Sponsored by: Real Truck
Gas vs PSD
Old Jul 20, 2010 | 04:17 PM
  #6736
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by ChargersFanInCO
Exactly....If I knew then what you knew now, I would have bought a 5.4 and said "FTW, I've got a 5.4 biatches!"
So you're admitting that you'd chearlead for whatever you're driving right now, just like jac08f250 does?
Like Josh, I won't sit here and say my V10 does everything better than any other motor. It doesn't. But I won't sit still while people say "it'll go on fire", "sit in the truck lane with my flashers on", or a host of other things that are just untrue.
Old Jul 20, 2010 | 04:19 PM
  #6737
ChargersFanInCO's Avatar
ChargersFanInCO
Exactly...don't you WISH you'd bought a 5.4 now? Huh? LOSER!!!
Old Jul 20, 2010 | 04:21 PM
  #6738
ChargersFanInCO
The 5.4 rules the planet, but only in the heavier SD form... 5.4 FTW!!! Now this thread is done...You have reached the end of the internets...right here:
Old Jul 20, 2010 | 04:27 PM
  #6739
phillips91's Avatar
phillips91
It's like comparing my 5.4 to Mike's v10. His truck does not have the best gearing or tranny for getting a load moving (as you saw in the videos). I don't think he would have a problem admitting that my truck did better in that situation because my truck has the better gearing/tranny combo. If I ran into Mike on a hill with us already going 25-30 mph, I have no problem admitting that his truck would smoke mine going up the hill because his poor gearing off the line would not be a factor then and his engine is more powerful than mine. Which truck is "better" depends on the situation.
Old Jul 20, 2010 | 04:29 PM
  #6740
jac08f250's Avatar
jac08f250
Originally Posted by Sand_Man
You also said the ANY OTHER GT would be an easy target, didn't you? You seem to like to modify your posts once you sober up. If you're running mid 13's (which you are not, I promise) then you should have no problem beating pretty much ANY stock GT. Street racing against someone for half a block is what idiots do. The offer still stands: come on out here, pick up one of your loud-mouth buddies along the way and we'll see who's got the goods when it comes to real drag racing. Just think of all the glory! You could be showing pictures and videos to all your diesel buddies about how you whipped a gas-burning Mustang! You'll be legendary! I will even back up your story completely as well! Wouldn't that be worth the drive?
You don't think that my truck can run mid 13's with the stuff in my sig. Do you even know what a diesel is? Here is a guy that has the same stuff done to his truck like I got done to mine except he is running a 310 tune which I also can run if I want to and he went 12.80's. So I think with a 250 tune mid 13's shouldn't be a problem.
  #6741
ChargersFanInCO
I'm not arguing with you...5.4 FTW!!! So much better than...holy crap it's raining here...wish I had video...Houston-style rain....
Old Jul 20, 2010 | 04:32 PM
  #6742
ChargersFanInCO
There, for the record...V10 vs PSD doesn't exist. Nothing comes CLOSE to the 5.4...with proper atmospheric conditions, proper gearing (for the hill you're looking at) proper octane, proper load, and your very own video camera without having me in sight wanting to blow your ****ing doors off you oh-so-badly....
Old Jul 20, 2010 | 04:34 PM
  #6743
Lead Head's Avatar
Lead Head
I'm not worried about growing oil. I'd be worried about burning valves if my Exhaust manifold wasn't properly mounted, not to mention CO poisoning since God knows a gasser doesn't burn all it gets.
So whats that catalytic converter, particulate filter and NOx absorber doing under your truck then?
You're not going to burn an exhaust valve with broken manifold bolts. The engine would likely be fine for the rest of its life too with broken bolts but you'd have to deal with the annoying sound it makes.
Old Jul 20, 2010 | 04:36 PM
  #6744
ChargersFanInCO
It's pussifying your children from the same stuff I was exposed to as a child is what it's doing....tree hugger...lol
Old Jul 20, 2010 | 04:37 PM
  #6745
jac08f250's Avatar
jac08f250
Oh like you v-10 owners don't shake your pom poms for the v-10. Give me a break hitler.
Old Jul 20, 2010 | 04:40 PM
  #6746
Lead Head's Avatar
Lead Head
Guess that explains your posting habits...
Old Jul 20, 2010 | 04:41 PM
  #6747
phillips91's Avatar
phillips91
Nowhere in any of my posts have I said the 5.4 is the best engine on the planet. What I have said is that with the right gearing you can get a 5.4 to out pull a better engine with the wrong gearing. Will a 5.4 with an automatic and 3.73 gear get a load moving as easily as a 7.3 with an automatic and 3.73 gear? Not even close. But will my 5.4 with a manual and 4.10 get a load moving better than a 7.3 with an automatic and 3.73 gear? All day long.
See, I am not like you and think that my truck is an extension of my manhood. I have no problem admitting that your truck would out pull mine.
Old Jul 20, 2010 | 04:42 PM
  #6748
ChargersFanInCO
You're the one who goes by the moniker "Lead Head"...
Old Jul 20, 2010 | 04:44 PM
  #6749
ChargersFanInCO
Nowhere in any of my posts have I said the 5.4 is the best engine on the planet. What I have said is that with the right gearing you can get a 5.4 to out pull a better engine with the wrong gearing. Will a 5.4 with an automatic and 3.73 gear get a load moving as easily as a 7.3 with an automatic and 3.73 gear? Not even close. But will my 5.4 with a manual and 4.10 get a load moving better than a 7.3 with an automatic and 3.73 gear? All day long. Of course you didn't. I declared it the winner.
lol...my manhood? Dude, never mind...that's just FUNNY!
Old Jul 20, 2010 | 04:45 PM
  #6750
ChargersFanInCO
Welcome back!!
