Sponsored by: Real Truck
Gas vs PSD
Old Jul 10, 2010 | 01:46 AM
  #6001
Lead Head's Avatar
Lead Head
Originally Posted by phillips91
That's my point exactly. Ford could have used any engine they wanted to in their motorhomes and they chose the v10. They could have used any engine they wanted to in the 650/750 and they chose a cummins, cat and v10 over the 6.0/6.4. That would be like Chevy using the duramax in their silverado but using a cummins or psd in their topkick. Or isuzu having a joint venture with sterling and putting a cat engine in it.
The 6.4 is a very competent engine - and for Navistar's own use has made it 2010 emissions compliant. So emissions is not the reason why its not being used (or the reason why Ford is replacing it with the 6.7) Ford got burned bad by the 6.0 and its warranty claims so now they want nothing to do with Navistar engines anymore. The 6.4 was pretty much a stop-gap until the 6.7 was ready.
Also, GMC has Isuzu engines available in their Topkick series.
Old Jul 10, 2010 | 08:58 AM
  #6002
LSchicago2's Avatar
LSchicago2
Towing companies are having a tough time with their 6.4's. Probably the worst thing, is that they are still repeatedly blowing radiators. one guy just spent $1,993 on a new radiator from ford (installed) Many companies who are loyal to Ford are switching to V10's (me included) to avoid all the problems with these engines (6.0/6.4). Just wait until you until start seeing emmision problems out of warranty on these 6.4's. Hold onto your wallets. Ford has noticed the shift to V10's in the cab chassis market. They will sell a bunch of F650's with the V10 gassers. Why would Ford want to use any IH engine in a 650 after all the problems they had with IH? They wanted out of IH engines, period. The last good PSD was the 7.3. The 6.7 shows potential, we'll see in a few years.
PS. SOME GREAT READING HERE: Here is a 6.4/V10 topic on the leading tow truck forum: http://tow411.yuku.com/topic/86137 Read through the Ford forum if you want to read about 6.0/6.4 problems. You won't find much there bad about V10's though.
Old Jul 10, 2010 | 09:15 AM
  #6003
Tom's Avatar
Tom
Why don't you come down to THIS THREAD? You'll find a few "good" 6.4L PSDs there.
I met a guy last weekend at a 4th of July party with an '06 F350 with the 6.0L PSD. When asked he told me that he had over 100,000 miles on it with NO problems to speak of. He couldn't be happier with it. I would argue that he had a GOOD 6.0L.
If I had your bad experience with the 6.0 I may share your opinion. But to state that they are all junk because some have bad luck with them is a bit presumptive. I've met LOTS of people who have had great luck with their 6.0/6.4L trucks.
Old Jul 10, 2010 | 09:19 AM
  #6004
phillips91's Avatar
phillips91
That's what I was saying. GM uses the Isuzu duramax in their light duty trucks and they also use the Isuzu duramax in their medium duty trucks. That shows me that they have enough faith in their light duty engine to use it in their medium duty trucks. They also use Allison transmissions in both their light duty and medium duty trucks.
Old Jul 10, 2010 | 09:25 AM
  #6005
LSchicago2's Avatar
LSchicago2
Chevy/GMC No longer have medium duty trucks. They abandoned that market a year ago. 2009 was the last model year. You can only buy up to a 3500 now.
Old Jul 10, 2010 | 09:29 AM
  #6006
phillips91's Avatar
phillips91
True. But while they were being made did they not use the duramax and allison combo? That is the point I am trying to make. Chevy and Isuzu trusted their light duty combo enough to use it in their medium duty. Ford and Navi do not.
Old Jul 10, 2010 | 09:47 AM
  #6007
LSchicago2's Avatar
LSchicago2
The only one (on the forum you posted) over 50,000 miles with out trouble admits going through radiators every 35K. $2,000 radiator every 35,000 miles? no thanks. These are pickups, quite a bit different from trucks used in my industry. Most guys on the towing forum drive pretty sane, but the trucks are still pushed every day. Just wait until the average 6.4 has over 100K miles I think that thread will be different. The tow truck industry's trucks are used very hard. The tread I posted represents my industry's change to V10's from the 6.4. One guy has been at the dealer 21 times for in engine problems in 55,000 miles. That reminds me of my 6.0. There will be good and bad trucks for every variation made. It no longer makes sense for many in my industry to stay with diesels in the Fords. I'm not picking a fight, just giving my viewpoint.
Old Jul 10, 2010 | 09:53 AM
  #6008
LSchicago2's Avatar
LSchicago2
That is right, but Chevy used a different Duramax in the class 6-7 (true medium duty class) that is the 7.8 liter in line 6 diesel built in Japan. Ford and Navistar have used the v8 diesels the the medium dutys, Ford used the 7.3 and 6.0, Nav used the 7.3, 6.0 and 6.4. Ford will no longer install an IH engine for obvious reasons.
Old Jul 10, 2010 | 09:59 AM
  #6009
phillips91's Avatar
phillips91
The 7.8 is still made by Isuzu and ist still a duramax though. Same maker, same brand. It just doesn't look good when Ford uses a Navi engine and Ford tranny in their light duty trucks and Ford joint ventures with Navi and puts a cummins and allison in their medium duty trucks.
Old Jul 10, 2010 | 10:37 AM
  #6010
Lead Head's Avatar
Lead Head
I don't think it really matters honestly. The PowerStroke has a hurt reputation right now - no medium duty buyer is going to want it, and Ford is trying to distance itself as far as they can from Navistar engines.
And actually the Isuzu Straight 6 used in the Class 6/7 Topkicks is not branded as a Duramax. Its branded as an Isuzu 6H (which as mentioned is made in Japan, vs. America for the Duramax V8) and you can only have the Allison 2xxx and 3xxx series transmissions behind it. The Allison 2xxx and 3xxx are entirely different beasts compared to the Allison 1000 used behind the Duramax V8. The Allison 1000 is like an econo-car transmission strength wise compared to the Allison 2xxx and 3xxx.
So I'll ask you this, Why doesn't GM use the same engine in the light duty trucks as their medium duty class 6/7? Certainly looks bad for them..
Old Jul 10, 2010 | 10:43 AM
  #6011
LSchicago2's Avatar
LSchicago2
Ford has always used the Cummins in the class 6-7's. Due to Dodge's contract with Cummins, they can't install them in the Class 2-5 trucks, or I'm sure they would've. Ford phased out IH motors in the 6-7 trucks first, then the 2-5 series trucks. Ford doesn't install IH engines in anything anymore. Nothing weird, they just don't want to use IH engines anymore, and I don't blame them! I won't buy another IH engine. I would expect the Ford built 6.7 PSD in the 650/750 in a year or two.
Old Jul 10, 2010 | 10:57 AM
  #6012
Tom's Avatar
Tom
Remember that I've been on the V10 side of things ever since this thread got started. I agree with you about the merits of the V10 and the greater overall reliability as well as it's capability of moving large amounts of weight.
And as I've stated dozens of times in this thread that I was looking for a V10 when I bought this truck, for the same reasons you bought yours.
I was just attempting to point out the majority of 6.0 and 6.4L owners are perfectly happy with their trucks. This is why I strongly disagree with the notion that the 6.0/6.4L engines are bad engines.
Old Jul 10, 2010 | 11:50 AM
  #6013
phillips91's Avatar
phillips91
You are still missing my point. GM uses an Isuzu engine and Allison tranny in their light duty trucks and they used an Isuzu engine and Allison tranny in their medium duty trucks. That means they must trust those brands pretty good. Ford uses a Navi engine in their light duty trucks but a Cummins, Cat and V10 in the medium duty trucks. That tells me Ford thinks the Cummins 6.7, Cat and V10 engines are all better than anything Navi makes. That's not too big of an edorsement for the 6.0 or 6.4 if you ask me. There isn't a better endorsement out there for a product than for your competitor to use it instead of their own.
And why wouldn't you blame them? Because you said they are junk. My point exactly. Ford didn't trust them enough to use them in the medium duty truck(or motorhome), so why should I trust one to sit in my driveway?
Old Jul 10, 2010 | 12:13 PM
  #6014
Lead Head's Avatar
Lead Head
The 6.4 is not Ford's motor, its Navistar's. It is not that Ford doesn't trust it - its that they don't want it. They want nothing to do with Navistar motors anymore because of an ongoing lawsuit over 6.0 warranty claim issues (basically Navistar did not want to pay for 6.0 Warranty work). Ford used to use the 6.0 in the 6/7 trucks until the 2007 emissions year and the PSD was dropped with the 6.4. The 6.4 began the winding down of Ford's use of Navistar engines, they started with the medium duty's because they already had other engine options available. Like I said, the 6.4 in the light duties was basically a stop gap until Ford's own 6.7 was ready and I'm guessing within a year or two you'll see the 6.7 show up in their 6/7 series trucks.
My point about Chevy is that the Isuzu Diesel and the Allison used in their 6/7 series trucks are true medium duty components. So they obviously don't trust their light duty Duramax V8 and Allison 1000 transmissions to be used in their medium duty trucks.
Old Jul 10, 2010 | 12:32 PM
  #6015
phillips91's Avatar
phillips91
I know the 6.4 isn't Ford's engine, but they used it in their light duty trucks, so it would make sense for them to have used it (or another Navi engine like the dt 466) in their medium duty trucks until they stopped using Navi all together. When Ford quit using the 6.0 in the 6/7 series trucks and then said they didn't want to use the 6.4 because Navi engines were junk, what does that say about their light duty trucks that were still going to come with a Navi engine for the next 3 years?
When the 6.0 was on its way out Ford brought a lawsuit against Navi, quit using their engines in the medium duty trucks and then said they were going to make their own psd when their contract with Navi ran out(because of poor quality), that's not giving me a reason to jump up and go buy the new 6.4 when it came out.
