Sponsored by: Real Truck
Gas vs PSD
Old Jul 19, 2010 | 03:57 PM
  #6586
2001400ex's Avatar
2001400ex
Originally Posted by TennesseeMustangPerf
Just to toss this out there, a turbocharger operates off of engine speed, not necessarily pedal distance or towing needs. The turbocharger spins off of the exhaust gasses exiting the engine, true that the harder you press the pedal the more a turbo will generate boost since the RPMs will increase, but it is a direct relationship to the amount of exhaust the truck puts out which is in turn in direct relation to the RPMs of the truck. You can generate more boost by flowing more air VIA less restrictive exhaust and intake, head work, etc., or by changing the setting on the bypass valve to adjust when the excess boost is blown off (aftermarket turbos, stock PSDs don't have these valves), but in the end the compressor is only able to produce it's max air flow pressure. Ultimately, the boost levels are directly associated to the engine speed, and therefore is limited to the flow of the compressor and the speed of the engine. Just my $.02.
I think some gassers who have never driven a diesel don't know how this works. The point is, when I am unloaded at 65 mph, my boost is 5psi on flat ground. With my toy hauler attached, it is at 18psi or so. Same rpms, engine speed, and amount of air.
So, yes weight is a factor.
  #6587
jac08f250's Avatar
jac08f250
Originally Posted by Johnny Langton
I figured it out guys...
You just can't fix stupid.
No matter how many facts and how much data is presented,they just choose to be stupid.
First my "Gasser tune" can't make any more power according to him, then, he's acting as if my tune make it some HUGE advantage over a 6.4L truck. Which is it? Whatever's convenient to be a ***** at the time?
JL
I figured that out a long time ago about you gassers. You even admit that you guys have to bring facts and data in here to try to convince us that a v-10 can hang with a diesel. Us diesel guys don't have to present anything cause we know the truth. The diesel is the better option for heavy towing. But if it makes you feel better and sleep at night continue with your so call facts and opinion but we all know the truth.
Old Jul 19, 2010 | 03:59 PM
  #6588
bill11012's Avatar
bill11012
Modular motor junkie
So your telling me that if he was towing 2K more, he would have beeing putting down more HP?
Fine. Give use proof that your less powerfull engine can tow as fast as us.
  #6589
jac08f250's Avatar
jac08f250
Also here in the Dallas area I see ALOT more diesel hauling and towing stuff then I do gas super duty's. Hmmmmm......I wonder why? The only gas engine super duty's I see around here are older ones that they always have a empty bed. Probably cause they don't like the 6-8 mpg you get when towing.
Old Jul 19, 2010 | 04:05 PM
  #6590
jac08f250's Avatar
jac08f250
Oh my god LMMFAO my less powerful engine. Man your engine only dreams of what my engine makes. I would do circles around your truck if we ever towed or race each other. LMAO
  #6591
ChargersFanInCO's Avatar
ChargersFanInCO
Yes, he would produce more hp with 2k more towing or in the bed of the truck. Cruising down the road, the engine isn;t producing anywhere NEAR max hp or torque. Give it more gas (just to give Krewat a stroke) and the boost rises, hp and torque does too.
Old Jul 19, 2010 | 04:07 PM
  #6592
ChargersFanInCO
Watch the videos a couple of pages back...
Old Jul 19, 2010 | 04:08 PM
  #6593
bill11012's Avatar
bill11012
Your truck stock made less power than a stock 3V V10.
  #6594
Lead Head's Avatar
Lead Head
No. That is because you don't realize just how much further you are shoving that accelerator pedal down to maintain speed. The further you press down the pedal, the more fuel you inject, the the greater the exhaust volume and the greater the boost.
You would see the same thing with a V10 (except it would be vacuum not boost) Unloaded 65mph down the highway you might see 15mmHg (just made up numbers here) of vacuum, towing a trailer you might see 3 mmHg of vacuum.
If your max boost is 30 PSI, and you go wide open 30 PSI is all you are going to get. As soon as you hit 30 PSI, that is basically indicating your engine is at full load. It doesn't matter if you have 15 or 15,000 lbs behind you, that is all your engine has to give.
Your sort of get it, except in that 6.4 acceleration video he was to the floor, wide open, pedal to the metal. There is no more throttle to give. That is all the engine has to offer no matter how much weight is behind him.
Old Jul 19, 2010 | 04:09 PM
  #6595
ChargersFanInCO
Yet it's sooo much faster and gets better mileage...why is that?
Old Jul 19, 2010 | 04:11 PM
  #6596
bill11012's Avatar
bill11012
That just proves that the 6.4 pulls better than the older V10s.
I am talking about the 3V, which was not in that test.
So at WOT with 19,000 he is making less power than WOT with 21,000.
Old Jul 19, 2010 | 04:13 PM
  #6597
jac08f250's Avatar
jac08f250
Not to the rear wheels it didn't. Only on paper it did.
Old Jul 19, 2010 | 04:16 PM
  #6598
ChargersFanInCO
And there will never be a video of the 3V V10 towing against a 6.4 because you're all too scared to go up against one.
Old Jul 19, 2010 | 04:17 PM
  #6599
bill11012's Avatar
bill11012
It makes more at the flywheel and at the wheels.
How would the same tranny and axle in both trucks take more power from one than the other?
Old Jul 19, 2010 | 04:18 PM
  #6600
bill11012's Avatar
bill11012
I would love to. I just don't have a 3V V10.
