Sponsored by: Real Truck
Gas vs PSD
Old Sep 27, 2009 | 02:14 PM
  #2011
phillips91's Avatar
phillips91
Originally Posted by Rush117
At highway speeds, hp WILL make the difference. The V10 WILL end up faster but if they are geared the same, it will take longer for the V10 to pass the psd because it will be out accelerated.
we may be arguing different points, so let me clarify myself. using my 5.4 and 7.3 again. if we stay in 3rd gear and never shift to 4th, both with 4.10 gears, my 5.4 will go faster at top speed no questions asked, because it turns more rpms. my argument is about acceleration. with the same gearing(no matter what rpm my 5.4 is turning) and us in the same tranny gear, my 7.3 is going to have more get up and go as soon as we hit the go pedal even though the 5.4 has more hp. depending on my load size, i can accelerate faster with my 7.3 in 5th gear than my 5.4 will in 3rd.
Old Sep 27, 2009 | 03:37 PM
  #2012
95_Dually's Avatar
95_Dually
The reason that the 7.3 can still accelerate is because of torque. Most of the people here continue to say and show using math formulas that HP is what makes things move. The truth is without torque, you are not going anywhere. That is why the Diesel can move a heavier load with a higher gear. If the V-10 made the same torque, it would be able to use a taller gear. S
Since everyone seems to say that HP is the deciding factor then gearing should have nothing to do with it. The V-10 makes about the same HP as the diesel at about the same rpm's but the torque is so much less it needs the gears to compensate for the torque.
Old Sep 27, 2009 | 04:51 PM
  #2013
bill11012's Avatar
bill11012
Modular motor junkie
No, the gears are to let it run a higher RPM to get to the HP.
Torque is great for getting a load started but HP is what keeps it moving.
Old Sep 27, 2009 | 04:56 PM
  #2014
Rush117's Avatar
Rush117
The difference is still hp. I don't know what the transmission ratio difference is between your 5.4 and 7.3 in third gear but I doubt they are too different, if at all. That being the case, there is NO WAY that the 5.4 is anywhere near its hp peak whereas the 7.3 is much closer. So even though your 5.4 has a higher peak hp, the amount it is producing at the time you start accelerating, is probably much lower than the 7.3. Also remember that torque is an input in the hp formula so it plays a significant role in how much hp the engine has.
The thing that is important to realize here is that the hp numbers we're talking about is "peak" hp. The physics behind the claims here are accurate. Just keep in mind that they are based on very narrow snapshots of engine output. We can take the hp peak numbers as a snapshot and determine that a V10 can "pull harder" than a psd but we can only be certain of this if the V10 is at its hp peak at sea level. So don't think of it as the higher hp, lower torque motor will pull harder, think of it as that it will eventually pull harder.
The argument I make is that the peak hp of the V10, or 5.4, is severely diminished because in order to outpull a psd, it has to rev significantly higher than highway rpm to get the power. They say the V10 "likes" high rpm. I say no engine "likes" high rpm, the V10 just needs it to get its power.
EDITED TO ADD: In order to explain why your 7.3 will out-accelerate your 5.4, it would take an accurate dyno sheet for both of them. I would guarantee that your 7.3 is producing a whole lot more hp at the rpm where you start the acceleration than the 5.4 is.
Old Sep 27, 2009 | 05:04 PM
  #2015
bill11012's Avatar
bill11012
It really does seem to like it, or at least put up with it very well.
Mine has had the **** revved out of it most of its life, and it does not have any problems.
Old Sep 27, 2009 | 05:31 PM
  #2016
alchymist's Avatar
alchymist
"Mifflin Clay"
Actually the fairest test is a "black box" test. Two identical trucks, except for no restrictions on drivetrain, and identical weights and loads. No one cares about the drivetrain ratios, it's an ENGINE comparison. Forget all the ratio calculations, let the individual trucks be optimized, and it all comes down to HP. Perfect solution for either vehicle would be a CVT tranny.
Old Sep 27, 2009 | 06:53 PM
  #2017
KelVarnson's Avatar
KelVarnson
This is the right approach. If you really want to compare the engines directly, they have to be allowed to run at their optimum RPMs. Comparing them in two identical trucks with identical drivetrains is not a fair test.
Old Sep 27, 2009 | 10:36 PM
  #2018
Pinky Demon's Avatar
Pinky Demon
And the beat goes on...
Old Sep 27, 2009 | 11:31 PM
  #2019
mongo75's Avatar
mongo75
I see nothing wrong with taking both engines and putting them in the identically set up vehicle. Kinda like taking a 500 pound pile of bricks, and timing both a slim and fast guy move them 50 feet, or a slower, stronger guy. My money would be on the slower, but stronger guy to finish first- he can carry more and won't get tired as fast.
Old Sep 27, 2009 | 11:44 PM
  #2020
bill11012's Avatar
bill11012
I said I would show my math on how the V10 is cheaper than a 7.3 PSD and is more profitable as my work truck.
I finely got the time to type it all out, here it is.
This is all based on the miles I have put on mine and my maintenance schedule.
All the prices are from O'reillys.
The 7.3 was $6,000 more than a V10 new.
V10 164,000 miles at 10mpg at $2.40 = $39,360
7.3 164,000 miles at 14mpg at $2.60 = $30,457.
That puts the 7.3 $2903 ahead.
57 oil changes using castrol synthetic blend and wix filters.
V10 6 quarts at $5 = $30 + filter at $6 = $36. 57 x $36 = $ 2,052
7.3 15 quarts at $5 = $75 + filter at $22= $97. 57 X $97 = $ 5,529
That puts the V10 $574 ahead.
9 air filters
V10 $19 x 9 = $171
7.3 $26 x 9 = $234
That puts the V10 $637 ahead.
fuel filters
V10 $13 x 9 = $117
7.3 $41 x 9 = $369
V10 $889 ahead
belts X 2
V10 $29 x 2 = $58
7.3 $36 x 2 = $72
v10 $903
hoses x 2
V10 upper $18
lower $70
heater$39
heater$17 = $144 x 2 = $288
7.3 upper $15
lower $20
heater$36
heater$38 = $109 x 2 = $218
V10 by $833
coolant x 2
v10 5 gal at $11 = $55 x 2 = $110
7.3 8 gal at $11 = $88 x 2 = $176
So, by my math the V10 comes out $899 ahead of the 7.3 power stroke.
More miles and more maintenance should continue to stretch that gap.
Old Sep 27, 2009 | 11:49 PM
  #2021
95_Dually's Avatar
95_Dually
Bill, your truck and my truck has about the same HP at 2500 RPM. Not peak for either one of us. I will have more torque and therefore out pull you. It doesn't matter what gears you have because 2500 RPM is 2500 RPM. I will also be going faster than you at 2500 RPM due to a taller gear.
When You get to your Peak HP you will begin to catch up but it will take you a while because I am already in my powerband. I am not saying you are not faster, I am saying I am quicker. This again is because of torque.
Old Sep 27, 2009 | 11:55 PM
  #2022
bill11012's Avatar
bill11012
From a start, yes.
from 35 mph up I can run a gear lower than you can, even if we make the same power at the flywheel, I have a better pulling gear, the same hp and will pull better than you because of that.
Old Sep 28, 2009 | 12:08 AM
  #2023
95_Dually's Avatar
95_Dually
How can you run a gear lower than me? You have a lower rear gear already. We will probably be in the same gear at 2500 rpm. You will only have so much power even after the math because you have less torque. Once you shift to the next gear guess what, you have lost that HP advantage and you are working to get back up to again.
Old Sep 28, 2009 | 12:09 AM
  #2024
mudmaker's Avatar
mudmaker
9 air filters
V10 $19 x 9 = $171
7.3 $26 x 9 = $234
fuel filters
V10 $13 x 9 = $117
7.3 $41 x 9 = $369
V10 $889 ahead
belts X 2
V10 $29 x 2 = $58
7.3 $36 x 2 = $72
v10 $903
hoses x 2
V10 upper $18
lower $70
heater$39
7.3 upper $15
lower $20
heater$36
V10 by $833
coolant x 2
That's a lot of figuring there!
Couple of corrections for ya.
I have always changed my oil every 7-8k miles in my 7.3's so that would put it at around 20 changes in that many miles.
A 7.3 was not a $6k option. IIRC it was around 3500.
Edit: mine was actually a $4114.00 option
Old Sep 28, 2009 | 12:17 AM
  #2025
bill11012's Avatar
bill11012
I thought it was a 6k option, that kind of messes up all my math.
Your oil not get filthy by 5K?
