Sponsored by: Real Truck
Gas vs PSD
Old Jun 18, 2010 | 03:37 PM
  #5116
phillips91's Avatar
phillips91
Originally Posted by Jrfish007
But pulling in the field is nothing compared to pulling my 12,000 horse trailer up the WV mountains.
Wow, if you are pulling 12,000 horses that is 18,000,000 lbs of horse if they each weigh 1,500 lbs each. How much does the trailer weigh and how long is it?? Sorry man, I had to
What part of WV do you go through? I think there are only 3 counties there that I haven't been to, so I am pretty familiar with some of the climbs there.
Old Jun 18, 2010 | 03:46 PM
  #5117
mountaineer27's Avatar
mountaineer27
I'm not sure I remember this point, but almost all military applications use JP8, it's much closer to kerosene, similar to jet fuel with a bunch of additives to make it "act" like other fuels. And if you have even seen the stuff you would not want it in your truck. How the grit in that stuff makes past a fuel injector is beyond me. Then again, it's the military, so they can rebuild every 500 hours at our cost, no big deal.
89 octane jet no, but I haven't seen any diesel jets either. Have you seen diesel at cold temps? It gets pretty cold at 30,000 ft above sea level, diesel would be like jello up there. They normally use this stuff called jet fuel, the carbon chain is smaller than diesel to increase the freezing point and prevent gelling. I have seen plenty of gas powered planes though, they use 101 octane leaded aviation fuel.
Read about it here:
Jet fuel - Wikipedia, the free encyclopedia
Check this out:
"Kerosene-type jet fuel (including Jet A and Jet A-1) has a carbon number distribution between about 8 and 16 carbon numbers; wide-cut or naphtha-type jet fuel (including Jet B), between about 5 and 15 carbon numbers."
Remember gasoline is between 6 and 12 carbons long while diesel is 8-21 carbons. jet fuel pretty much lands between gas and diesel with Jet B being more gas like and Jet A being more diesel like, but neither Jet A or B are gas or diesel.
So no, jets don't run on diesel.
Actually they do run on a type of diesel. i know for a fact as i work on the F-22. JP8 is a diesel kerosene mixture much like winter diesel. and you could run it in a regular truck. its used in all the diesel age equipment. (power carts, air conditioners, hydro carts, ect)
the air force just tested bio diesel in an A-10 with no problems too.
Old Jun 18, 2010 | 03:47 PM
  #5118
bill11012's Avatar
bill11012
Modular motor junkie
With a load like that its a good thing he got the V10!
Old Jun 18, 2010 | 03:49 PM
  #5119
Jrfish007's Avatar
Jrfish007
Originally Posted by strokin'_tatsch
it depends on my load on how high my EGTs will get. i can pull 20+lbs in my tow tune if i fix my boost leaks the way things are right now. my future setup should be 600+hp and tow capable with out EGTs ever seeing over 1000*, but that will come with time. with a 66mm single turbo and around 250cc injectors i could tow frequently without seeing high EGT and be close to 600hp. my future setup will include 300cc injectors, 75mm turbo compounded with a mid size procharger. instant power, EGTs will stay in check, and power output could be around 700hp from a very light estimate being limited by fuel. this can be done on a stock engine w/ studs if tuned correctly. there is actually a guy on a different forum with 250cc injectors, procharger w/ a GTP38R turbo that tows daily at high altitude and his EGTs stay down below 1000* and estimated power is close to 600hp.
go turbo your truck, get it running, and see how it tows. add up your receipts and post the number and post the dyno results... In the meantime my junk with 313k miles will outpull yours and get better mileage. i currently get 22mpg empty and around 15 towing..
When it comes to boosting, I'm not sure either. I know I've heard of a few supercharded V10's that put some wicked numbers down, but haven't heard of turbo V10's. The V10's have basically the same internals as the 5.4, and that can take some boost, so I don't think it would be to bad. PSD are far better for moding and will be cheaper to make gobs of power from and probably be more reilable. You can bet that boost on the V10 won't help your mpg either.
In the end though, making more power won't allow you to tow/haul more, agian I come back to the point I'm not interested in it. unless I hit the lotto for a few million, then I can afford to find out
Old Jun 18, 2010 | 03:52 PM
  #5120
Jrfish007's Avatar
Jrfish007
I know JP8 is used in diesels, I wouldn't want in anything I owned though.
what exactly is "type" of diesel. I mean when you break it down both diesel and gas are just hydrocarbon chains. You can call gasoline a "type" of diesel if you wanted to.
Point is, the stuff you go to the gas station and put in your truck is not what they are running jets on like he claimed.
Old Jun 18, 2010 | 03:55 PM
  #5121
mountaineer27
the two turbo'ed. i wonder what is better?
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/HvVtWDiJC6M&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HvVtWDiJC6M&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
******** width="640" height="385"><param name="movie" value="http://www.youtube.com/v/G7oObDUkY-A&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/G7oObDUkY-A&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed>*********>
Old Jun 18, 2010 | 04:07 PM
  #5122
dkf's Avatar
dkf
340+ pages of arguement... this thread has no purpose.
It has proven that you know next to nothing about gassers but you still think they are worthless. Unfortunatly this is how a lot of diesel purists are.
I'm not saying the V10 is the greatest nor the PSD is the greatest, each has there own application. If your going to bash one or the other just try base it on facts not pure speculation.
Old Jun 18, 2010 | 04:08 PM
  #5123
Jrfish007's Avatar
Jrfish007
I live in Mon county and generally take the horse over to Preston for trail riding. But I will some times go south where the real hills are and go to Knoxville or Charlotte. Even went to Florida once with it, but decided to leave the horse home and just fly after that, spent to much in fuel (that trip was with a 7.3 too)
You probably know the are better than I do then lol I just moved here in August for a job. Lived in Ohio before this.
Old Jun 18, 2010 | 04:12 PM
  #5124
jac08f250's Avatar
jac08f250
Originally Posted by dkf
It has proven that you know nothing about gassers but you still think they are worthless. Unfortunatly this is how a lot of diesel purists are.
I owned a 08 f-250 5.4 and I know it's nothing compare to my 2010 6.4L. I get better mpg out of the psd, it's faster then my gasser, and my psd has less gears. The only thing I liked about the gasser was when I got rid of it.
Old Jun 18, 2010 | 04:15 PM
  #5125
Jrfish007's Avatar
Jrfish007
Originally Posted by bill11012
1 tons running 60K gross is not all that uncommon in farm country. 7,000 in the bed of a DRW 1 tons nothing. In a SRW its over the tires weight rating, but you can do it. Theres a mod in the IDI forum thats had over 12,000 in the bed of his SRW 1 ton.
You can do it, but I don't htink he pulling down the road at 70 mph like that. Ever since I bent the frame on my chevy doing that, I've been pretty careful about that. I also only bought Ford after that too.
The real reason I say that he was using a medium duty truck is because he said Cummins. So that means he either had a medium or heavy duty truck or he was using one of those D-things.
Old Jun 18, 2010 | 04:18 PM
  #5126
Jrfish007's Avatar
Jrfish007
your PSD has less gears? Both of those truck have the same transmission.
Old Jun 18, 2010 | 04:20 PM
  #5127
jac08f250's Avatar
jac08f250
my 5.4 had 3.73's and my psd has 3.55's and the diesel feels alot faster.
Old Jun 18, 2010 | 04:21 PM
  #5128
Jrfish007's Avatar
Jrfish007
ahhh... Well, you PSD is probably faster than a V10 too and certainly gets better mpg.
Old Jun 18, 2010 | 04:24 PM
  #5129
dkf's Avatar
dkf
YouTube - My Turbo V10 Excursion doing a Big smokey burnout.
The guy who owns this Ex is a member of FTE. Heres the thread. Excursion - King of SUVs - Ford Truck Enthusiasts Forums
Old Jun 18, 2010 | 04:40 PM
  #5130
Rush117's Avatar
Rush117
11,000' is why your 6.0 can out pull a 3V V10 up that pass. A N/A engine drops 3% of its HP every 1,000'.
At normal elevations, look at the math Josh did.
You can expect a 3 to 5% loss of performance per 1,000 feet of elevation depending on atmospheric conditions such as temperature, and barometric pressure. So at 11,000 feet, a 3v V10 has anywhere from 162 to 243 hp. Ouch!! Who knows what the performance loss of a psd is. It depends on the excess capacity of the turbo at sea level. I'd really like to know. From experience, I'd guess that a performance drop isn't noticeable until about 10,000 feet.
So tell me, Bill, what is "normal elevation"? Being that I live at about 8,000 feet most of the year, anything below 6,000 is low country and if you're below 4,000, you might as well be on the sea floor. Can I equate "normal elevation" to average elevation? Did you know that the average elevation of the United States is about 2,500 feet? So on the average US road, a 3v V10 has anywhere from 307 to 334 hp, about equivalent to a 6.0.
My point here is not to say that the V10 sucks. What I am saying is that making a blanket statement that a V10 can pull harder on the same hill with the same load is not necessarily the case. Being that the 3v V10 has a roughly 3% edge on the 6.4 in terms of hp means that once you hit 1,000 feet of elevation, they are equal. Above that and the advantage goes to the 6.4. The majority of the US, by a wide margin, is above 1,000 feet. Good use of a calculator can give you a basic idea of performance under very controlled conditions. In the real world, those numbers can be vastly different. There may be other factors that would give the edge back to the V10. If you know of any, I'm all ears.
