Sponsored by: Real Truck
Gas vs PSD
Old Sep 29, 2009 | 10:55 AM
  #2086
mudmaker's Avatar
mudmaker
Originally Posted by Krewat
The real crux of the matter is that it's not the best choice for everyone.
That is why ford offers three different motors. Each motor should have a scenario where it is better.
For the way I use my pickup I just haven't found where a gasser is better.
Old Sep 29, 2009 | 10:56 AM
  #2087
Tom's Avatar
Tom
For YOU.
With Ford losing the V10 in 2011 in the F250/350, and going backwards to an 8-cylinder 6.2L, they are making the choice for those who prefer the gasser.
Looks like I'm keeping my 2001 for the rest of my life
I understand lots of folks are resistant to change. However why don't we wait to speculate on this engine until we actually see HP and TQ values, as well as power and torque curves.
Just because it's a bit smaller and 2 cylinders down does NOT mean it'll be worse.
The 6.0L PSD gained 50 HP when it lost 1.3 liters. My 6.4 puts out nearly 100 HP more than the 7.3L engine. Technology is great!
Why don't we all wait and see before bashing?
Old Sep 29, 2009 | 11:00 AM
  #2088
mudmaker's Avatar
mudmaker
Originally Posted by R-WEST
Holy cow!! 139 pages!!
If you go change the post per page in your the UserCP you can change that. I only have 53 pages.
Old Sep 29, 2009 | 11:09 AM
  #2089
krewat's Avatar
krewat
FTE Leadership Emeritus
I'm not necessarily bashing. But going from 10 to 8 cylinders, even with the same cubic inches WILL result in less average overall torque at all RPMs.
It might not show in the numbers, but it's still there.
As for the diesels, yes, boost is a wonderful thing. On gassers, there is no replacement for displacement, especially when normally-aspirated.
Old Sep 29, 2009 | 11:11 AM
  #2090
SteveBricks's Avatar
SteveBricks
FTE Emeritus
Maybe the 6.2 will make it's power at 7k rpm
Old Sep 29, 2009 | 11:16 AM
  #2091
Tom's Avatar
Tom
True enough about N/A gas motors. Depending on other factors it may actually perform better though. The V10 needs to rev to make serious power, which I'm sure will be the same for the new 6.2.
But say it only has a minimal loss in torque. What if it has 425 instead of the current 457? I believe they are using a new VCT system in the new engine. What if they can get it to provide near peak torque all the way from 1,500 to 5,000 RPMs? The current V10 starts to lose steam after the torque peak at 3,250. What if this one didn't until much higher? You'd have a relatively minimal loss of power at lower RPMs, but the mid and high range would be MUCH better.
Couple that with the new 6R140, which I'm sure won't be bashful about letting the engine rev up and sing, and I think it'll be a monster. I believe in the videos on the Ford website they claim that it's more fuel efficient than the outgoing 5.4L engine. Think about an engine that may tow better than the V10 and get better MPGs than the 5.4!
This thing could be GREAT!
Old Sep 29, 2009 | 11:40 AM
  #2092
krewat's Avatar
krewat
The 2-valve V10 puts out 80% of it's peak torque at only 1000RPM. And it doesn't "lose steam" after 3250, it just peaks at 3250. The fall-off isn't as much as you make it sound like
Old Sep 29, 2009 | 11:59 AM
  #2093
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I have one already.
Old Sep 29, 2009 | 12:19 PM
  #2094
Tom's Avatar
Tom
Funny post, Miller Feed.
I believe you, my 5.4 was a real workhorse and I believe had a very similar torque curve to the V10.
But still,
http://www.5startuning.com/dynoscans/page%2014.jpg
This dyno of a 2005 3V V10 dyno chart shows a definite decline of torque once it peaks. If you could minimize that through clever cam timing, you could make some BIG power. Much like the rumored 400 HP of the 6.2.
Old Sep 29, 2009 | 01:03 PM
  #2095
krewat's Avatar
krewat
First, keep in mind that's rear-wheel numbers, not flywheel which is what has been discussed so much in this thread.
Totally stock, the curve on that dyno shows a "decline" of 35 ft/lbs at 5100 rpms (190ftl/bs), versus the peak of 225ftl/bs at around 4000.
That's 18% less than the peak. That's not a whole bunch.
It's worse on the 2-valve, unless you start doing things like I did - open the intake and exhaust and tune it. My 2-valver really pulls way up to 5000RPMs.
Old Sep 29, 2009 | 01:11 PM
  #2096
Tom's Avatar
Tom
I believe it! I remember driving Monster-4's truck with a 5-star tune, and it really pulled all the way to redline. This is why I love the modular truck engines so much! This is also why I invited a friend who loves his Hemi ram to our little gathering next Sunday. Others may make engines that pull hard at high RPMs, but I've never driven a gasser that pulls like a Mod V8(or V10!) at low RPMs and can carry that all the way through redline.
Even so, to say something's perfect and can't improve normally means you're not trying hard enough. I know Ford has been trying awfully hard, and their sales numbers lately really demonstrate that.
The 3V V10 gained a lot when they went with the 3V heads with VCT. I expect a similar improvement with the "little" 6.2L V8 and their new VCT system. I have high hopes...
Old Sep 29, 2009 | 02:25 PM
  #2097
HuntsDucks70's Avatar
HuntsDucks70
Ah, that depends on the competition!
Realize for a minute that KelVarnson and I both own diesels. When I went up to Millersburg and met up with Monster-4 and i eat hybrids, we got to try them out. Wasn't a fair comparison to Monster-4's V10, as he had the older model with less power than the 3V V10 of the same generation as the '07 F150 and my '08 PSD we lined it up against. Still, it did a great job with that kind of load, and I really have lots of respect for the engine. I would have been really interested to see how a stock 7.3 would have done.
From what I've seen out of my 6.4, as well as the stats on paper, there's no doubt that the 7.3 will seem to have an easier time with a load. After all, it has the definite torque advantage, which translates to a horsepower advantage all through it's rev range. At the same revs, the V10 can not match the horsepower output of the turbodiesel. Therefore, the only time you'd realize a benefit to the V10 is when you crank it up over 3,500 RPMs and let it sing. Perfectly capable of doing it, and I think it'd do it all day long for many years without a problem. The fact still remains that the 7.3 will likely be a more pleasant engine to tow with.
Which doesn't mean the V10 can't do it, though!
i just want to state that i luv reving my truck to 5K plus, i freakin luv to hear it scream! i dont think i am the only one who luvs to rev their ***** to the moon!
what sounds really disgusting is full throttle shifts at 3K, just doesn't do it for me, give me a reving gasser any day
i will say this though, i will likely down grade to a diesel when i get into my mid to late 50s, not a bash, just a plan i have
diesel=great engine for people who luv em
gasser=great engine for poeple who luv em
diesel will pull with less RPM and better fuel economy (not including the 6.4), diesels are great and i do not have a problem saying so, but, to me, my V10 is perfect, short trips to the store with kids, hunting, towing and off roading, idles quietly in my driveway without dumping fumes into my house or around my children
DIESELS CAN AND WILL PULL BETTER THAN MY V10, and to that i say, so freakin what, i luv my V10, smooth, quiet, powerful, high reving and thirsty!
Old Sep 29, 2009 | 02:29 PM
  #2098
Tom's Avatar
Tom
I have to agree. Nothing wrong with letting it sing, if that's what you're into. As far as MPGs, I still think the 6.4 has an advantage over the V10. Certainly not what it once was with the 7.3, but I believe it's still there.
I've gotten 17 MPG on the highway, and I have less than 4,500 on mine. Normally will get 12-13 city. How does your V10 do empty?
Old Sep 29, 2009 | 02:30 PM
  #2099
95_Dually's Avatar
95_Dually
I completely agree with you.
  #2100
95_Dually's Avatar
95_Dually
That is a funny post Miller Feed.
