Sponsored by: Real Truck
Gas vs PSD
Old Jul 21, 2010 | 05:24 PM
  #6781
jac08f250's Avatar
jac08f250
Originally Posted by phillips91
Why is it you can never read? I said my cousin(not any of his friends), my neighbor(not some guy he used to know that may have had a 6.0) and people that worked with me(not someone that some guy that used to work with me was friends with his cousin). These are all people I know directly and have ridden in their trucks and been with them when they stopped for fuel. How much better can I know them than that?
I don't live in Texas do I? The prices there mean nothing to me. Just like Vail Pass. I don't live there, so how a truck performs there means nothing to me either. But using your prices that comes out to $747.82 for the 6.0 and $795.87 for my 5.4. So you would save about $48 per oil change interval. Change the oil and we are pretty much even again.
Yeah I can read and what I read was that none of those are your trucks and they are your cousins neighbors. Sounds like a third party to me so yeah its like a friends cousin neighbor type of story. You said you don't believe that other guy who actually drives a 6.0. What makes us believe what you are saying who doesn't even own one. You are going off of another guy who lives next to your cousin and not even you.
And I guess you don't change your oil? So is that how you supposely break even cause not once have you change your oil?
Old Jul 21, 2010 | 05:25 PM
  #6782
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by 2001400ex
When trying to make a point, make it factual. Your 5.4 will not outpull or get better mileage than a stock 6.0.
He never said it would - IN ALL CASES.
Old Jul 21, 2010 | 05:36 PM
  #6783
phillips91's Avatar
phillips91
Apparently you didn't read it. I said my cousin AND my neighbor. NOT MY COUSINS NEIGHBOR. Got it? My cousin, MY neighbor and people that worked WITH ME.
I change my oil, but a 6.0 oil change costs more than mine.
Edit- I just checked Advance auto and the 6.0 oil filter is $19.90. Throw in 15 quarts of oil at $2.20 per quart and that is $52.90 for an oil change. My 5.4 is $25 for the entire oil change. So where I live my 5.4 is about $20 cheaper than the 6.0 and where you live the 6.0 is about $20 cheaper than my 5.4.
Old Jul 21, 2010 | 05:39 PM
  #6784
Lloydable's Avatar
Lloydable
My cousin, next door neighbor and all the service trucks that came to our job sites got between 10-15 mpg's. I trust them more than I trust you. Let's use your numbers though. If a 6.0 gets 18 mpg's and my 5.4 gets 15 mpg's then our total fuel cost for 5,000 miles would be 5,000/18=278 gallons x $2.99 per gallon=$831.22 for the 6.0 and 5,000/15=333 gallons x $2.48 per gallon=$825.84 for my 5.4. You save $6 in fuel per oil change interval(but quickly throw it away and more when you change your oil). So sorry man, I don't care what your mpg's are, when you pay more per gallon it evens out. That's just the truth LOL.
yea other than he is making significantly more power
Old Jul 21, 2010 | 05:46 PM
  #6785
LSchicago2's Avatar
LSchicago2
BS on a stock lightning running low 13's. I have seen alot of lightning at the local quarter mile track when they first came out and the best I saw that ran was like a 13.8 or so.
No BS there, that is what it ran with the Barometric pressure @ 32.2 and about 50 degrees. I've never been to the track with the pressure so high, but that will act like you have a couple more pounds of boost. Optimal times come with optimal air conditions.
Old Jul 21, 2010 | 07:31 PM
  #6786
2001400ex's Avatar
2001400ex
I would pretty much say there is no case that a well running stock 5.4 would outpull a well running stock 6.0, even a fully loaded dually crew cab 6.0 and reg cab sb 5.4.
Now I have never driven a 5.4 but I owned a Chevy 6.0 in the 1500 hd, and even programmed with a cold air intake is not close to my stock psd
I know the chevy 6.0 is a different truck, but it was 300/360 stock (340/400 if u believe claims on the programmer and intake ) and the 5.4 is 300/365. So while not exact, they are close.
Old Jul 21, 2010 | 07:33 PM
  #6787
mountaineer27's Avatar
mountaineer27
glad to see much hasnt changed in here
Old Jul 21, 2010 | 07:47 PM
  #6788
phillips91's Avatar
phillips91
We were comparing mpg's and I was saying that it was just as cheap for me to drive my 5.4 as it is for someone to drive a 6.0 and that just because it gets better mpg's doesn't mean it costs less to drive. Then you replied with the part about there being no way my 5.4 would outpull or get better mpgs than a 6.0. I was only arguing the fact that even though I get worse fuel mileage it doesn't matter because my fuel costs less.
Old Jul 21, 2010 | 08:04 PM
  #6789
2001400ex's Avatar
2001400ex
I have never sat in your truck, but to say you get 14 mpg pulling at elevation (2.5k to 6k) even if only 3.3k pounds, you would get 14, especially averaging over 75 mph. I would say, unloaded you wouldn't get 14. But keep arguing, I chuckle at your posts, especially when you say you can outpull a v10. LOL
Old Jul 21, 2010 | 09:10 PM
  #6790
bill11012's Avatar
bill11012
Modular motor junkie
Your not getting the point of his posts.
His 5.4 has a 5 speed and 4.10s. It can out pull almost all PSDs and V10s of the same age that are handicapped with slushboxes and 3.73s.
He never said that a 5.4 with the same crap trany/gears could beat them, or that he could outpull a well geared V10.
Old Jul 21, 2010 | 09:40 PM
  #6791
kx450frider617's Avatar
kx450frider617
That is like saying my little RC car engine could out pull a PSD if it had 4,500 gears and The PSD had 12. Posts like that are pointless also.
Old Jul 21, 2010 | 10:25 PM
  #6792
2001400ex's Avatar
2001400ex
Bill, for the record, you make me chuckle too. You two are the only reason I stay on this thread. All the evidence that says the v10 or 5.4 is a dog you refute with "that is biased." Then a v10 pulls the same as a psd that smoked at the end, and y'all say the v10 is boss. And all the evidence shows the 6.0 and 6.4 outpull the 3v v10 but y'all still say the v10 is boss, and gets the same mpg as the psd. LOL LOL me laughing all the way. Oh ya, and y'all won't go pull with someone in the area...
Old Jul 22, 2010 | 07:09 AM
  #6793
Jrfish007's Avatar
Jrfish007
Your payload might have been higher, but your truck did not weigh in at over 7k pounds...
The F150 weighed 6,210. My current truck weighs 6,780 lbs. Both had relatively full tanks of gas and just me in the drivers seat. I have lost about 10lb since I got my truck though
I've had both of them on scales when I buy gravel. The super duty weighs, 500, ehh almost 600 lbs more, but my F150 was a supercab and the super duty is a crew cab. A regular cab 4x2 should be weigh close to what my old F150 weighed. At that weight and with more gears in the tranny, there is no reason he should not be able to at least match my mpg.
Old Jul 22, 2010 | 07:21 AM
  #6794
Jrfish007's Avatar
Jrfish007
I love how you claim we don't read, yet after 2 posts you still don't get that he talking about multiple people.
It's just one of those people is his cousin, another one of those people is his neighbor, ect.
Apparently the comment about V10 owners not being able to read, should be fixed to super duty owners... Or perhaps no one here can type
Old Jul 22, 2010 | 08:47 AM
  #6795
Monster-4's Avatar
Monster-4
If you are refering to the test we did my truck is NOT a 3V. It's a 2V with the older 4R100 transmission. Compare it to the 7.3 in that test since they are from the same era with the same transmission and gearing.
