Sponsored by: Real Truck
Gas vs PSD
Old Jul 22, 2010 | 07:34 PM
  #6841
phillips91's Avatar
phillips91
Originally Posted by 2001400ex
That shows why you should not be stating things as fact. The emissions on the 6.0 do not affect mpg. The 6.4 only affects mpg because the dpf uses additional fuel to burn out the bad stuff from the engine.
My neighbor has been getting 9-10 mpg's out of his for the last year and the most common response I get from 6.0 guys is that he needs to do an egr delete because it is probably clogged and hurting his mpg's. Whether or not that is why he gets bad mileage (or the other guys I know), I don't know. Either way, it doesn't change the fact that they don't get the mileage you get out of yours.
Edit-Just looked up a few different egr delete kits and they all say that they improve fuel mileage on the 6.0.
Part Number: BDD1090001
* BD Diesel EGR Cooler Delete Kit
* Improves fuel mileage and engine reliability
From a 6.0 tech page.
2.What goes wrong with this system and how can it hurt my engine?
The other problem with the system is that the egr valve constantly gets coked up with exhaust soot. The dirty exhaust gas passing by it deposits soot on the valve surfaces. Sooner or later the valve will get enough soot on it that it can’t close and operate normally. Exhaust gas is constantly pouring into the intake manifold now. This condition causes severe drivability issues, POOR FUEL ECONOMY, and low power.
4.Will deleting the cooler affect the way my truck runs? Will I get a check engine light?
The answer to the first question is yes. You should see an increase in fuel mileage....
Old Jul 22, 2010 | 07:57 PM
  #6842
2001400ex's Avatar
2001400ex
Edit-Just looked up two different egr delete kits and both say that they improve fuel mileage on the 6.0.
And the K&N cold air intake says the same thing, doesn't mean it is true. Of course they say that. Read around that forum, there are plenty of stock people, and if running right, they get way better than 9 or 10. I did have a buddy with a lifted 6.0 with 35s, f-350 crew/long that was modded similar to mine, that only got 10 or so.
I would advise your friend to do the following:
Check/change the air filter, replace only with OEM.
Change the fuel filter, only replace with OEM
Check for low fuel or other codes
Check the turbo boot, clean it
Check the EGR vavle, clean it
Flush the coolant, add a coolant filter
Have the ECT and EOT temps measured to ensure they are within 15 degrees
Use Diesel Kleen or some other cetane additive
The way you word it above, it says in the past year. To me that means it didn't always get that mileage. I bought mine last year at 93k miles and modded it around 102k and have almost 119k now. My mileage is roughly the same now as it was before, really the biggest difference is EGTs are lowered so I can pull hills better.
Old Jul 22, 2010 | 08:10 PM
  #6843
phillips91's Avatar
phillips91
His is the worst one I have seen when it comes to mpg's. It's an xl, reg cab, manual, 4x4 with nothing in it but him. It's an 07 model, he bought it new and it has less than 20,000 miles on it. For a while he was getting as high as 12 mpg's out of it but for the last year or so he said it has been around 9-10. No smoke, no power loss, no CEL or any problems of any kind other than the mileage went down.
Old Jul 22, 2010 | 08:43 PM
  #6844
Kajtek1's Avatar
Kajtek1
SorryI missed these...
That shows why you should not be stating things as fact. The emissions on the 6.0 do not affect mpg. The 6.4 only affects mpg because the dpf uses additional fuel to burn out the bad stuff from the engine. The only additional emissions stuff on the 6.0 is the exhaust gas recirculation, which just pushed exhaust gasses back into the turbo, and does not require additional fuel. Read through the 6.0 threads and you will see what I am talking about. My mods were not about fuel mileage, just about reducing my EGTs and programming the transmission so the truck drives better.
In 9 years, the techonology has improved, and so has fuel mileage, dramatically, so that just proves my point. Go check out MSN autos and you will see the mileage I am talking about.
The 11 is purely city driving, 15 is highway. So a mixture of 13 is reasonable. Here is the link:
2002 Ford F-150 Engines and Fuel Economy - MSN Autos
The technology did improved, but not necessary for Ford. I still consider my 99 PS 7.3 diesel the best truck available on today's market. Would love to own the 25 mpg Sprinter as a back up for smaller loads.
Than this is the readout from my 2005 car. The 49 mpg averaging 81 mph.
The 2005 car makes about 9 years old technology?
Old Jul 22, 2010 | 10:58 PM
  #6845
2001400ex's Avatar
2001400ex
It is still in warranty, if he were my friend, I would suggest he get it in to the dealer. These engines can have codes with no CEL, in fact it is very common. There are codes that cannot even be read by standard code readers. A regular cab manual should get way better mileage than mine, even bone stock. A dealer should be able to diagnose it. Honestly, my guess is with the little mileage, it sat and the turbo vains rusted, and it is not providing proper boost.
When done at the dealer, I would install a coolant filter ASAP.
Old Jul 22, 2010 | 11:21 PM
  #6846
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Old93junk
As you get older.........your foot cant press the skinny pedal as far.
Being old does not sound like much fun.
Old Jul 23, 2010 | 12:58 AM
  #6847
Kajtek1's Avatar
Kajtek1
I prefer the word "experienced"
Like 7.3 is experienced and reliable engine
Old Jul 23, 2010 | 09:53 AM
  #6848
phillips91's Avatar
phillips91
He's had it in the shop numerous times trying to figure out what is wrong with it and they can't find anything. They kept it for over a week straight one time and checked every last thing on it and still no improvement.
Old Jul 23, 2010 | 10:15 AM
  #6849
2001400ex's Avatar
2001400ex
He needs to find another dealer. If it was in the dealer, doubtful it is a clogged egr as they usually clean that.
Old Jul 23, 2010 | 10:24 AM
  #6850
7.3stroker95's Avatar
7.3stroker95
Going Bio
Have you ever seen a gasoline powered freight locomotive? The fuel is more conducive to effiency, and power building in a Rudolph Diesel engine. Even a Diesel powered marine crat is more reliable, safer and has a longer working life. All while properly maintatinededed. So, that means the answer to your ? is the difference is great while the advantages are clear and the caveats are on the side of the owner with the most shallow of pockets. All factors being equal, the Diesel is the preffered choice of military and industry. Not to mention the diesel does not have a throttle. And does take in a maximum capacity of air on each stroke, while ideling on a mere mist of fuel. while the V-10 without the effieciency is powerful, it is only a good alternative to the vastly superiour powerplant of a Diesel engine. This response is without prjudice, as I have owned several models with each engine, and have found through thousands of gallons of each type of fuel that the gas vs diesel comparison is in it self a flawed argument. It is on the same level of comparing a Prius to a Bulldozer.
Old Jul 23, 2010 | 10:38 AM
  #6851
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by Jrfish007
11/15... Now that made me laugh. Honestly you think gassers get that bad mpg? now wonder why you hate V10's... you must think we get like 2/4 mpg
Here, it's a 2001 window stick for a 5.4L super crew, you can clearly see 15 and 19, no where near your supposed 11/15. Granted it has 3.55 gears, but I'm doubtful that the jump form 3.55 to 4.10 will result in a 25% loss in mpg.
Google Image Result for http://home.earthlink.net/~rghayes/sticker.jpg
If you don't believe me that my previous F150 got 15/18, that's fine. You don't even have to believe the weights I posted, I have no proof of them. The guy just wrote down what popped up on the screen and subtracted it from the loaded weight. I don't have slips or anything to prove it (although I can say the high payload package comes with heavier axles and multiple frame reinforcements -i.e. they boxed the frame in- and that is not light stuff.)
But you can't honestly believe that a 5.4L F150 is going to get the same mpg as a V10 super duty...
My 2008 Lariat F150 with a 5.4 was rated 13/17...I got right around 13/15
Old Jul 23, 2010 | 10:41 AM
  #6852
ChargersFanInCO
Originally Posted by LSchicago2
I have a 2V V10 03 F450 6 speed I'd put against any stock naturally aspirated 5.4 in a tow off.
Then you need to talk to Phillips91 since I own a 6.4 PSD that would eat your V10...
Old Jul 23, 2010 | 10:43 AM
  #6853
ChargersFanInCO
Originally Posted by Krewat
B Tire size has as much to do with TOTAL gearing as gear ratio does. I'm willing to bet that the Superduty has larger diameter tires than the 150, so the effective gearing is closer than you would think.
My 09 SD has the same size tires and rims as my 08 F150. Same OD.
Old Jul 23, 2010 | 10:46 AM
  #6854
ChargersFanInCO
First of all, the guy says he is towing a 12,500 lb trailer, not 8,000. He is also at 10,000 feet elevation. And he is also asking if he is going to hurt his engine by running it 4,500 rpm. It is beyond me why these people think they are going to blow an engine up when they aren't even running it anywhere near peak hp, much less over revving it. Probably an ex diesel driver that doesn't realize it's ok to rev it over 3,000 rpm.....
Dayummmm...all the way down to first gear for a mountain pass?
Old Jul 23, 2010 | 11:46 AM
  #6855
phillips91's Avatar
phillips91
Like I said before, at that elevation his engine is making less power than a first generation 4.6. He is also afraid to press the gas pedal and isn't even reaching peak hp(not the trucks fault). What gear he is in doesn't matter because the gasser has to be a gear lower than the psd in order for both to be going the same speed at peak power. For example, Bill can do 80 mph in 2nd gear with his v10 while my 7.3 is at the redline in 4th(same as Bill's 3rd) at 70 mph. It doesn't make his truck "weak" just because it is a gear lower to do the exact same thing.
We also don't know the speed limit on the hill he is climbing either. He did mention a 15 mph speed limit through a curve, so I can't imagine the speed limit being too high.
