Sponsored by: Real Truck
Gas vs PSD
Old Jul 20, 2010 | 02:04 PM
  #6706
ChargersFanInCO's Avatar
ChargersFanInCO
2009 MY FORD OBD System for 6.4L Diesel Engine
If you read the "General Description" part, the 6.4 engine speed is determined by throttle position. However, when the wastegate closes upping boost, if no throttle position has changed, it will be the same amount of fuel with increases boost as the wastegate closes and the variable vane geometry turbo opens. That's why I see more boost climbing a hill or pulling a load, with the same throttle position. Could I hold it forever, like climbing Vail Pass without giving it more gas? Of course not. However, with small hills, it works out quite nicely and took me a bit to figure out how to drive it compared to a gasser since I was used to increasing the throttle when going up the damn things. I drove it like a gasser for a while and realized I was speeding when I got to the top of a small hill. I have nothing but hills around my house, but not so much when I get out of the mountains going to work.
Old Jul 20, 2010 | 02:08 PM
  #6707
phillips91's Avatar
phillips91
Originally Posted by 2001400ex
Bill you say that with such conviction, but yet, we have not seen an 05 outpull a 6.0...
And Josh, here is the page of your pull:
https://www.ford-trucks.com/forums/9...h-video-8.html
How come both your 5.4 and the v10 in the pulls at the beginning of that thread both start to slow down at a certain point of the hill? My PSD has never done that, no PSD I have even ridden in has done that, and no videos of any PSD on here has done that... I am anxiously awaiting morning so you can post your math to see why that is and yet the v10 and 5.4 will outpull a psd.
You are looking at the pull where I shortshifted at about 2,000 rpm to show how mine could still accelerate because of the gearing advantage. This is the pull where I actually ran it hard. I slow down twice in this video. Once because I am going over road construction(if you listen you will hear my trailer bounce) and then I slow down to go around a turn because two cars are coming at me (one of which is in my lane) and I don't want to be tearing *** up a two lane road with traffic coming. So how about you ask why I slow down instead of assuming it's because it lacks power.
https://www.ford-trucks.com/forums/9...-video-10.html
Old Jul 20, 2010 | 02:11 PM
  #6708
ChargersFanInCO
I understand completely. Everyone knows a 5.4 will outpull both the V10 and the PSD. That thing is a MONSTER!!
Old Jul 20, 2010 | 02:44 PM
  #6709
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by ChargersFanInCO
How many threads relate to the V10 losing the exhaust studs?
Uh, one on that first page (which probably changed by now). And does it HURT the engine? Adding diesel fuel to the oil is not something I'd like to do
Old Jul 20, 2010 | 02:46 PM
  #6710
krewat's Avatar
krewat
Are you sure you're not Phillips91 with some mod tools? You sound just like him when he has new batteries in his calculator...lol
Nice way to avoid actually responding. I am not Phillips91, because, I don't own a PSD - he does
Old Jul 20, 2010 | 02:47 PM
  #6711
krewat's Avatar
krewat
Without a reduction in engine speed, or some other factor, the PCM will not know to close the wastegate. SOMETHING CHANGES. Either your RPM or your foot. Pick one.
Old Jul 20, 2010 | 02:55 PM
  #6712
ChargersFanInCO
Going UP a hill? Neither. The wastegate closes and the vanes go to "Open"
Old Jul 20, 2010 | 02:58 PM
  #6713
ChargersFanInCO
I didn't avoid it. The people who idle while in regen grow oil. I am ALWAYS driving when it happens. 7500 miles for the first oil change, and it put out exactly 15qts +- an ounce... Hell, the manual says not idle when in regen... the ones "growing oil" bought the wrong vehicle for their driving style. The dealership says to go to 10000 now between changes. Since they do the maintenance for free on my truck up to 100000 miles, I'm not going to argue with them.
IF it ever happens when I'm pulling in, I'll put it in park which kills the regen and let it do its thing when I leave next time. I put a lot of miles on mine, and it's why I bought a diesel...which I SWEAR I said when I first came to this thread. 2.7 months, and 7600 miles.
Old Jul 20, 2010 | 03:04 PM
  #6714
ChargersFanInCO
If you lose all of the studs, it will damage the engine as that exhaust manifold falls off and bounces around. Do you really belive a qt or two of diesel fuel will render an engine that hold 15qts of oil bad? You'd "grow oil" too if you didn't burn so much of it.
Old Jul 20, 2010 | 03:21 PM
  #6715
Jrfish007's Avatar
Jrfish007
the RPM's drop, the PCM sees it and compensates by increasing boost. The thing is the RPM's don't drop enough for you to notice, you'll never see a 100 RPM drop. My turbo Saab works the same way, except with gas.
One thing about that article (I admit I didn't read it a word for word, just skimmed it), it kind of seemed like it said you won't use more fuel. That isn't true, what it ment was that the fuel ratio won't change. As you put more boost, you'll add proportional amounts of fuel, but the air to fuel ratio will not change. Not challenging anyone, just clarifying.
Old Jul 20, 2010 | 03:22 PM
  #6716
Jrfish007's Avatar
Jrfish007
I probably have a better chance of hitting the lottery than all my exhaust head studs falling off. And if that happens, I won't care because I'll buy 10 new trucks.
Old Jul 20, 2010 | 03:26 PM
  #6717
ChargersFanInCO
I'm still looking SPECIFICALLY for the one that talks about fuel consumption vs boost for a VVT with Wastegate application....Again, I'm talking about small hills, and 99.9999% of the time I let OFF the pedal (gas, just to irritate Krewat) when the boost comes on as it starts accelerating as the boost builds. I agree boost needs fuel...ONCE the wastegate is closed and the vanes are fully open. Until that point it is burning the same fuel amount and correcting the A/F mixture based on load. that is done through the sensor that tells the PCM what is going on.
Old Jul 20, 2010 | 03:28 PM
  #6718
Lead Head's Avatar
Lead Head
You'd have to try hard for all your exhaust studs to break. Even then its still bolted to the down pipe so the likeliness of it bouncing around is close to nothing.
Do you know what diesel fuel does to oil and bearings? Most engine manufactures say that a maximum of 5% fuel dilution at the end of an oil change interval is acceptable. In a 15 quart oil system, that works out to about 3/4ths of a quart. You had 6.4s that were making 2-3x that.
I'd rather have my exhaust manifold come loose then restroom my internals.
  #6719
ChargersFanInCO
And I have a better chance of hitting the lottery than getting Krewat to realize my truck isn't his Grandfather's Oldsmobile.
Old Jul 20, 2010 | 03:31 PM
  #6720
krewat's Avatar
krewat
Magic, I'm tellin' you. No wonder why you're so in love with that oil-burner
Diesel is NOT GOOD as a lubricant for engine bearings But never mind that.
My V10 doesn't burn oil. It never uses a drop between oil changes. None of my Ford modulars have ever used oil, using Castol GTX dino oil.
It's not irritating me whatsoever, it's just funny that a diesel owner actually says "gas pedal".
