Sponsored by: Real Truck
Gas vs PSD
Old Jul 19, 2010 | 06:03 PM
  #6616
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by 2001400ex
"The 3000 RPM issue was actual designed from Ford in the PCM so this was "working as intended". It only limited the engine from the start until the hill leveled out a bit and then the RPMs came up to redline. After that it was not an issue. (EDIT: Go to about 1:15 in the first video)
It was locking the TC at 3000 RPM due to the time at WOT and acceleration speed. The TC locking killed the V10's acceleration rate. Mike from 5 Star already confirmed this in the base programing. He gave be a tune to compensate for this but I never got a chance to test it yet."
This is was I am talking about, from the OWNER of the truck back on page 437. Sorry man, that is the same thing as a diesel defueling, just a different style.
That's why they shoot up Vail Pass...In the truck lane...with their flashers on. They can't stay at WOT too long.
Old Jul 19, 2010 | 06:08 PM
  #6617
Monster-4's Avatar
Monster-4
This had NOTHING to do with the engine. It is 100% a transmission logic to keep the temps down. I believe the same logic exist for the 7.3/4R100 combo.
Old Jul 19, 2010 | 06:09 PM
  #6618
bill11012's Avatar
bill11012
Modular motor junkie
They can run at WOT just fine, for any amount of time.
  #6619
Monster-4's Avatar
Monster-4
Originally Posted by phillips91
What in the world are you talking about? There was no "safeguard" that kept his truck from going past 3,000 rpms. He didn't have the gearing or the low end power to get the load moving past those rpms.
Correct. This is NOT an engine "safegaurd". It was purely for the transmission and transmission only!
Old Jul 19, 2010 | 06:10 PM
  #6620
ChargersFanInCO
Go watch the videos. When he shifted at around 30 mph it took forever for Tom to call out 35. It went from 0-30 in no time and then it was 31... 32... 33... 34, almost to 35, ok now it's at 35. Could be where he was already in 2nd and around 2,000 rpms while mine was still in the equivalent of his 1st. All I can go by is Tom and Mike calling out the numbers since I can't see the speedometer(passenger filmed theirs). I filmed mine while I was driving, so the speedo is in plain view.
Tom drives a 6.4 doesn't he? Or does he drive someone elses vehicle in the test?
Old Jul 19, 2010 | 06:11 PM
  #6621
ChargersFanInCO
Well then I'll default to my previous statement that goes like this: "They have no *****".
Actually, what you're saying is that they can run at WOT all day...if the transmission says it's ok...
Old Jul 19, 2010 | 06:12 PM
  #6622
Sand_Man's Avatar
Sand_Man
Hasn't a single gasser driven a diesel before?
Although I own a V10 (by choice, not accident) I regularly drive the '09 6.4 F250 regular cab short bed we have at work. While it's certainly a nice truck, it's in no way a match for the 6.7 Cummins in my Dad's '07 Dodge. It actually feels a lot like my V10 except it gets worse mileage. Now the question to you is, ever drive a V10?
Old Jul 19, 2010 | 06:14 PM
  #6623
Monster-4's Avatar
Monster-4
I drove Tom's truck (the white 6.4) and Tom drove my truck (the V10) all four times in the videos.
Old Jul 19, 2010 | 06:15 PM
  #6624
bill11012's Avatar
bill11012
They can run full throttle all day either way.
It just changes the RPM that it runs at.
Old Jul 19, 2010 | 06:16 PM
  #6625
phillips91's Avatar
phillips91
Tom drives a 6.4 but he was in Matt's 6.0 when he was calling out the 31....32.....33....34.... They were testing a 6.0, 7.3, 6.4 and v10 on that day.
  #6626
ChargersFanInCO
Yes, we had several of them as TMP vehicles when I was in the Army
Old Jul 19, 2010 | 06:20 PM
  #6627
Monster-4's Avatar
Monster-4
It's a 4R100 logic only that would effect a diesel the same as gas engine that locks the TC up after certain parameters are meet. I don't think it's a "safeguard" per say. It's simple programing logic. I highly doubt Ford though about starting a 18K+ load out on a 15% grade. They just took some parameters and said this plus that should be "good enough".
Old Jul 19, 2010 | 06:24 PM
  #6628
bill11012's Avatar
bill11012
What year V10?
Old Jul 19, 2010 | 06:37 PM
  #6629
TennesseeMustangPerf's Avatar
My max boost is 40, but I don;t get nowhere near 40psi of boost unless I have something big and heavy tied to the truck. I can floor it all day empty, and it only goes to 20psi of boost. Hasn't a single gasser driven a diesel before?
Actually, that would probably have more to do with the way that the transmission will hold the gearing lower when grunting than when not towing weight. A spike of 3,000RPMs may show say 7 psi. while a sustained 3,000 might show 15. This is due to the turbo pressurizing the engine with boost, which increases up to a point consistently.
Thing is that I have heard about horsepower in the thread about a thousand times, but torque is not discussed. Our 1999 Kubota L3010 only has something like 23hp, but would pull trailers and stumps as much as we could load it down. Torque is much more important in towing than horsepower. Tractor trailers used to have a fairly close gas/diesel ratio, but almost all on the road today are diesels. This change over happened back before diesel was more expensive than gasoline, too.
Old Jul 19, 2010 | 06:47 PM
  #6630
Lead Head's Avatar
Lead Head
Actually, you sort of don't get it. Stock diesels defuel based on several measurements, which includes EGTs on newer diesels. So, WOT on a 15% grade would put down full hp/torque to a point, then when certain levels are reached, would defuel. Hence why so many diesel guys put aftermarket exhausts on. Not to increase power when empty, but to reduce the amount it defuels when towing by keeping EGTs cooler.
That is similar to the v10 that would not go past 3k rpms, a safegaurd to not blow the truck up.
If anything you're saying with more load the Diesels will put out LESS power once the EGTs get up. The computer wasn't limiting the engine speed. It was trying to protect the transmission by locking the torque converter up. A locked up converter generates a lot less heat then an unlocked. I guess Ford was worried that the "wimpy" V10 can burn up the same transmission used behind the 7.3.....
As far as a 6.4 not hitting full boost unless towing/hauling, that is probably the result of the engine programming meant to help improve mileage. It won't fully fuel the engine unless it calculates a heavy load. Older Diesels will happily hit full boost unloaded. So if you don't hit full boost unloaded, that means you are not making your full 350HP either But anyways the difference between hauling 10,000 lbs and 12,000 lbs is not going to make the engine boost any higher.
As far as having a lot of torque, yes that is important for a pleasant towing experience. It means your engine can put out more horsepower at a lower RPM. Less downshifts, etc..You could have a 650 ft-lb engine 15HP engine, lots and lots of torque and can get any load moving but when it comes down to it, it can only do 15HP work of work. Your top speed will be extremely low and going up any hill will require you to downshift until you are barely moving. The same thing with my 12HP IH Cub Cadet. The near infinite ratios of the hydro transmission lets this 700 lb 12HP tractor pull my 3200 lb ranger just barely up to the tractors max speed of 8MPH, and at that speed pulling the truck the engine's governor has the throttle plate on the carb wide open.
Has anyone here actually been in a semi before? I have. I was in one with a trailer full of scrap foam, not exactly a heavy load and even then acceleration was a joke. Even though this engine had well in excess of 1200 lb-ft of torque, its 350-400HP is what ultimately limited its acceleration and top speed. We were going about 60, and I asked my buddy driving if the pedal was to the floor - and he replied with a yes, and that was after we unloaded all the scrap foam too. Any hill meant a downshift or 4 and a dramatic reduction in speed.
