Sponsored by: Real Truck
Gas vs PSD
Old Sep 28, 2009 | 06:15 PM
  #2071
KelVarnson's Avatar
KelVarnson
Originally Posted by Rush117
I checked your math and the only difference I have is the axle torque for the 5.4. I came up with 2310 vice 2308, but who's counting.
I caught that too, right after I posted. It was a rounding error, because I did the 5.4 in multiple steps, since it had a reduction in the tranny. I calculated the 7.3 in one step, since the tranny was 1:1.
Thanks for the double-check.
The only thing I would add is that you solved for axle torque and I would just add in tractive force so the tire size will be included. In this case, both tires are the same so it doesn't matter for comparison purposes but it does show the amount of force the tires are actually exerting on the ground to move the truck. In this scenario, I came up with 1,751 for the 5.4 and 1,321 for the 7.3.
Excellent point. And I concur with your numbers.
Old Sep 28, 2009 | 06:47 PM
  #2072
Tom's Avatar
Tom
Phillips, I think I figured out what the problem is.
Nearly every post you make is completely ignoring speed. For example, this one:
Originally Posted by Phillips91
or those that are saying gearing doesn't give it an advantage, that it just puts it in its powerband, look at it this way. Take two identical v10 trucks and hold them at 3500 rpm. They are going to be making the exact same hp and tq. Put them in some kind of space age tunnel that only allows air to go into the engine(to eliminate the wind resistance argument for the extra 5-10 mph). Give one truck 4.30's and the other 2.73's. Which one is going to accelerate faster when you floor them both at 3500 rpm? They are making the same exact power, turning the same exact rpm, have the same wind resistance, but one of them will snap your head back and the other will crawl like a turtle. That extra acceleration comes from the gearing, not the hp. That's why giving the v10 4.30's and letting it run in 3rd gear isn't a fair comparison to the 3.73 diesel in 5th gear.
The truck with 2.73s at the same RPM would be going one and a half times FASTER than the one with 4.30s at the same RPM! Takes more HP to move the same mass a faster speed! Take that 4.30 geared truck and accelerate to the same speed the 2.73 one is. Now try it! The 4.30 truck would have to shift to O/D, and for whichever given speed we're talking about, the 4.30 truck would now have a disadvantage in gearing, as you'd have a reduction gear in there.
Can't ignore speed!
Now, let's try this again...
3500 RPMs/2.72 = 1287 RPMs at the rear wheels.
3500 RPMs/4.30 = 814 RPMs at the rear wheels. MUCH slower!
So, using that, let's see which theoretical ratio would get the 4.30 truck to turn the same speed...
814/x = 1287
814 = 1287x
x = 0.63
So you'd need a super tall O/D with a 0.63 ratio to get the same speed...right?
So let's get back into torque, but this time at the same road speed. We'll assume 425 ft-lbs here...
425 ft-lbs x 2.72 = 1156 ft-lbs at the rear wheel
OR
425 ft-lbs x 0.63 x 4.30 = 1151 ft-lbs.
The 5 ft-lb variation is due to rounding when I calculated the theoretical O/D gear necessary to get the 4.30 truck to go as fast as the 2.72 truck at 3500 RPMs.
See? Horsepower is the same, speed is the same, therefore Torque HAS TO BE THE SAME!
Old Sep 29, 2009 | 03:27 AM
  #2073
95_Dually's Avatar
95_Dually
Crazy, I see your formula and I believe it on paper. It must be true, but it is giving me a headache thinking about it.LOL
Old Sep 29, 2009 | 03:29 AM
  #2074
95_Dually's Avatar
95_Dually
I give up. The V-10 has more power and wins the competition. The diesel is at a disadvantage because it cannot turn 5000 rpm. I think I get it.
Old Sep 29, 2009 | 07:44 AM
  #2075
phillips91's Avatar
phillips91
Originally Posted by KelVarnson
Since you like to talk in terms of torque rather than HP, please explain to me how the 7.3 is producing 565 ft.lb. (24%) less rear-wheel torque at very close to the same speed, and can still out-accelerate the 5.4.
Truthfully, I don't doubt that your 7.3 is outpulling your 5.4, I just think the 5.4 is producing less horsepower than you think it is.
im just taking my hp and tq numbers from what ford says they make. both of them are 100% stock, so the hp and tq ratings should be what they were from the factory. the gear ratios, tire size and the rpms are a fact. there's no getting those wrong. your formula comes up with one result but my driving comes up with a totally different one.
ive tested my trucks every way imagineable and the 5.4 isnt even close to my 7.3. no way, no how. with my camper (26' and ~6k lbs) i can toy with it on hills in 5th gear that my 5.4 has to be in 3rd and 4th gear wide open just to maintain speed. theres one red light i get stopped at a lot thats at the bottom of a decent hill. with my 5.4 i have to start out in granny gear, run it pretty dang hard and top the hill in 3rd gear. if i hit 4th gear, its immediately back down to 3rd. just falls on its face. in 3rd it can accelerate, but i dont have to run it wide open. with my 7.3 on that same hill, i can top it in 5th gear without ever having to go over 2500 rpm. im not arguing that your formulas arent correct. i dont think youve made a mistake on them or anything like that. im just saying that formulas dont always translate to the real world.
Old Sep 29, 2009 | 08:35 AM
  #2076
Broncoholic1's Avatar
Broncoholic1
Originally Posted by mudmaker
That is the problem with trying to figure out the difference all on paper. Real world results do not always equal the perfect world on paper.
OK lets try Rock, Paper, Sizzorrs
Old Sep 29, 2009 | 08:39 AM
  #2077
alchymist's Avatar
alchymist
"Mifflin Clay"
Actually, someone should edit out all the BS & mis-information, and get us back to 10 pages........
Old Sep 29, 2009 | 09:10 AM
  #2078
Broncoholic1
22??!! Wow... My '02 7.3 consistently gets 14 mpg combined town and highway. And I never go over 70 mph.
It must be down hill both ways to work.
Old Sep 29, 2009 | 09:18 AM
  #2079
Tom's Avatar
Tom
Ah, that depends on the competition!
Realize for a minute that KelVarnson and I both own diesels. When I went up to Millersburg and met up with Monster-4 and i eat hybrids, we got to try them out. Wasn't a fair comparison to Monster-4's V10, as he had the older model with less power than the 3V V10 of the same generation as the '07 F150 and my '08 PSD we lined it up against. Still, it did a great job with that kind of load, and I really have lots of respect for the engine. I would have been really interested to see how a stock 7.3 would have done.
From what I've seen out of my 6.4, as well as the stats on paper, there's no doubt that the 7.3 will seem to have an easier time with a load. After all, it has the definite torque advantage, which translates to a horsepower advantage all through it's rev range. At the same revs, the V10 can not match the horsepower output of the turbodiesel. Therefore, the only time you'd realize a benefit to the V10 is when you crank it up over 3,500 RPMs and let it sing. Perfectly capable of doing it, and I think it'd do it all day long for many years without a problem. The fact still remains that the 7.3 will likely be a more pleasant engine to tow with.
Which doesn't mean the V10 can't do it, though!
Old Sep 29, 2009 | 09:19 AM
  #2080
phillips91's Avatar
phillips91
any time you want to ride with me just let me know. ill be more than happy to let you ride to and from work with me for as long as you want. im willing to back up my claim. you willing to come prove me wrong?
Old Sep 29, 2009 | 09:27 AM
  #2081
krewat's Avatar
krewat
FTE Leadership Emeritus
Let's just say that there's LESS of an advantage to the diesel than you think
Old Sep 29, 2009 | 09:35 AM
  #2082
SteveBricks's Avatar
SteveBricks
FTE Emeritus
Sure it can - but not for long
Old Sep 29, 2009 | 10:05 AM
  #2083
mudmaker's Avatar
mudmaker
If someone did that there would be nothing left of the thread but the title!
Are you guys actually taking this seriously??
Seems to me the only thing that guys are arguing about is hypothetical situations.
For me the PSD is the best available choice of motors in a Superduty.
Old Sep 29, 2009 | 10:17 AM
  #2084
R-WEST's Avatar
R-WEST
Holy cow!! 139 pages!!
Old Sep 29, 2009 | 10:29 AM
  #2085
krewat's Avatar
krewat
For YOU.
The real crux of the matter is that it's not the best choice for everyone.
With Ford losing the V10 in 2011 in the F250/350, and going backwards to an 8-cylinder 6.2L, they are making the choice for those who prefer the gasser.
Looks like I'm keeping my 2001 for the rest of my life
