Beating the **** out of a DD truck I depend on for personal and business use is idiotic IMO.
You wouldn't believe what I've put the F150 I drive everyday through. It's been through hell,but it gets proper maintenance, and has 245K trouble-free miles on it. It wears a 400 lb galvanized steel ladder rack with 3-5 ladders everyday, 2 saddle type toolboxes in the bed, a single custom plywood tool cabinet that takes up the entire supercab portion,and usually has the passenger seat full of stuff, and assorted materials in the bed. It's a little 4.6L 2V with a 4R70W, and a 3.55 locker in the back. It's never had a wrench on it for a single mechanical repair-nothing, nadda, zip.I go out every morning and it starts and takes me to work, then back home at the end of the day. I've spent as long as 4 hours towing a trailer loaded down with around 6500lbs or wire at 65 mph on the interstate with OD locked out going to a jobsite, and many,many more trips withing an hour's drive doing the same thing or similar.
JL
Yes, but in a tractor pull as I was referencing, would you really make that much more power? Sure if was running WOP everyday, that might be a good idea, but I'm doubtful you'll see any major gain. And from the sounds of it FORDTUF1 only does these pulls once in awhile.
There is a power gain and a torque gain by going to open loop fuel enrichment as soon as your foot goes WOT. How much depends on many things, but you can usually see 15-25 rwhp peak, but you'll see much more over the entire RPM range vs stock.
JL
My buds truck that runs neck and neck with me puts out 450 RWHP and I think around 1,000 #torque. But my truck is heavier then his. Last year I ran a 9.4 @ 75.87 mph, in the 1/8th mile. I think I'm in the high 8's now with the BTS and live tuning from Jody at DP-TUNER.
You climb and you have it floored to keep speed and maybe accelarate . I put my truck on cruise and barley the tac moves if at all. I know the truck will move the laod w/ out a doubt. I wish everybody would understand this as well.
Let's say you are in 5th gear cruising at about 2,000 rpms. At that speed and rpm a stock 6.0 is making a MAX of 217 hp and has a tractive force of 1,534 in 5th gear, assuming a 3.73 gear(and assuming you are full boost without downshifting). To go that same speed in 4th gear a v10 with a 4.10 would have to turn 3,084 rpm. At that rpm the v10 is making 260 hp and has a tractive force of 1,837. That is a far cry from having to be floored to maintain speed.
Originally Posted by exiled
What does your transmission have to do w/ your engine. Thoight we had the same transmission.
They do have the same transmission, but due to the rpm differences the v10 can always be at least one gear lower than the psd. Being able to turn more rpms allows you to stay in a lower gear longer, which helps you put more tractive force to the ground. That is why your truck pulls harder in 1st than it does 2nd, harder in 2nd than it does 3rd, and so on, even though the engine is making the exact same hp and torque at the flywheel. Gearing multiplies torque, which means you can have less engine torque but still put more torque to the ground.
