Sponsored by: Real Truck
Gas vs PSD
Old Jul 20, 2010 | 07:00 AM
  #6676
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by Krewat
You seem to be speaking for a lot of people that aren't even here anymore. You and ChargersFan. Two.
Present the facts. Find a V10 with the same load, time it, video it, document it, and present it as evidence.
I've already invited any of you gassers to meet me at the base of Vail Pass, and I'll video your V10 vs my PSD. I'll just have to figure out a way to clip my camera to my rear-view mirror to video you. Or on the rear bumper.
Old Jul 20, 2010 | 07:06 AM
  #6677
ChargersFanInCO
During acceleration, if the engine doesn't spin up fast enough, the turbo pushes more air in, the PCM adds more fuel, and the result? More boost.
It's not some magic "more weight, more boost". It's a result of your application of the go-pedal, versus how fast the engine spools.
Diesel injection timing, versus fuel flow, means more boost.
Wrong. If the engine "doesn't spin up fast enough" how is the turbo going to force in more air? the turbo needs the exhaust gas to spin up the impeller. Mine uses a wastegate and if I'm not needing the boost to pull a ****-ton of weight, it dumps it off, at the same RPM, and same pedal position. You DON'T know how a turbo works; at least on the newer vehicles. My vehicle WILL produce more boost at the same RPM if needed, and others have said the same thing on here.
Old Jul 20, 2010 | 07:30 AM
  #6678
Jrfish007's Avatar
Jrfish007
Originally Posted by jac08f250
Well so far all the people who have quoted me and said something about what I said and took it a different and clearly didn't read what I post were all gassers.
Come on!!! That's part of the fun
  #6679
ChargersFanInCO
Originally Posted by Lead Head
As far as a 6.4 not hitting full boost unless towing/hauling, that is probably the result of the engine programming meant to help improve mileage. It won't fully fuel the engine unless it calculates a heavy load. Older Diesels will happily hit full boost unloaded. So if you don't hit full boost unloaded, that means you are not making your full 350HP either But anyways the difference between hauling 10,000 lbs and 12,000 lbs is not going to make the engine boost any higher.
Read the link I posted dealing with hp/torque. I don't NEED the full 350hp at the start because of the amount of torque I produce. That 350hp comes into play when I'm doing 55mph+. HP is all a gasser has (ok, 400lb/ft of torque, which is close to what the new Mustang has) but they have to have the hp or they can't KEEP the load moving. that's why they run in the higher RPM's while doing so. It's like the article says...You can have all the hp in the world, but without torque, you're not going to get the load moving in the first place. It also says because the diesel moves loads with such ease at a lower RPM, it's much easier on the engine and makes it last longer...another point of contention on here.
Hey, at least the gassers can say "I make as much torque as a new Mustang does"...lol
Old Jul 20, 2010 | 07:45 AM
  #6680
Jrfish007's Avatar
Jrfish007
457 lb-ft for the 3V V10, 80% of which is available at 1500 RPM. The Mustang wishes it could do that.
Engine torque versus engine HP is a pointless debate because the truck will convert the power to what ever is needed through the transmission and rear end gearing. If you're taking off with a stupid heavy load with a gasser, the RPM's will build in 1st gear building engine Hp which will go through the tranny and a tall rear end to be converted to torque for the tires.
A diesel has plenty of torque, so it works the other way around. It uses a shorter rear end to produce more HP at higher speeds when it needs it.
This is why it is pointless to debate these engines with the same rear ends, they have different needs from their rear ends. And while I could go many places with that statement, I'll leave it alone lol
Old Jul 20, 2010 | 07:53 AM
  #6681
ChargersFanInCO
?? The PSD's have a taller read end than the gassers. 3.31 or 3.55 for the 09's and 10's...
Old Jul 20, 2010 | 07:59 AM
  #6682
Jrfish007's Avatar
Jrfish007
LMAO... it's to early in the morning. I confused the numbers with the actual gears. By taller I ment bigger number.
So my post should have been gassers need smaller rear ends to convert the high RPM HP into torque at low speeds and diesels need bigger rear ends to convert the low RPM torque into HP at higher speeds.
Good catch lol
Old Jul 20, 2010 | 09:16 AM
  #6683
LSchicago2's Avatar
LSchicago2
Finally, someone gets it. The V10 is for someone who tows once in a while and doesn't drive very far otherwise. It won't tow as easily as a PSD, it won't get as good of mpg either, but it can do it when called upon to do so. Yes I would have liked the 6.4, but I just wasn't willing to cough up the cash, not with my starving 401k and a new baby at home.
Yes, most PSD owners bought that engine as overkill, which is fine. If they want to do that it is fine. Take Jac08 for instance, he has even more power from his 6.4, which is probably WAY overkill. But if he wants to do that, it's fine with me. I have no right to say he wasted his money or made a bad decision, it's his money and his truck and he can do whatever he wants with it; all I can do is say I wouldn't have gone that path. Personally I didn't even know that engine was capably of so much power with just a tune, he showed me other wise. I'm not into tuning the engine, so it really doesn't effect me or my purchase though, still interesting.
BTW: I towed a 10k trailer with an F150, it was a supercab, long bed, with a 5.4L and 4.10 rear end (high payload package). It was okay, definitely was not good on the hills though, but I also had a 4 speed tranny. It definitely wasn't the ideal setup. My friend has the 3V 4.6L with the 6 speed and a 3.55 rear end and would have blown my 5.4L out of the water empty.
The V10 is bought by people who tow all day everyday too. There is a huge movement to V10's in the tow truck industry, because we are all tired of the 6.0 and 6.4 problems. Taking your new diesel to the dealer 6-8 times a year is not very productive. I bought my used 03 F450 V10 with 123K on it because it was very cheap. 3 years old for $20,000. It was so reliable, that I decided to trade my 05 f450 6.0 for a new V10. That was not to save money, it was to have a truck than can work all day everyday. It uses more fuel in the City than my 6.0, but highway mileage is close to the same. My 03 V10 gets better mileage than the 09 V10. In fact, my 03 gets the same highway mileage as my 2000 7.3 got with the same gears, and better than my 6.0 got on the highway. City is mpg is worse, way to much stop & go and bumper to bumper in Chicago. I'd rather spend a little more on fuel, and not have my truck in the dealer constantly. The $100 deductibles I save makes up for most of that! Cheaper maintenance makes up for the rest. My local Ford dealer only has 1 diesel mechanic, and about 15 gas mechanics. Diesels are always a week wait or more, My friend the service writer told me if I have a problem with my V10 they can usually look it it the same day. I asked him why they don't get another diesel mechanic? He told me they don't want anymore diesel work, that it's mostly lower paying warranty work anyway! I enjoyed driving diesels, I just hated them being in the shop. I trusted my 5 year old V10 more than my 2 year old diesel on the long trips. V10's just make more sense in my industry right now. I could care less about MPG or max torque, I just need the job done.
Old Jul 20, 2010 | 09:26 AM
  #6684
Jrfish007's Avatar
Jrfish007
I wouldn't argue that the V10 can't tow. I'm just saying the V10 can't tow as easily as the PSD. I'm not getting into reliability, because everyone will start saying their uncle's father's aunt's brother-in-law had a 6.0 with 400000000 miles and no problems, all of which means nothing to me. Fact is they were less reliable than the V10.
This was pretty much my philosophy when I bought my truck. As long as it has the power to do what I need it to, that is all the power I need. Sure I can get more with the PSD, but do I need it? Nope.
Old Jul 20, 2010 | 09:30 AM
  #6685
Johnny Langton's Avatar
Johnny Langton
This is EXACTLY why I did not buy a diesel when I purchased my truck. I tried to like the 6.0L, I REALLY did. I DO like the turbocharger and empty fuel economy. I DO NOT, however, like the horrid experience I have seen far too many friends go through with that engine. If the new 6.7L proves itself to be reliable and trouble free-I might own one in the future. BUT, it's gonna have to prove itself first-something the V10's all have done. I know for a fact that I can jump in either of my V10 powered vehicles with 9000+lbs of trailer in tow and travel wherever I want in this country and get there and back without an obscenely expensive repair on the road away from home. With a 6.0L, that's not certain-past experience has proven that. The 6.4L in my experience gets the SAME fuel economy as both of my V10 vehicles. This isn't just one truck I'm talking about-it's DOZENS of 6.4L trucks owned by co-workers and friends that have varied in model year ('08-'10), and various trim levels-XL, XLT, Larit, etc. I also refuse to own a vehicle that cannot have a major repair done without cab removal. I don't write checks-I work on my own vehicles,and this is unacceptable. The claims that "there's a cab-on repair procedure for everything" is a BS copout by those check writers that need to justify their purchase by parroting the service writers. Ford doesn't do anything in-cab, and for a good reason-you cannot do a proper repair without good access to the engine. Working blind is a recipe for a repeat repairs.
JL
Old Jul 20, 2010 | 09:33 AM
  #6686
ChargersFanInCO
Actually, it's more like my wife's cousin's, best friends, uncle who bought a dog from some random guy on the street heard about someone who knew someone who had a diesel that was nothing but problems. The 08's had some problems, but I don't see many 09's or 10's with drama. I read more about issues with the V10 (yes, it spans several years) than the 09's and 10's as a matter of fact. The 08's had radiator issues, which all traced back to the degas bottle...also had some EGR cooler issues, which also went back to the bottle. Show me a systemic problem with the 09, 6.4. You can't. I can't show you one with the V10 either.
Diesel, FTW!
Old Jul 20, 2010 | 09:36 AM
  #6687
ChargersFanInCO
Oh yeah, and if the PSD's are made at a ratio of 7:1 (Krewat claimed it, not me) to the V10, then why do the V10 threads have so many issues?
Old Jul 20, 2010 | 09:43 AM
  #6688
Jrfish007's Avatar
Jrfish007
Diesel, FTW!
lol, I like the dog, that's a good touch.
Yes, I have seen people that have had fine PSD's of all makes and years and people with problems from all makes and years; same for the V10.
I'm just saying the probability of walking on to a lot, and finding a new V10 that will operate for 100k miles without a problem is better than finding a new 6.4 PSD that will operate without a problem for 100k miles. They both exist, it's just a matter of which will be easier to find; both of which will be very hard to find soon since these engines aren't being put in pickups any more... making this whole thing a rather moot point.
Old Jul 20, 2010 | 09:51 AM
  #6689
ChargersFanInCO
I think the odds are very good unless someone buys a diesel to drive to the local grocery store...2 blocks away...4 times a week. If it's highway miles like mine, (I'm looking at 100k in 4-5 years) it'll go a lot further than 100k...Then we can factor in costs as I already have, and it's cheaper in the long run to own the diesel based on MY type of use.
Old Jul 20, 2010 | 10:01 AM
  #6690
2001400ex's Avatar
2001400ex
Originally Posted by bill11012
What year V10? sounds like you are talking about a 99....
The 05 was the first year that will out pull a 6.0.
Originally Posted by 2001400ex
Bill you say that with such conviction, but yet, we have not seen an 05 outpull a 6.0...
And Josh, here is the page of your pull:
https://www.ford-trucks.com/forums/9...h-video-8.html
How come both your 5.4 and the v10 in the pulls at the beginning of that thread both start to slow down at a certain point of the hill? My PSD has never done that, no PSD I have even ridden in has done that, and no videos of any PSD on here has done that... I am anxiously awaiting morning so you can post your math to see why that is and yet the v10 and 5.4 will outpull a psd.
This got buried quickly, bringing it back up so Josh and Bill can respond...
