Sponsored by: Real Truck
Gas vs PSD
Old Jul 7, 2010 | 06:26 AM
  #5911
Lead Head's Avatar
Lead Head
Originally Posted by Kajtek1
Now I wonder why Federal EXPRESS did buy whole fleet of 3+ liter diesel Sprinters to replace their fleet of 5-7 liter gas powered vans?
Probably because nobody else really makes a modern tall-height van anymore? The old ones had Grumman bodies, I don't think Grumman is even still in the van business. I'm sure the fuel economy benefits was also a factor, but the fact that Mercedes is just about the only one with this style of van (at least in America) has a lot more to do with it.
Old Jul 7, 2010 | 06:32 AM
  #5912
Jrfish007's Avatar
Jrfish007
Originally Posted by ChargersFanInCO
I would also like to ask why you lock your hubs in the winter? Do you have a manual xfer? what are the benefits of locking them if you have ESOF? I'm asking as mine goes into 4WD when I flip the switch. Does it actually "lock" the front end when you lock the hubs making it a front-wheel-drive with the rear wheels acting as normal? The book is pretty ambiguous.
Yes, I do have a manual transfer case. Basically if I don't lock my hubs, the transfer case will send power to the front axles, which won't be connected to the tires. All F150's come with electronic hubs, but I don't think the super duty's do. I am not sure if the upper end ones have electric hubs or not... I know XL and XLT's don't.
However, keeping the hubs locked means when ever I accelerate, I have more rotational mass to accelerate, because the front tires are connected to the front axles (but not the transfer case, so no power is going to the front tires until I turn on the 4x4).
I keep them locked in the winter because the plow trucks here are a joke and you never know which roads are clean and which are not. In addition, there are quite a few stop signs at the top or in the middle of a hills around here. And getting out at every one of those got old really fast.
Old Jul 7, 2010 | 06:38 AM
  #5913
Jrfish007's Avatar
Jrfish007
Originally Posted by Crazy001
There's no reason a large displacement V8 wouldn't do as well or better than the current gen V10 does. It's not a great engine simply because it has 10 cylinders!
It's a great engine because it's large enough(6.8L) to have a high peak torque and HP rating and is built upon proven architecture that allows it to have a nice, flat torque curve and is known to last over 300,000 miles. This can be done with a V8.
Actually there is a reason a V10 is better than a V8. The more cylinders you have, the more aggressive cam you can put in the engine with it sounding like it is going to stall. More cylinder help smooth the idle out. So a 6.8L V10 can have a far more aggressive cam than a 6.8L V8.
In addition, it makes a smaller combustion chamber, which is easier to control for a gas engine.
There is a reason we don't see 8.0L single cylinder engines lol
But the most obvious reason is that it has the same architecture as the 5.4 and was easy to build.
Old Jul 7, 2010 | 06:41 AM
  #5914
Jrfish007's Avatar
Jrfish007
Because they get better mpg. And I doubt anyone here would argue that when you are driving the truck as many miles as they do per day, diesel will clearly win the economic battle because of better mpg.
Old Jul 7, 2010 | 06:48 AM
  #5915
Jrfish007's Avatar
Jrfish007
Originally Posted by jac08f250
ehhhh....I don't know how much longer the v-10 will be in the line up. Now I know this is a rumor and all but there are rumors of a bigger v-8 to replace the v-10. I think it's stupid to get rid of the v-10 cause the other so call big 2 don't offer a v-10 in the cab and chasis or at least I don't think they don't offer one.
Actually the other 2 don't offer any form of a big gas engine anymore. Dodge puts bigger engines in their cars than their trucks. But to be honest why should they? They have "smaller" gas engines (and Ford does now with the 6.2 V8) that can max the trucks towing ability. Ford's new 6.2L engine can tow over 15,000 lbs in the CC, 4x4, F250 shortbed. My V10 is only rated for 300 lbs more. It doesn't make sense to build another engine so you can get 300 lbs more towing capacity.
Most people who tow on a regular basis will buy the diesel anyway, the gas engine is for people who might put stuff in the bed, occasionally tow, and/or not drive many miles. In that respect, the new 6.2L V8 is just as good as the old V10, specially with the addition of an extra gear in the tranny.
Old Jul 7, 2010 | 07:55 AM
  #5916
Tom's Avatar
Tom
Yeah, that makes perfect sense to me.
But unless I'm badly mistaken, neither the 2v or 3V engines have this aggressive cam you refer to. Isn't an "aggressive" cam one which provides more power in the upper RPM ranges which causes low RPM performance to be abysmal?
I always figured one benefit of having more cylinders per unit of displacement would allow the engine to rev higher due to the lighter mass of the individual rotating components. Again, not directly applicable to the V10s, as they aren't high-revving motors.
Old Jul 7, 2010 | 08:00 AM
  #5917
mountaineer27's Avatar
mountaineer27
well a v8 is the least efficiant engine built. its fights gravity. now a inline 6 is a more econimical engine. to bad they dont make them anymore in light cars and trucks. so i wouldnt imagine a v10 is better. it would be worse. you may make more power because you have two extra cylinders but that doesnt make it better.
Last edited by mountaineer27; Jul 7, 2010 at 08:26 AM. Reason: i had inline 8 instead of 6 lol
Old Jul 7, 2010 | 08:06 AM
  #5918
Lead Head's Avatar
Lead Head
A V8 fights gravity? Huh?
Inline 8's suffer from lots of torsional stresses on the crankshaft and take up a lot of space.
Old Jul 7, 2010 | 08:20 AM
  #5919
mountaineer27
the front and rear trio of cylinders are mirror images. creates a perfect balance.
a inline creates less torsion stress than a v8. thats why there perfered in large trucks. cant fight you on the room issue though
in the words of wiki "Because it is a fully balanced configuration, the straight-six can be scaled up to very large sizes for heavy truck, industrial and marine use, such as the 16 L (980 cu in) Volvo diesel engine and the 15 L Cummins ISX used in heavy vehicles.[4] The largest are used to power ships, and use fuel oil."
Old Jul 7, 2010 | 08:49 AM
  #5920
bill11012's Avatar
bill11012
Modular motor junkie
Yeah very slowly while the rpm's are about 4k. I would hate to see and hear a v-10 pulling a heavy load up a hill. Probably sounds like the engine will explode.
4,000 RPM at WOT sounds fine and it can run it all day.
Ok can you v-10 pull a load like this.
This is about 24k pounds just on the trailer.
If the PSD can do it than my truck can. Something in the drive train will snap from the strain before engine will.
Plus the v-10 would wear out alot quickier then the psd.
If they do SO much testing on the v-10 why do they have to be rebuilt normally around 250k miles or so?
Any way to back that up?
It's that JL that thinks that no one should have a psd cause he thinks the v-10 is the second coming of Jesus Christ.
Originally Posted by Johnny Langton
You do have a reading comprehension issue.
JL
Makes perfect sense. I have never thought of that before.
Old Jul 7, 2010 | 08:57 AM
  #5921
jac08f250's Avatar
jac08f250
Damn are you JL's boyfriend? Ok your truck can tow anything I can, but who will get the better mpg, and who can get up to hwy speed faster, and get to the desanation faster. Oh that would be me cause everyone knows a diesel is better in all those factors.
Old Jul 7, 2010 | 09:04 AM
  #5922
ChargersFanInCO's Avatar
ChargersFanInCO
the total trip for him is about 6 miles one way. It can easily take an hour to do that trip because of traffic.
My trip is 4.5 miles, and can take me about 45 minutes.
Ughhh...I hate traffic.
Old Jul 7, 2010 | 09:12 AM
  #5923
ChargersFanInCO
makes sense..mine does lock in when I flip the dash switch if the hubs are in "auto". My hub positions are "auto" and "lock" not "free" and "lock". I don;t see a big point in running them in lock, and that's what I'm trying to figure out since the book says to leave them in "auto" for "most purposes".
Just to keep it on topic...Diesel Wins...
Old Jul 7, 2010 | 10:22 AM
  #5924
Jrfish007's Avatar
Jrfish007
The disadvantage to automatic locking hubs is that it can one full tire rotation for them to lock in where as in manual lock they are locked in.
The difference comes in if you are already stuck before you put into 4x4. If your stuck and try to put it in 4x4 with the auto hubs, they may not lock in since the front tires are not rotating. You can get out and lock the hubs manually and be in 4x4 without having to rotate the front tires.
Old Jul 7, 2010 | 10:24 AM
  #5925
Jrfish007's Avatar
Jrfish007
Getting there faster is merely a question of who wants to break the law more... Unless of course your talking a really long distance, then the gasser will loose because it will be in the gas station all the time.
