Sponsored by: Real Truck
Gas vs PSD
Old Sep 11, 2009 | 04:59 PM
  #1336
Rush117's Avatar
Rush117
Originally Posted by KelVarnson
That's silly. Power still equals torque times RPMs, the 5252 is just to get the units right (horsepower). It's still perfectly valid to say, "Power equals torque times RPM".
I completely agree...if only Bill had said that instead of "tq X RPM = HP".
That is all interesting information, and an interesting question at the end. I would have to think that while a turbo helps at altitude, there still must be some detrimental effect. I doubt that you get sea-level performance at any altitude just because you have a turbo. But I don't know for sure...
On a wastegated turbo, there will be a "critical elevation" that the turbo can provide the same induction pressure to the engine that it did at sea level. The 7.3 would fall into this category. So it can maintain sea level performance up to its critical elevation. I have no idea what that elevation is but I believe it is above 8,000.
The 6.0 is more complicated because it doesn't have a wastegate. I assume the 6.4 is in the same boat but I don't know. I'd assume that it doesn't have excess capacity so, therefore, no need for a wastegate. However, it's possible that the variable vanes take care of the excess capacity rather than a wastegate. This is a long complicated way to underscore my ignorance on the subject. Although my 6.0 doesn't seem to lose any power at elevation but that is hardly an objective or scientific observation.
Old Sep 11, 2009 | 06:04 PM
  #1337
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by 02GrayPowerStroke
Thats a good point. But I think most people on this site are not running stock. I have been wrong before.
I sure am!
Old Sep 11, 2009 | 06:16 PM
  #1338
bill11012's Avatar
bill11012
Sorry, that is what i meant. I was tired when i said that.
Old Sep 11, 2009 | 06:45 PM
  #1339
KelVarnson's Avatar
KelVarnson
Alrighty then, I guess we're all on the same page.
I was going to ask, "Where does it get the extra energy to do that, but then you said:
...and the light bulb went on in my head, telling me that the 7.3 waste gate is basically wasting energy until it closes off at some particular altitude.
Do I have that right?
I learn something new everyday. Thanks.
Old Sep 11, 2009 | 06:54 PM
  #1340
Tom's Avatar
Tom
Yup. A wastgate detours exhaust gasses around the turbo to avoid producing too much boost. Therefore, as the air gets thinner, the wastegate wouldn't open as early, allowing the turbo to use more of the exhaust gasses to generate the same amount of boost it would at lower altitudes.
Old Sep 11, 2009 | 07:22 PM
  #1341
02GrayPowerStroke's Avatar
02GrayPowerStroke
I sure am!
You sure are what?
And I did not read the other 1500 replys to this thread but have you ever driven a PSD or pulled with one? Or what and how often do you pull with you V10?
Old Sep 11, 2009 | 08:14 PM
  #1342
Rush117's Avatar
Rush117
You sure are what?
I think he's saying that he is running stock.
Old Sep 11, 2009 | 08:20 PM
  #1343
mountaineer27's Avatar
mountaineer27
7.3 rocks
Old Sep 11, 2009 | 08:32 PM
  #1344
Izzy351's Avatar
Izzy351
Sheesh -- is this thread STILL going???
Anyone with a V10 want to meet at a truck pull with a work/street class?? I've only seen diesels there -- but I haven't been to many. I'm game.
Old Sep 11, 2009 | 08:53 PM
  #1345
04redstroker's Avatar
04redstroker
Originally Posted by Broncoholic1
Yes if a Bulldozer or cement truck sounds cool
I like the way they sound. At least they sound better then a v10.
Old Sep 11, 2009 | 09:55 PM
  #1346
EXv10's Avatar
EXv10
That's another matter of opinion type thing. If I never had a diesel I might like the sound.................king of like developing a taste for limburger cheese (which I do like). But for now , the V-10 sounds good ; Grrrrrrroooowl.
Old Sep 12, 2009 | 08:22 AM
  #1347
Broncoholic1's Avatar
Broncoholic1
You sure are what?
I pull a #3200 tandem equipment trailer. #15,000 it is a Dynaweld & a 12,500 Mini excavator, Also a Case 1845c #7000 with attachments, & a Case 350B Dozer #9,500 all over town, Stock truck just turned 100K, Might be time for a tune up. The mini I can feel back there,
As for the sound when it spools up it is bone stock not much sound. Mobil 1 ever since the first 6000 miles on the 3rd oil change. New exhaust studs & Muffler is all I have ever done to it. OBTW I did replace the rear springs with 1 ton packs 5 years ago, I forgot. The V10 studs do really suck tho...
This truck out pulls the 97 F350 = 7.3 That is the main reason we got it. That & we used to plow snow with it, PSD are no good for snow removal, in the turbo too much. As for stock to stock the 99 V10 was the winner 10 years ago...
When you run a machine all day you do not want to jump in one to drive home, It sounds cool for the younger kids...
PS: I would never own a 6.0 or a 6.4 too many problems.
The 7.3 is the way to go if you are going to mod it
Old Sep 12, 2009 | 09:21 AM
  #1348
KelVarnson's Avatar
KelVarnson
Is that because the turbo lag is a pain? Just trying to understand.
Old Sep 12, 2009 | 09:33 AM
  #1349
Izzy351's Avatar
Izzy351
Never heard a dozer or cement truck sound like this:
http://www.youtube.com/watch?v=HBY6YCS-8T0
Old Sep 12, 2009 | 10:20 AM
  #1350
bill11012's Avatar
bill11012
You sure are what?
My V10 is stock, 2v non PI. 3.73s and 4R100. I have towed up to 18,000 gross.
It is lacking on the low end, and with these gears I can not get the revs up to peak HP tell about 35mph. Once I have gotten up to that speed, I can keep up with traffic easily.
I tow 2-4 times a weak, most loads about 15k gross.
I have driven a 7.3, 2 V10s and a 5.4. All 98 or 99.
The 5.4 with an empty trailer was pathetic.
The 7.3 has a lot more at low rpm, but the V10 in the right rpm range pulls much harder.
