Sponsored by: Real Truck
Gas vs PSD
Old Sep 3, 2010 | 11:04 AM
  #7906
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Kajtek1
That sure would cover lot of plug holes repairs.
Including the holes in the hood.
I still have yet to see a plug get spit out that was put in right.
Old Sep 3, 2010 | 11:06 AM
  #7907
bill11012's Avatar
bill11012
Originally Posted by ChargersFanInCO
True...because they have different gears....Thank you for being so astute.
And the V10 puts more torque to the ground becuase its able to run in a lower gear than the PSD. More HP and more lb ft at the real wheels.
Old Sep 3, 2010 | 12:09 PM
  #7908
ChargersFanInCO's Avatar
ChargersFanInCO
I'm still waiting for you to make the drive from TX to here...then we'll see who puts more torque to the ground.
Old Sep 3, 2010 | 12:14 PM
  #7909
Fishin76's Avatar
Fishin76
You'll lose if he has shorter gears than you.........no comparison. 3.73 in PSD, 4:30's in V10. He'll win, by gearing alone.....
Speaking of gearing, I was looking at 2010 6.4L with the snow prep pack, It had 3.55 gears! and a torqshift. ......
Old Sep 3, 2010 | 12:28 PM
  #7910
1975StroppeBaja's Avatar
1975StroppeBaja
Maybe you should make the drive from there to TX to put him in his place. Why does the pull off have to happen where you're at?
Or maybe you could meet halfway somewhere.
Old Sep 3, 2010 | 12:46 PM
  #7911
bill11012's Avatar
bill11012
I have 3.73s. Gearing does not make much of a diffrence when you are at speed, its just getting a load moving.
You will, I have a 10 year old 2V. You need to have a pull off with the same age truck with a 3V. That will beat you.
He wants the pull off to be at his elevation, he is afraid of losing without that advatage.
Old Sep 3, 2010 | 12:52 PM
  #7912
exiled's Avatar
exiled
My answer to this question is I'm always working. I never get to play. I thought raising cattle and working at a grain elavator work be easy. Nope. I'm trying to keep tabs and if i see I'm going into an area that a member is in I'll offer to have a tow off on his home ground.
Old Sep 3, 2010 | 01:19 PM
  #7913
Jrfish007's Avatar
Jrfish007
As Bill said, it elevation. The turbo helps compensate for much of that, while Bills N/A V10 engine is left huffing an puffing and producing less power than a 4.6L 2V.
Old Sep 3, 2010 | 01:23 PM
  #7914
Jrfish007's Avatar
Jrfish007
Why not, to push snow all you need as that low end torque to bend the frame up.
Seriously though, if a 5.4L with a 3.73 can do it, I'm doubtful a 6.4 with a 3.55 would have an issue.
Old Sep 3, 2010 | 01:27 PM
  #7915
Fishin76's Avatar
Fishin76
It does make a difference at speed. Lower gears keep you higher in the powerband when traveling normal highway speeds. (where is counts when towing.) staying higher in the powerband usually translates to less MPH loss towing up hills.
I wasn't saying you had 4.30's, that was just for comparison. i couldn't remember what gears you had, haha... That was the 'IF' statement... "If he has shorter gears" in my previous post.....
Old Sep 3, 2010 | 01:28 PM
  #7916
exiled's Avatar
exiled
The 37 HP will more than make up for the torque. If he was running his truck WOT it would out pull you up hill, no matter the load. Starting at highway speeds just plays right into the V10s favor.
Why will he not load over 20K GCW?
No it wont. i dont have to run at WOT to be in my powerband. How does 37 horses make up for the 93 lbs of tq? I'm reminded of The 302 mustangs and 350 camaros. The 302 weighed in a 225 ponies while the camaro brought 285 horses. What your saying in the camaro will be there before the mustang could get out of !st. This is not true. All the mags shotouts has the to 2 crossing the line in a time difference we cant see. Now which 1 was in front well that depended on what mag you was reading. I ate up alot of camaros over the years and been ate by a few as well. It was the stangs tq that got it down field. I cant remember the TQ numbers but 225 hp was more than enough to drive the tq. At highway speed my 410 over 430 is a very very very small advantage. If it where that i had 373s i would have a larger advantage. Please I want to understand.
Old Sep 3, 2010 | 01:31 PM
  #7917
Johnny Langton's Avatar
Johnny Langton
Camaro vs Mustang in the 80's was all about weight.
JL
Old Sep 3, 2010 | 01:37 PM
  #7918
Fishin76's Avatar
Fishin76
I'm not saying it wouldn't push snow. it'll do that just fine. but it will do more upshifting with the 3.55's verses the 3.73's when towing/hauling. IMH0, 3.55's are balance gears anymore. A balance between power and economy. 3.31's economy gears, 3.73 - 4.10's towing gears, 4:30 extreme payload and towing. I had a 5.4L F150 with the 3.55's, it did ok, but I wished it had the 3.73's for a bit more kick in the pants.... I always thought that 3.55's in that truck kept the RPM too low for best MPG's. i think ford did it for acoustical reasons.....
Old Sep 3, 2010 | 01:46 PM
  #7919
Jrfish007's Avatar
Jrfish007
I had 2 F150's with 5.4 and 4.10's, they weren't great in for speed considering the hit I took on mpg's. My buddy that has an F150 with the 4.6 and 3.55 would have smoked my 5.4 with 4.10's just because he has the new 6-speed and I always had the 4 speed.
Old Sep 3, 2010 | 01:53 PM
  #7920
Fishin76's Avatar
Fishin76
I agree, 4.10's with a 5.4L and a 4r70w (updated AODE) is not a good combo for MPG's.. Your buddy must have a new F150 with the 3V 4.6L, the 6speed auto and 3.55's. The 3V 4.6 is only 25 hp short of the 5.4L and only 30 or 40 ft/lbs less torque, So yes, i believe you that your buddies truck would beat yours. 3.73's, by all the posts and articles i have read, were the best gears to have in the 2004-2008 F150's.
