Sponsored by: Real Truck
Gas vs PSD
Old Sep 5, 2010 | 04:26 PM
  #8041
Johnny Langton's Avatar
Johnny Langton
Originally Posted by exiled
Your one of the very rare situations. You drive your truck empty 8 miles a day. So yea I guess it really don't matter what it burns. Fuels around here right now is $2.55 for 87 and $2.85 for diesel. I get 18 mpg empty. The best I've read for a v10 is 14mpg. That's a 4 mpg differnce. So on 10 gals I get 40 more miles. So 14 mpg I'm saving nearly 3 gals. 2.55x3=7.65. That's $7.65 I'm saving every 10 gals. W0 gals of 87 cost $25.50 and 10 gals of diesel cost $28.50. Now that my savings is $7.65-$3.00 making it $4.65 adjusted for every 10 gals. The least I buy a month is 120 gals. For every 10 gals I'm saving 3 so that 12x3=36 gals36x$2.55=$91.80 a month. Just times that by 12 and the number gets bigger. That's makes a big differnce when the price of cattle falls out and price of grain goes up along w/ the price of fuel. So don't tell me the lower price of gas makes the differnce in mpg cause it don't. Its very simple math. When your truck becomes the center of your paycheck you understand that.
You'll lose alot of ground in your argument when you have to replace that HPOP, and a turbo or two.
JL
Old Sep 5, 2010 | 04:27 PM
  #8042
PorchFarms's Avatar
PorchFarms
i could make one hella commercial for ford with all the stuff i've done with my truck. Once pulled semi loaded with 15 tons of saw dust 5 miles to shop. Worst part was turning in. Pulled cotton module builder 60 miles. Semi blew engine at rest area 40 miles from ok city. Semi lost all air and locked brakes, took pick up and pulled out of way. Plus got to pull out dumb dodge driver who tried to go around. Hauled 2 mx 110 tractors on 35 ft gn. If i can hook up to it i will try.
Old Sep 5, 2010 | 04:31 PM
  #8043
Johnny Langton
Originally Posted by Kajtek1
Should install Fumoto valve. It is 15 minutes for me now.
How V10 do with burning oil? I usually add 2-3 quarts between 10,000 changes.
None of mine burn any oil. F250 has 82K miles, Excursion has 73K miles. F150 with 4.6L(identical same engine tech) has 245K miles, same thing.
Originally Posted by Kajtek1:9296354
Even with $800 spark plug changes?
My plugs are the most expensive plugs to be had for a modular, and cost $90. As is typical with most diesel owners, you quote dealer ripoff prices for plug changes,etc, but at home repairs/maintenance for your diesel.
JL
Old Sep 5, 2010 | 04:39 PM
  #8044
Cory281's Avatar
Cory281
Oh really? I just got back from wal-mart buying oil and a filter. Grand total $58.67. So I'm saving myself $30? Cool. What is the suggested change on the v10s fuelfilter? Be back in abouit 30 minutes going to go change oil.
I worked at a oil change shop for a couple of years a long time ago. For gas engines we always recommended once a year. I've always done that on my F150 and both my Mustangs, I think that is kind of overkill actually, but I've always done it. I actually just took my brothers V10 in for him for a fuel filter, it had never been changed and it's a 01 with 70,000ish miles. It was pretty dirty.
If you change your own oil, you do save some money, your truck is a 6.0 right? That would be nice to do yourself because the filter is up top and not that big huge filter the 7.3 uses, I made a few messes taking those big baby's off when they are hot.
Old Sep 5, 2010 | 04:42 PM
  #8045
Cory281's Avatar
Cory281
JL
None of my 4.6's I've had burn any oil at all, and they get abused from time to time. My brothers V10 doesn't burn any either. He had his plugs changed on his truck by a mechanic and it cost him around $100 dollars.
Old Sep 5, 2010 | 04:57 PM
  #8046
phillips91's Avatar
phillips91
Originally Posted by PorchFarms
The funniest part of this thread is the gas drivers dont realize that the diesel owners have or have had gas trucks before! I personally have had any make of ford gas engine made. So i know what they can and cant do.
I currently own both and can tell you what they can do too. I have also towed the same trailers with a 4.6, 4.9, 5.0, 5.4 2v and 3v, 5.8, 6.0, 6.8 2v and 3v, 7.3 OBS and SD and 7.5 as well as several other older models.
Originally Posted by ChargersFanInCO
The diesels get better mileage, and it more than offsets the price difference between gasoline and diesel fuels.
Depends on which psd you are comparing it too. Johnny gets 15 mpg's out of his v10 and I get 20 mpg's out of my 7.3. Over 1,000 miles I will use 50 gallons of fuel at 2.85 per gallon for a total cost of 142.50. Johnny will use 67 gallons of fuel at 2.40 per gallon for a total cost of 160.00. If a 6.4 gets 15 mpg like most I have talked to, it would use 67 gallons of fuel at 2.85 per gallon for a total cost of 190.95.
Saying a 5.4 will start moving a load faster than a diesel is crazy.
Go back and read what I said. I said MY 5.4 with a manual and 4.10 gears will get a load moving easier than SOME diesels with an automatic. I can start out in 1st(low) and the diesel is having to start out in its 1st, which is the equivalent of my 2nd. I never said a 5.4 would get a load moving better if they had the same gearing or if the 5.4 had an automatic.
Old Sep 5, 2010 | 05:19 PM
  #8047
Cory281's Avatar
Cory281
Originally Posted by phillips91
I currently own both and can tell you what they can do too. I have also towed the same trailers with a 4.6, 4.9, 5.0, 5.4 2v and 3v, 5.8, 6.8 2v and 3v, 7.3 OBS and SD and 7.5 as well as several other older models.
Go back and read what I said. I said MY 5.4 with a manual and 4.10 gears will get a load moving easier than SOME diesels with an automatic. I can start out in 1st and the diesel is having to start out in its 1st, which is the equivalent of my 2nd. I never said a 5.4 would get a load moving better if they had the same gearing or if the 5.4 had an automatic.
Kind of off topic here, but what gas motor did you like the most for pulling out of all of those?
Old Sep 5, 2010 | 05:42 PM
  #8048
Kajtek1's Avatar
Kajtek1
JL
Isn't that thread all about being biased?
Gassers owners brag about expensive oil changes on diesels what is mentioned $60 material cost and 20 minutes of labor, but forget to quote their spark plugs service, that is way longer than 20 minutes of labor and done in about the same intervals
Old Sep 5, 2010 | 05:56 PM
  #8049
ChargersFanInCO's Avatar
ChargersFanInCO
So because you "read" that a 6.4 gets 15mpg, so it must be true? I've seen people who get better mileage than mine, and I get 19.9 - 20.4mpg now...Hand Calculated. And you know what?, I don't care who says I'm lying, either. I get hella' good mileage out of mine going to Denver daily. (73 miles each way)
Old Sep 5, 2010 | 05:59 PM
  #8050
ChargersFanInCO
They also refuse to acknowledge those like me who have a maintenance package good for 150,000 miles from the dealership, so I couldn't care less how much an oil change, fuel filters, or brakes cost...I do have a spare set of FF's in case I ever get bad fuel. My maint pkg was included in my $30,885.00 out the door price.
Old Sep 5, 2010 | 06:12 PM
  #8051
exiled's Avatar
exiled
JL
Why is my fuel mileage going to go down? Only thing I'm saying is .30 a gal difference in fuel doesn't offset fuel mileage.
Old Sep 5, 2010 | 06:19 PM
  #8052
Kajtek1's Avatar
Kajtek1
They also refuse to acknowledge those like me who have a maintenance package good for 150,000 miles from the dealership, so I couldn't care less how much an oil change, fuel filters, or brakes cost...I do have a spare set of FF's in case I ever get bad gas. My maint pkg was included in my $30,885.00 out the door price.
I bought my PS at 6 years of age for $8000.
No maintenance package at almost 200k.
Old Sep 5, 2010 | 06:23 PM
  #8053
exiled's Avatar
exiled
JL
Old Sep 5, 2010 | 06:27 PM
  #8054
phillips91's Avatar
phillips91
I liked the 4.9 the least. One of the weakest things I have ever towed with by far. I know I will get flamed by many people for saying that, but it's the truth. Best one for me was the 3v v10. It had more low end power than the 7.5 and kept pulling even stronger as the rpm's climbed.
I never said you were lying or that you don't get the mpg's you say you do. I just always throw out the lowest and highest values that I hear and go with what I see the most of. Bill gets 7-8 mpg's out of his v10, but I know how he uses his(lots of idling, farm work, pedal to the floor running 90, etc), so I wouldn't use his number. I used to get 23 mpg's out of my 7.3 routinely, but that was driving 450 miles straight with no load at 55 mph, so I wouldn't use that as a number for the 7.3.
Old Sep 5, 2010 | 06:34 PM
  #8055
Johnny Langton
Never said your fuel mileage will go down. A $2000 HPOP buys a helluva lot of fuel.
JL
