Sponsored by: Real Truck
Gas vs PSD
Old Aug 28, 2010 | 06:00 PM
  #7651
phillips91's Avatar
phillips91
Originally Posted by exiled
I,ve been thinking about the problems the v10 and 5.4 have had since 2000. They both had spark plug spitting problems. In the 3v heads in 04 and 05 models.{I listed them cause that's what I have and had} The spark plugs seized up in the heads. I don't know if this was ever fixed. So I change my wifes every 20,000 miles in her f150 and mustangs. So I really don't listen to the 100k mile spark plug change argument. I've never noticed more v10s than PSDs. I don't think I ever will either.
The problem with the 3v spark plugs is the plug itself, not the engine. Certain brands of plugs are a two piece design that can break if too much torque is applied. A lot of people go with the one piece design when they change plugs and that eliminates the problem. The early 2v's were a combination of fewer threads, aluminum heads and faulty installation. If installed properly they would never have a problem, but put one in cross threaded and it's coming out pretty quickly.
Old Aug 28, 2010 | 07:09 PM
  #7652
2001400ex's Avatar
2001400ex
If you are going to go there, then I can say all the 6.0 problems can be solved by changing out the head bolts. It is a problem with the bolt itself, and not the engine. So... that means it is not a big deal.
LOL Doesn't matter why, fact is it was a design flaw.
Old Aug 28, 2010 | 07:27 PM
  #7653
phillips91's Avatar
phillips91
Changing plugs is normal maintenance on a gasser. When I buy one I expect to have to change the plugs. So when it comes time to change them just put the proper ones back in(or change them immediately when you buy the truck). That is a very simple and cheap fix compared to changing head bolts on a 6.0(which should NOT be normal maintenance on any vehicle). Without writing a book, head bolts are far from the only design flaw that needs to be fixed on the 6.0 (turbo vanes, egr problems, fuel injectors, etc).
I agree both are design flaws and should never have happened, but they aren't even in the same ballpark when it comes to severity of problems caused or cost to fix.
Old Aug 28, 2010 | 07:30 PM
  #7654
dkf's Avatar
dkf
You break a plug off in a 3V modular you get the broken plug removal kit specified by Fords TSB. You blow plug in a modular use a timesert of similar kit to fix the problem. Both fixes are a drop in the bucket compared to replacing the head studs on a 6.0l.
Old Aug 28, 2010 | 07:43 PM
  #7655
2001400ex's Avatar
2001400ex
My point is, who cares why the flaw is there. If it is in the truck it is an issue.
And if you spit a plug in a stock V10, your engine dies, you are calling a tow truck, and replacing the engine. If your head gaskets go, you have warning signs, you still go home, and place the gaskets and bolts.
As for the EGR and other problems, all depends on maintenance. There are thousands of people with zero problems with the EGR, turbo veins, and injectors (which injectors are a problem in all diesels after a certain number of miles).
Old Aug 28, 2010 | 07:53 PM
  #7656
phillips91's Avatar
phillips91
There are different levels of flaws when it comes to things like this. My 7.3 has a flaw with the cam sensor, but if it goes out it is no big deal. A free part, one bolt, 5 minutes and it is fixed. That is a flaw that I can live with, but still a flaw.
Why would I need to replace the engine if my modular shoots a plug??? It is a simple repair that you can do on the side of the road in less than an hour. You can still drive the truck without a spark plug in it too. It's not going to run the best, but it will still run.
Old Aug 28, 2010 | 08:16 PM
  #7657
FORDTUF1's Avatar
FORDTUF1
My stock 6.7 will outpull anybodies stock or modified truck except for one guy. He had a Ford 6.4 with a boatload of mods and his own software to program the truck himself.
I know this because I pulled in the truck pull last weekend and finished 2nd. I'll bet once the re-flash comes I'd be able to even beat him because he only pulled 5 feet farther
There were several Dodges and Chebbies modded and blowing big black smoke, but oh so sad they had a big FAIL.
Old Aug 28, 2010 | 08:37 PM
  #7658
2001400ex's Avatar
2001400ex
Talk to Bill, he will take you AND your V10!!!! Just ask him, he will tell ya. LOL
Old Aug 28, 2010 | 08:52 PM
  #7659
exiled's Avatar
exiled
The siezed spark plugs was do to carbon getting in between the ground shield and the head. The rotting of the groundshield was due to unlike metals. I had the same thing on my 05 and wifes 04. Cam sensors was a problem on 3v engines too.
Old Aug 28, 2010 | 10:22 PM
  #7660
Kajtek1's Avatar
Kajtek1
Originally Posted by bill11012
I talked to a Fed ex driver about them and he never said anything about 2 million miles... He said they were underpowerd POS's that needed new injectors every 100K miles.
Sprinter per my recollection are in US for not much longer than 5 years, therefore not too many of them could gain such a mileage.
They are on European roads for about 15 years and I hear about 2 million miles, or 3 millions kilometers on them quite often. Followed a farmer in one years ago. Driving Fiat Punto with top speed 100 mph I could barely keep up.
  #7661
Jrfish007's Avatar
Jrfish007
Really? Haven't heard of any of the V10's complaining about cam sensors?
I pretty sure the 3V's fixed the spark plug issue too.
Old Aug 28, 2010 | 10:27 PM
  #7662
Kajtek1's Avatar
Kajtek1
Fords are indeed used for motohomes, some pricey ones too. The F53 and other 350, 450 and 550 chassis and powertrains are used.
FORD F53 Super Duty Class A Motorhome Chassis | Stripped Chassis | Ford Commercial Trucks
The bare chasic yes and exclusively with gas engine. Good luck finding diesel model. There are available motorhomes with E350 cabin, but far from luxury and very far from 20 mpg.
Old Aug 28, 2010 | 10:30 PM
  #7663
Jrfish007's Avatar
Jrfish007
Today I made a point to notice the engine in the SD's I came in contact with. The 1st 7 was on a road crew. 3 350s and 4 250s. 1 of the 350s was a single and it had a 5.4. All of them where 05 and newer and had a 6.0. Going by the sale barn I pulled in to check things out. 3 dodges 5.7. 1 chev don't know what it had. 17 SDs. 8 6.0s, 4 6.4s, 2 6.7s, and 3 7.3s. When I got to the dealership I'd decided to pull in and look around. Out of 30 something SDs there was only 3 v10s.there was no 5.4s{Saw a raptor. I thought it was ugly} I got to work finally, counting mine there was 5 SDs. 3 6.0s 1 5.4 and 1 7.3. I,ve been thinking about the problems the v10 and 5.4 have had since 2000. They both had spark plug spitting problems. In the 3v heads in 04 and 05 models.{I listed them cause that's what I have and had} The spark plugs seized up in the heads. I don't know if this was ever fixed. So I change my wifes every 20,000 miles in her f150 and mustangs. So I really don't listen to the 100k mile spark plug change argument. I've never noticed more v10s than PSDs. I don't think I ever will either. As far as engines go any body that I've talked to that had a problem w/ their 6.0 it was w/ a components not the engine. The engine failures that I have heard of was from tuners. Right again the 6.0 has left a bad taste in a lot of people's mouth. I bet no more so than Ford and International.
Comon... this is funny.
1. at the V10's prime selling point, it only consisted of 14% of SD sales. often is wa around 10%. If only 10% of SD's have the V10's, you probably won't see many of them. I think it's close to 75% have PSD's, so of course you ar going to see more of them.
2. (and this is where things get funny) You are actually saying the modulars have issues and comparing it to 6.0 issues. All I can say is that hurt... Sam Adams coming out your nose hurts. Seriously though, you are comparing a repair bill that might cost $200 IF you send it to shop to the problems the 6.0 has. New injectors cost what about $2000? I've seen plenty of people on here with $5000+ repair bills for their 6.0's. Ford dealer told me it would be about $3500 to put a remanufactured V10 in my old truck, and that's the freakin stealership.
Sorry, I would take a $200 repair over the $5000 repai any freak day.
And yes, I never leave sparks in any of engines for more 50k miles. They are to cheap not to replace IMO.
Old Aug 28, 2010 | 10:32 PM
  #7664
Jrfish007's Avatar
Jrfish007
I know this isn't truck related, but it a diesel... One bad deisel...
Video: Merc E-Class estate gets slidey - BBC Top Gear
Old Aug 28, 2010 | 11:00 PM
  #7665
mountaineer27's Avatar
mountaineer27
wow, this guy took a brand new truck to the pulls...... hahahaha enjoy your twisted frame!!!
