Sponsored by: Real Truck
Gas vs PSD
Old Jul 7, 2010 | 10:31 AM
  #5926
Jrfish007's Avatar
Jrfish007
Originally Posted by Crazy001
Yeah, that makes perfect sense to me.
But unless I'm badly mistaken, neither the 2v or 3V engines have this aggressive cam you refer to. Isn't an "aggressive" cam one which provides more power in the upper RPM ranges which causes low RPM performance to be abysmal?
I always figured one benefit of having more cylinders per unit of displacement would allow the engine to rev higher due to the lighter mass of the individual rotating components. Again, not directly applicable to the V10s, as they aren't high-revving motors.
To be honest, I've never looked at the cam timing on the engines. I do know they have specific cams they sell (in the aftermarket category) that are designed for towing, they help shift the power band down and create more torque. Now if the more cylinder thing helps or not with those types of cams, I'm not sure.
However, as I mentioned, the smaller cylinder helps with complete combustion. This helps with emissions on gas engines; again, I'm not sure if that was a factor when Ford built the V10 or not, I know it was when Dodge decided to go with their V10 8.0L in the Ram though.
Old Jul 7, 2010 | 10:36 AM
  #5927
Jrfish007's Avatar
Jrfish007
Originally Posted by mountaineer27
well a v8 is the least efficiant engine built. its fights gravity. now a inline 6 is a more econimical engine. to bad they dont make them anymore in light cars and trucks. so i wouldnt imagine a v10 is better. it would be worse. you may make more power because you have two extra cylinders but that doesnt make it better.
In general the more cylinder per a bank, the better the efficiency. Think of a V8 as 2 I4's, I4's are noisy little engines. I5's are better and I6's some of the smoothest engines around (see BMW). Also see most super high end luxury cars have V12's (Benz S600, BMW 760, old Jag XJ12 ect.) V10 will be better than a V8, not as good as a V12; but, I'm not so sure Ford took advantage of that, it was probably just more economical to slap and extra 2 cylinder on the 5.4 V8 than redisng the entire engine.
Old Jul 7, 2010 | 10:39 AM
  #5928
Jrfish007's Avatar
Jrfish007
the front and rear trio of cylinders are mirror images. creates a perfect balance.
a inline creates less torsion stress than a v8. thats why there perfered in large trucks. cant fight you on the room issue though
in the words of wiki "Because it is a fully balanced configuration, the straight-six can be scaled up to very large sizes for heavy truck, industrial and marine use, such as the 16 L (980 cu in) Volvo diesel engine and the 15 L Cummins ISX used in heavy vehicles.[4] The largest are used to power ships, and use fuel oil."
Interesting. I always assumed they built I6 because it was economical to build, but I guess there is that aspect too.
Old Jul 7, 2010 | 10:40 AM
  #5929
Lead Head's Avatar
Lead Head
in the words of wiki "Because it is a fully balanced configuration, the straight-six can be scaled up to very large sizes for heavy truck, industrial and marine use, such as the 16 L (980 cu in) Volvo diesel engine and the 15 L Cummins ISX used in heavy vehicles.[4] The largest are used to power ships, and use fuel oil."[/quote]
As far as balance, so? V12s and V16s have perfect primary and secondary balance at any v-angle, as does an Inline 8 and V24. Detroit Diesel has a 20L V8, Cummins has a 78L V18. EMD made a 211L V20. Balance issues have not stopped anybody from making huge versions of V8s and other weird number cylinder configurations.
You also still haven't told me why a V8 has to fight gravity...
No....Torsion is twisting. Inline 6s and 8s have much longer crankshafts then an equivalent V8. This means that the crankshaft is going to want to twist a lot more. The reason why they are preferred in large trucks is because of ease of maintenance and the ability to fit between the narrow frame rails of a semi.
Old Jul 7, 2010 | 10:43 AM
  #5930
Jrfish007's Avatar
Jrfish007
Yes, they are very well balanced, or can be. That is why they are used in luxury cars as I mentioned above.
Old Jul 7, 2010 | 10:45 AM
  #5931
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by jac08f250
Ok your truck can tow anything I can, but who will get the better mpg, and who can get up to hwy speed faster, and get to the desanation faster.
V10 wins 2/3.
Old Jul 7, 2010 | 10:51 AM
  #5932
Jrfish007's Avatar
Jrfish007
Originally Posted by bill11012
V10 wins 2/3.
twin turbo V10 diesel? Best of both worlds
Old Jul 7, 2010 | 11:00 AM
  #5933
bill11012's Avatar
bill11012
That would be awsome.
Old Jul 7, 2010 | 11:06 AM
  #5934
Jrfish007's Avatar
Jrfish007
Like this kind of awesome?
Google Image Result for http://www.automotto.org/images/vw-touareg-dragging-a-boeing-747_59.jpg
To top that off it pulled the Boeing 747 in second gear. That's 150 tons for those that don't want to click.
Old Jul 7, 2010 | 11:21 AM
  #5935
bill11012's Avatar
bill11012
Thats pretty cool.
If a VW can do it my V10 can do it.
Old Jul 7, 2010 | 12:50 PM
  #5936
ChargersFanInCO's Avatar
ChargersFanInCO
If your V10 can do it, my PSD can do it...in it's sleep.
Old Jul 7, 2010 | 12:58 PM
  #5937
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by Kajtek1
Now I wonder why Federal EXPRESS did buy whole fleet of 3+ liter diesel Sprinters to replace their fleet of 5-7 liter gas powered vans?
Using the reasons so many here are talking about, why didn't they use a PSD-powered F53 chassis? Apples and oranges.
You mean while it's in the shop, or stuck in regen?
Old Jul 7, 2010 | 01:22 PM
  #5938
krewat's Avatar
krewat
Oh, man, this is just too precious to let go of:
FORD CLASS-EXCLUSIVE V10 GAS ENGINE, TORQSHIFT TRANSMISSION WILL POWER MEDIUM-DUTY CHASSIS CABS | Ford Motor Company Newsroom
From LSChicago's thread in the Large Truck forum:
https://www.ford-trucks.com/forums/9...10-option.html
Long live the V10...
And with the 6-speed TS too...
Old Jul 7, 2010 | 05:18 PM
  #5939
mountaineer27's Avatar
mountaineer27
yes V engines do because the have a balance shaft. a incline does not use a balance shaft because it doesnt need it. it can get a perfect primary and secondary mechanical balance without a balance shaft.
inclines have 4-7 main bearings to avoid crankshaft flex. these bearings cover the complete area exposed where the crank spans the distance of two cylinders. hence the decrease in torsion or flex.
were did you come up with that info from?
im not try to say the v10 is a worse engine. im just saying that by calling it better beacuse of two extra cyliders is all in the way that you look at it. one way yes it is in the power aspect but yet in other aspects it may not be as good. fuel economy for one.
Old Jul 7, 2010 | 06:51 PM
  #5940
Seven-Point-Three's Avatar
Seven-Point-Three
V10 wins 2/3.
Hmmmmmmm.............You must teach me your kind of math, I added it up and got zero, zippo, nada, etc. for the V10.
