Sponsored by: Real Truck
Gas vs PSD
Old Sep 28, 2009 | 12:43 AM
  #2041
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by mudmaker
To me it is a matter of the additives in the oil, not just how dirty it is. The only way to tell for sure is to have it analyzed. I have never done it, but with a psd you can tell for sure when you let it go too far. Your injectors sound wierd!
I figure if it has crap in it to the point I cant see through it, its ready for a change.
Never knew that with that set up you could hear it like that, but it makes since.
Old Sep 28, 2009 | 12:45 AM
  #2042
mudmaker's Avatar
mudmaker
Originally Posted by 95_Dually
I want it for my wife. Maybe we could get them to fight for it. I will dig a mud pit.
My wife is currently driving a GMC conversion van. I want to get an Excursion though. It has to be the 7.3. I will keep looking since I cannot have yours.lol
That's funny right there!!
I hear ya on the 7.3. They are harder and harder to find with out a ton of miles on. The only reason I was able to afford mine is it has a prior salvage title. Got it w/80k miles for about what ones with 200k+ were going for, and it had been wrecked at 30k miles so it isn't like it came right out of the body shop.
you guys have yourself a nice evening! I have to get to bed!!
Old Sep 28, 2009 | 12:50 AM
  #2043
95_Dually's Avatar
95_Dually
Goodnight.
Old Sep 28, 2009 | 12:53 AM
  #2044
bill11012's Avatar
bill11012
Remember, everyone here has been assuming 3.73 in the PSD and 4.30 in the V-10. That has been the discussion all along. When someone mentioned 4.10 for the diesel it was said it is not standard but instead an option.
In 98 the 3.73 was stranded, the 4.10 was and option and 4.30s were no existent.
I need to look up the gearing on both tranys, but i can do that tomorrow.
I have to sleep!
Old Sep 28, 2009 | 01:06 AM
  #2045
95_Dually's Avatar
95_Dually
Goodnight.
Old Sep 28, 2009 | 06:48 AM
  #2046
Tom's Avatar
Tom
How can you run a gear lower than me? You have a lower rear gear already. We will probably be in the same gear at 2500 rpm. You will only have so much power even after the math because you have less torque. Once you shift to the next gear guess what, you have lost that HP advantage and you are working to get back up to again.
Wait a minute!!!
You can NOT have more torque at the same RPM without more horsepower!
Say Bill's near his peak at 2500 RPM and is putting out probably around 400 lb-ft. Your PSD is between it's torque peak and HP peak, so it's likely pushing around 450 or 500.
HP = (TQ x RPM)/5252
In this example, assuming my guesses are right, your PSD is pushing 214 HP(with 450 ft-lbs) and his V10 is pushing only 190.
Of course you're pulling harder, you have more HORSEPOWER!
You can never have more torque at the same RPM without having more horsepower. EVER!
Rant over, carry on!
Old Sep 28, 2009 | 07:06 AM
  #2047
jdadamsjr's Avatar
jdadamsjr
Amazing !!!!
Still arguing the what came 1st, the chicken or the egg ????
Old Sep 28, 2009 | 07:52 AM
  #2048
Rush117's Avatar
Rush117
Hey Bill,
I think the flaw in your math is that you are comparing new trucks. At 17, you would have been 11 the last time a new 7.3 psd sat on a lot. In order to make it a more accurate analysis, you need to determine what a 7.3 would have cost you when you bought your V10. I doubt it would have been anywhere near $6,000. In addition to that, the 7.3 will always be more valuable. Therefore, you can recoup some of the cost when you sell. You may drive it til the doors fall off but there will always be someone that will be willing to buy it.
Old Sep 28, 2009 | 08:33 AM
  #2049
alchymist's Avatar
alchymist
"Mifflin Clay"
Originally Posted by mongo75
I see nothing wrong with taking both engines and putting them in the identically set up vehicle. Kinda like taking a 500 pound pile of bricks, and timing both a slim and fast guy move them 50 feet, or a slower, stronger guy. My money would be on the slower, but stronger guy to finish first- he can carry more and won't get tired as fast.
And I'll bet you would insist on putting 400 lbs of lead around the V10 to make up for the weight difference between the engines too.....what part of "different designs" didn't you see?
Or perhaps the identical vehicles should have 4.88 rears and go for a speed trial.......?? Is that fair?
Old Sep 28, 2009 | 09:25 AM
  #2050
Rush117's Avatar
Rush117
If we were to come up with a psd vs. V10 test in identical vehicles with 3.73 gears, you'd say that would not be a valid test because the 3.73's in the V10 would not optimize it and the psd would be favored. So how about a test where you pick the gears, but both trucks get the same gears? What would be more fair to you than that?
I'll do a speed trial with 4.88's. I already know that the V10 would have a higher top speed. I also know that the psd will get to its top speed much faster and that the psd top speed will still be faster than I would ever operate it. You want 5.38's? I'd do that too. It would be fair and the results would be interesting.
Old Sep 28, 2009 | 10:31 AM
  #2051
Broncoholic1's Avatar
Broncoholic1
Originally Posted by bill11012
I guess it matters what you call dirty.
Tell you what, I will take a pic of mine at the next change so you can see when I think it should be changed, you do the same.
It is not how dirty it is The diesel has no gas in it to break it down. That doubles the miles for a Diesel. The V10 has some blow by hence breaks the oil down quickly. Just try to add a pint of gas to a fresh oil change & see how long the viscosity will last.
The V10 needs every 4K The 7.3 needs it 8K
Unless you tow @90 mph + Change it once a month, & the filter every other month. As for spark plugs have you hit 100K & changed them yet?
Old Sep 28, 2009 | 12:47 PM
  #2052
phillips91's Avatar
phillips91
V10 164,000 miles at 10mpg at $2.40 = $39,360
7.3 164,000 miles at 14mpg at $2.60 = $30,457.
V10 6 quarts at $5 = $30 + filter at $6 = $36. 57 x $36 = $ 2,052
7.3 15 quarts at $5 = $75 + filter at $22= $97. 57 X $97 = $ 5,529
fuel filters
V10 $13 x 9 = $117
7.3 $41 x 9 = $369
Not sure where you're getting your numbers, but you're off by a considerable amount over what I pay for my 7.3.
My 7.3 is an obs, but it gets 22 mpg. Most of the srw super duty guys get about 18-19. Way above the 14 mpg you quote.
Very few diesel people use sythetic oil. The majority of us use rotella t or motorcraft, which comes in around $2 per quart. My 5.4 only holds 6-7 quarts of oil but my oil change costs more than it does in my 7.3 because I use synthetic in it. So the price of the oil change depends on which kind of oil you use. If we both used the same kind of oil my change would be higher, but you use synthetic and I don't. So at the end of the day more money came out of your pocket.
I pay $20 for my fuel filters at napa. Half of the price you quote.
Old Sep 28, 2009 | 12:53 PM
  #2053
phillips91's Avatar
phillips91
Is something wrong with the wix filters for a PSD?
Yeah, they are too d*mn expensive. That's what's wrong with them lol. I get a purolator pure one for mine. Runs about $9-10 at advance.
Old Sep 28, 2009 | 12:58 PM
  #2054
KelVarnson's Avatar
KelVarnson
22??!! Wow... My '02 7.3 consistently gets 14 mpg combined town and highway. And I never go over 70 mph.
Old Sep 28, 2009 | 01:14 PM
  #2055
phillips91's Avatar
phillips91
The worst I've ever gotten out of mine unloaded was 19 mpg and that was running 70-75 the whole way. I get 21-23 if I run it 60-65. On my daily trip i drive 80 miles round trip and about 70 miles of it is highway. I don't drive it in the city enough to test the mpg there.
