Sponsored by: Real Truck
Gas vs PSD
Old Sep 4, 2010 | 08:25 PM
  #7996
tgreening's Avatar
tgreening
Originally Posted by phillips91
If you are going by Ford's recommended max gcwr or tow rating then that isn't a legal number(and a lot of the time will put you OVER the legal limit if you drive a psd). Legally, my 5.4 can tow more than a psd and v10 of the same year with the trucks being the same except for the engine. For example, my 250 has a gvwr of 8800 lbs and weighs 5600 lbs. A 7.3 from the same year has the same 8800 lb gvwr but weighs 6100 lbs in the same set up as mine. I have a payload of 3200 lbs and the 7.3 only has 2700 lbs. Using a 25% pin weight my 5.4 can legally tow a 12,800 lb 5th wheel and the 7.3 can only tow a 10,800 lb 5th wheel. Ford rates mine to tow 9,200 and the 7.3 to tow 15,000 though. Ford can rate them for whatever they want to, but the only thing that matters legally is what is stamped on the door(rawr and gvwr).
I mentioned this in one of my earlier posts. In the "lighter duty" truck packages the weight of the diesels can become a disadvantage in carrying capacity, not due to the limitations of the motor itself but due to the limitations of the platform it's installed in. A combination of any or all of lighter springs, less capable tires, the height of the lift block UNDER the springs, etc. Those are all factors used in the consideration of the trucks load capacity ratings. Obviously those all change between 250, 350, 450, etc and not all configurations are available in every platform.
My contention is that since the claim is "my V10 will out pull your 6.0" any day of the week, and not my total truck package will out pull yours any day of the week, that we should move up into a package that ceases to be the limiting factor and places more of the burden on engine limitations. Bill decided to jump up into the 550s. Perfect.
Why do you all think the v10 has to run at 4,500 rpm all the time when it is pulling a load? I have pulled 10k with my 5.4 many times (for 500-600 miles one way for my longer trips) and on the highway it cruises at 2,000 rpm just as easily as my 7.3 does. When I hit a hill I have to downshift, but I have never HAD to hit 4,500 rpm with it to maintain speed(I have done it a few times just playing around with it). Out of a 600 mile trip, there may be 5-10 miles of it that are spent above 3,500 rpm's. And that is with a 2v 5.4. There is a big difference in being able to and having to.
I don't. It is just a performance comparison. Bill is the one that says "Let her rev out and it will out pull the diesel". The diesel makes it's power at or near normal highway speeds at "normal" rpms for those given speeds. Somewhere in the vicinity of 2500 rpm. The V10 on the other hand makes it's max power right about 4500 rpm which is not normal highway rpm.
Mine will pull just fine on flatland too, at least in the 8-9K trailer weight range, but I don't know kind of hills you're talking about because when I hit them suckers in WV 4500rpm is almost a given, just to sort of maintain speed.
Old Sep 4, 2010 | 08:26 PM
  #7997
Jrfish007's Avatar
Jrfish007
Originally Posted by exiled
No the wouldn't. I don't know where Ford is w/ this issue. Somewhere in mid 2005 there was rumors spread over the internet and here that spark plugs where breaking off in the head. We're talking as little as 4?,000 miles. We discussed it in depth and got know. So around 18k miles at the time I pulled my spark plugs and checked them. My plugs had started rusting where the groundsheild and thread body meet. This is where the spark plug breaks. I pulled my wifes spark plugs in her 04 f150 and there was a lot of rust on her groundshield. We took both truck to dealership and they changed plugs under warranty. At this time Ford was putting out the bullentine. Before this it was just a rumore. We had the new plugs put in. I ended up trading my 05 f150 for my 04 SD. Not because of the spark plugs but cause I was bit by the superduty bug. At the time a solution that seemed to work was pulling the plugs and cleaning them. I just change them. I would stupid to put a plug back in and it fail and have to redo the job.
That's either a very low quality plug or you live by the sea. But rust has nothing to do with spiting a plug. I've pulled rusted plugs out of all kinds of things from Honda's to Buick's, the actualy retainingpart of the plug is around an 1/8" or more thick and won't give out that easily.
Old Sep 4, 2010 | 08:28 PM
  #7998
tgreening's Avatar
tgreening
Originally Posted by driximus
Does it have a calculation for the duration of time between a post that says "my X will out pull your X" and a post that says "no it won't"?
Old Sep 4, 2010 | 08:32 PM
  #7999
Kajtek1's Avatar
Kajtek1
I have to see if I can beat Bill to 8000 post in this thread
Old Sep 4, 2010 | 08:33 PM
  #8000
Kajtek1's Avatar
Kajtek1
How about now?
  #8001
Jrfish007's Avatar
Jrfish007
Towing 12k, my V10 kept jumping between 3rd and 4th. 3rd being around 4500rpms, but I could gain speed going up the mountain. I would get to 75 then let the truck kick back to forth for a mile or so untill it got to 65 and kick it back down to 3rd. It would have maintained 60-65 in 4th going up the mountains, but I was in a hurry so tried to keep it in the 70's.
But the truck pulling 12k certainly did 70, it may not have been as easily done as a PSD, but it did it.
On the flat ground, I didn't even break 3000 RPM's except maybe when I was getting on the highway. But it maintained 5th gear without a problem in Ohio.
Old Sep 4, 2010 | 08:54 PM
  #8002
phillips91's Avatar
phillips91
My point is that when two trucks have the same gvwr, the one that weighs less is going to be able to tow more legally. I haven't looked at the numbers, but Bill said both 550's (v10 and 6.0) came with the same gvwr. Assuming he is correct(not saying he is, since I haven't looked up the numbers), the v10 would be able to tow more legally since it has the same gvwr and weighs less.
Yes, both Bill and myself are saying let the v10 rev and it will pull better than the psd side wants to give it credit for. But we are also saying that you don't HAVE to run it that hard to maintain speed, because some people think it can't pull itself up a hill unless it is WOT and 5,000 rpm.
I have pulled trailers all over WV(been to every county but 3) with my 5.4 and the only time I hit 4,500 was when I chose to just for the fun of it. I was pulling ~9k up I-77 going past Bluefield and Princeton. That is a 6-8% grade for about 10 miles. I held it at 4,500 the entire climb, but it normally makes the climb at about 3,500. Some other hills I have pulled(and know the names and know other people on here have pulled them too) that were at least 55 mph are Fancy Gap, Buckner Gap, Sams Gap(all ~8% and a couple of miles long) and Dante mountain (10% for 3 miles). None of them required me to run WOT at 4,500 rpm to maintain speed. There are several local hills around here in the 15-23% range, but they are fairly short and the speed limits are below 45.
Old Sep 4, 2010 | 09:10 PM
  #8003
goattoford's Avatar
goattoford
Originally Posted by mongo75
UH OH- lemme get the pop corn and a chair LOL...
Actually, there are several points that account for the extra cost on the sticker- more power (tq), better fuel economy, longevity (some over 1 million miles), higher resale value, sound cooler LOL, a lot easier and way cheaper to get more hp/tq out of a diesel than gas, you can roll coal into the yuppies car next to you at the light. I'm sure there's more others will add...
I think the best point is you CAN ROLL COAL AT THE YUPPIES CAR NEXT TO YOU!!!!!!!!!!! LOL !!!!!!!!!LOLOLOL!!!!!!!!!!!!!!!!!!!!!
Old Sep 4, 2010 | 09:27 PM
  #8004
Kajtek1's Avatar
Kajtek1
Nah. My PS never release single puff of smoke when warm. Even on cold start I seldom see any smoke.
Than I remember my motorhome with 300 HP CAT. CATs are famous for smoking and my model was a good one. While towing 5000 lb boat at Lake Tahoe (over 5000' elevation) nobody could make the green light behind me. They just couldn't see it.
Old Sep 4, 2010 | 09:43 PM
  #8005
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Kajtek1
I guess Bill it comes (again) to the definition what we call real hauling.
You already admitted that you are no competition on uship to guys driving diesels. You burn too much fuel to make the competition.
Than how would you manage hauling 20,000 lb load via the deserts? You might not find enough gas stations, so you would have to haul small tanker as well.
I could make it with 20,000 just fine. Worst MPGs I could get would be 7 and it could go as high as 10.
Don't forget my fuel is cheaper too.
Bill never said the guys that outbid him drive diesels. What he said was every time he bids on something someone comes along and bids a price that is lower than what it would cost him in fuel to make the trip. Bill has only been looking to tow one thing one way. It is very simple for someone else who is towing something one way and then towing something else on the way back to bid much lower than Bill. Or someone towing more than one item on the same trip.
Exactly. Its that I can't compeat with guys with 3 car haulers when I can only take one car at a time. My engine has nothing to do with it.
In the 550 package the V10 maxes out at 26K GCWR and a maximum loaded fifth wheel trailer weight of 17,800 #and that is with 5.38 gears in a 4x2 config.. I don't know where you got your numbers, mine come from Ford Fleet towing guides.
The 6.0 OTOH maxes out at 33K GCWR with a maximum loaded fifth wheel trailer weight of 24,000#, with 4.88 gears in either a 4x2 or 4x4 config.
Ok, I did the "build your own" on there web site last year and they let me build a 33K cap. V10 F550. Same gross capacity as the 6.4 F550.
Originally Posted by 2001400ex
You make it sound like you actually believe a 3V V10 will outpull a 6.4...
I know it can and will.
Thats were 90% of its torque at 1500 RPMs comes in.
You will not pull it as fast as at 4750, but you will still do ok.
I would rather let it sing then lug though.
Hahaha
Old Sep 4, 2010 | 10:02 PM
  #8006
driximus's Avatar
driximus
Originally Posted by bill11012
Hahaha
I have been offline for a bit so when I got back on I came in and I knew with a Doubt this Thread was still going when I looked there was still up top LOL
Old Sep 4, 2010 | 10:12 PM
  #8007
Kajtek1's Avatar
Kajtek1
Yup... I am already sharping my keyboard to make 10,000 th reply
Old Sep 4, 2010 | 10:22 PM
  #8008
PorchFarms's Avatar
PorchFarms
The funniest part of this thread is the gas drivers dont realize that the diesel owners have or have had gas trucks before! I personally have had any make of ford gas engine made. So i know what they can and cant do.
Old Sep 4, 2010 | 10:25 PM
  #8009
Kajtek1's Avatar
Kajtek1
Well...can't expect too much from gasoline sniffers.
Did you drive Ford wagon with 1.9cdi engine? I clocked one at 224 kph in Alps -courtesy of French car rental. That is about 140 mph. Didn't care if it made only 30 mpg at this speed. That was 10 years ago. Takes long time for Ford engines to cross the Pond.
Old Sep 4, 2010 | 11:26 PM
  #8010
FORDTUF1's Avatar
FORDTUF1
Okay here it is if it works.
YouTube - FORDTUF1 TRUCK PULL 2011 6.7L
