's Avatar
Jrfish007
Nope, but I don't do tractor pulls with my trucks either.
Wouldn't the the tow/haul mode help out with that though, it seems to help keep the torque converter locked when I was towing my trailers. I would admit Ford's shifting pattern is not optimal. As I've said before, I'm not a fan of Ford auto tranny, specially in stock form. There probably is improvement to be made there, but I don't think your going add THAT much more wither way.
I would think the stock A/F in a V10 would be pretty safe as I haven't heard of many blowing up from being to lean... could be wrong though.
Another thing is that he has yet to mention if his V10 was an auto or a manual. If it was a manual, then all of this tranny argument isn't really going to matter.
Old Sep 2, 2010 | 01:07 PM
  #7841
Johnny Langton's Avatar
Johnny Langton
The V10 is tuned from the factory to get the absolute best economy possible, while also satisfying the emissions requirements. There are very few specific strategies that allow open loop fuel enrichment at WOT. 14.64:1 air fuel at WOT is bad in the overall big picture of longevity and power production.
JL
Old Sep 2, 2010 | 01:31 PM
  #7842
dkf's Avatar
dkf
I don't do any tractor/sled pulls with my my truck either. Beating the **** out of a DD truck I depend on for personal and business use is idiotic IMO. I do enjoy watching actual tractors pull though, as I do the highly modified purpose built rigs. This whole light truck tractor pull thing is more of pecker measuring session IMO.
Under extreme loads if the engine temps get out of hand the truck will lose power. The extra fuel at WOT under those loads JL stated is a good. The T/H is great and works well however it is designed to work within certain parameters.
Old Sep 2, 2010 | 01:36 PM
  #7843
bill11012's Avatar
bill11012
How much money do you have in you truck, as far as mods go?
Old Sep 2, 2010 | 01:40 PM
  #7844
bill11012's Avatar
bill11012
I don't really feel like its any worse than things I already do to my truck.
Old Sep 2, 2010 | 01:55 PM
  #7845
Jrfish007's Avatar
Jrfish007
JL
Yes, but in a tractor pull as I was referencing, would you really make that much more power? Sure if was running WOP everyday, that might be a good idea, but I'm doubtful you'll see any major gain. And from the sounds of it FORDTUF1 only does these pulls once in awhile.
