Sponsored by: Real Truck
Gas vs PSD
Old Sep 6, 2010 | 11:07 AM
  #8086
dkf's Avatar
dkf
I don't know how it happened or even why. 1 thing I'm pretty sure of though its not like sand man wants us to believe. When a spark plug is spit it don't just "fall out". I imagine there's pressure there. If it blew on the ignition I'm real sure that plug was moving. It would be easy to find out how much pressure it could have.
There will obviously be force pushing against the plug on the upstroke. I'd bet money the plug gave signs prior to being blown. Blowby sound, tick and probably detontation. (possibly excessive) Detonation can be a very harmful and can really shock the internals, obviously.
Old Sep 6, 2010 | 11:10 AM
  #8087
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by scraprat
Here is an old article from 2007. It will give you PSDs more reason to keep the DSLs. When reading further down in the article not one plug was thrown through the the hood and hey it was only one truck that burnt up. Now that would fall into the stimulus package.
Spit Spark Plug Ignites Ford Truck
That would cost a lot more than anything on the PSD, fer-sure...Well, it would be an insurance write-off, so I guess not. At least I don't have to worry about being burned alive by my 6.4.
Old Sep 6, 2010 | 11:30 AM
  #8088
Sand_Man's Avatar
Sand_Man
Originally Posted by exiled
Why am I going to go out my way to prove it to you. I don't what you believe. Its not my point. My point is some of you are to lazy to do some research or don't know how. And sit around and run there their mouth. My point was the v10 has had problems. Proof that wrong. Where's your proof? BTW I could proof it though. I can post his work order. No I'm not cause like I said I don't care what you think. Now if you had acted like you has some sense and was wanting to learn something I would have gone out my way to get the info to board. Attacking me doesn't get the results you want.
Proof for your story is like the Roswell UFO crash evidence of 1947, lots of people claim it exists, some have said they've even seen it. But until someone gets it out of the vault, it is what it is, another urban legend. BTW, as for my proof, it's sitting in my driveway and has all 10 plugs in it and has had since day one. And your semantics and spelling still blow...
Old Sep 6, 2010 | 11:39 AM
  #8089
Kajtek1's Avatar
Kajtek1
From the linked article showing burned down Ford as a result of spit plug.
Instead of putting consumer safety first, NHTSA is backing Ford. It's refusing to consider spit spark plugs beyond stating that its analysis of 474 complaints describing the incidents "found only a very few alleged any safety-related consequences. None of these showed any evidence of a serious safety consequence."
This is the same NHTSA that in the last year has recalled 45,000 Honda Civic hybrids because the engine could stall; 1.2 million Honda and Acura vehicles because their owners manual had incorrect information about NHTSA's "safety hotline;" a few hundred thousands Nissan Altimas and Sentras because the engine could stop running at slow speeds; 45,000 Chrysler vehicles because leaking brake fluid could start an engine fire.
The agency made Audi stage a second recall of some A6 sedans, claiming a previous recall had not fixed a headlight switch that could short out and start a fire.
This is just another proof (besides promoting gas guzzlers) how far can "corporate dollars" make into the politics in this country.
What makes me wonder is howcome V10 owners instead of demanding safety for themself, their families and coworkers - keep downplaying the problem?
Old Sep 6, 2010 | 11:43 AM
  #8090
Kajtek1's Avatar
Kajtek1
I guess that explains everything.
Old Sep 6, 2010 | 11:51 AM
  #8091
dkf's Avatar
dkf
I keep wondering how you can keep violating FTE guidelines bringing politics BS into this thread time after time and not get an infraction.
Old Sep 6, 2010 | 12:04 PM
  #8092
scraprat's Avatar
scraprat
Top Answer: 5
For the sheets and giggles I went to goggle and typed the same phrase... Ford ____ problems changing the blank to V10, 7.3, 6.0, 6.4 and in that order this is the amount of results are as follows. Keeping in mind it searched for that phrase. So it could be any problem with in that search. All things being equal only the engine changed in the search.
V10 -- 240,000
7.3 -- 994,000
6.0 -- 1,810,000
6.4 -- 993,000
Old Sep 6, 2010 | 12:25 PM
  #8093
ChargersFanInCO
V10 -- 240,000
7.3 -- 994,000
6.0 -- 1,810,000
6.4 -- 993,000
Strange...Mine shows the following...
V10 240,000
6.4 985,000
6.0 1,760,000
7.3 990,000
Seems like you added a few thousand to the diesels, but you got the V10 right. However, if I google "ford v10 blown spark plug fires" there are 216,000 results there also...
Now, I'm not trying to stir the pot here, but Google results mean absolutely nothing. All it is is a ranking. If you went to the last page on ANY of the listed subjects, you'd probably find a crayon picture with a 4yr old writing I wish I had a *insert engine size here*... Even if the numbers were relatively close, they sell 6-7 PSD's for every V10, so that would mean the V10 has more issues than the 6.4 using your Google rankings...
Old Sep 6, 2010 | 12:26 PM
  #8094
Kajtek1's Avatar
Kajtek1
FYI I was warned to keep some comment only in this topic
Than I guess only some can't see that we have well over 8000 replies in this topic, that violate FTE guidlines.
Old Sep 6, 2010 | 12:28 PM
  #8095
Kajtek1's Avatar
Kajtek1
You google "kajtek1" and you get 42,000 hits.
Bad news >>> most of them are mine
Old Sep 6, 2010 | 12:30 PM
  #8096
ChargersFanInCO
I mean c'mon...Google? Just for sheets and giggles I typed "ford moon bat problems" and got 354,000 threads...Anybody driven a Ford Moon Bat lately?
Old Sep 6, 2010 | 01:27 PM
  #8097
bill11012's Avatar
bill11012
Modular motor junkie
Its perfectly safe, there is no problem!
I am not downplaying anything. Put them in right and it will NEVER be a problem.
Why is that?
Old Sep 6, 2010 | 01:35 PM
  #8098
Kajtek1's Avatar
Kajtek1
Here we go again. Would you like to tell that to those who lost their trucks thanks to shooting plug?
I was close to loosing my Ford due the windshield wiper circuit shortening on parked truck. Others lost not only the trucks, but also their homes due to shortening CC circuit. Do I say the Ford is perfectly safe truck?
Old Sep 6, 2010 | 01:48 PM
  #8099
bill11012's Avatar
bill11012
The CC switch was a real problem.
The plugs just need the proper torque.
Old Sep 6, 2010 | 02:52 PM
  #8100
Kajtek1's Avatar
Kajtek1
And that is what cost $800 at dealer exchange, or $1200 at a repair?
I never had CC switch problem.
