Gas vs PSD
For those that are saying gearing doesn't give it an advantage, that it just puts it in its powerband, look at it this way. Take two identical v10 trucks and hold them at 3500 rpm. They are going to be making the exact same hp and tq. Put them in some kind of space age tunnel that only allows air to go into the engine(to eliminate the wind resistance argument for the extra 5-10 mph). Give one truck 4.30's and the other 2.73's. Which one is going to accelerate faster when you floor them both at 3500 rpm? They are making the same exact power, turning the same exact rpm, have the same wind resistance, but one of them will snap your head back and the other will crawl like a turtle. That extra acceleration comes from the gearing, not the hp. That's why giving the v10 4.30's and letting it run in 3rd gear isn't a fair comparison to the 3.73 diesel in 5th gear.
That's not the same comparison as comparing a V10 and a PSD.
Your example should be about two engines, one that produces "X" mount of torque at 3500RPM, the other that produces 2*X torque at RPM/2 (twice the torque at half the RPM), and one is geared at 4:1, the other at 2:1.
They would accelerate at the same speed. Theoretically.
Yes, when you step on both of them, the 4.30 truck will accelerate faster, because the gearing advantage will allow substantially more rear-wheel torque to be generated, but ALSO because the engine is not yet operating anywhere near its horsepower capacity.
Say that both trucks weigh 7,000 lbs, and they are both going up a 5% grade, both are in 3rd gear (1:1) and we are still ignoring wind resistance:
Tractive force required for both trucks: 350 lbs. (amazing what ignoring wind resistance will do for you). Assuming a 33" tire, that would be 481 lb. ft. of torque at the axle. So:
2.73 truck:
3500 RPM / 2.73 = 1282 wheel RPM.
(1282*481) / 5252 = 117 RWHP.
4.30 truck:
3500 RPM / 4.3 = 814 wheel RPM
(814*481) / 5252 = 75 RWHP
The truck with the 2.73's is using 56% more horsepower!
Now since we're ignoring wind resistance, let's also ignore gearing losses. Thus we can transfer the rear-wheel HP directly to the crankshaft:
2.73 truck:
(117 HP * 5252) / 3500 RPM = 176 lb.ft.
4.30 truck:
(75 HP * 5252) / 3500 RPM = 113 lb.ft.
(Someone please check my math)
The slower truck is using less HP. When you stomp on the gas, it has more to spare, and will thus accelerate faster. Of course, the difference between the two trucks will become more and more noticeable the closer you get to the HP limit.
lets just use my truck(225 hp at 3k rpm) as an example to simplify it even more. take out every variable like wind resistance and all that. i am back on my infinite hill again and you are going to keep adding weight as i go up the hill until i bog down. do you think i can pull more weight up the hill in 5th gear(3.12 final drive ratio) at 3k rpm and 225 hp or in 2nd gear(9.72 final drive ratio) and 3k rpm and 225 hp? in theory(like gassers like), if i can maintain that 3k rpm i should be able to pull the same amount of weight since i am making the exact same power. but in reality(what diesel guys like), the more weight you add the more i am going to struggle to maintain the 3k rpm and i am going to bog down much faster. why? because i dont have the gearing to keep the rpms up and i am relying solely on hp to keep me moving. in 2nd gear i get to rely on both gearing and hp to keep my rpms up and keep me at my peak power. in my example that is the same hp and a 3 to 1 gearing advantage, but it will yield totally different results. thats the same advantage the gasser gets when you all give it its 3 to 1 gearing advantage "just to get it in its powerband."
I wasn't challenging you or expecting to prove you wrong, just expressing amazement (and envy).
If you are consistantly getting 22 mpg you must be in the flat lands. My dad and I both had OBS psd w/ 3.55 rears and rarely saw 20. 18-19 was standard. You must be 2wd.
according to my numbers the 5.4 was making 232 hp at 3500 rpm and my 7.3 was making 162 hp at 2k rpm. at no point does my 7.3 make 232 hp, so it couldnt have been making more hp than my 5.4.
anything i say on here, i dont have one problem backing it up to anyone that wants to come along for a ride. whether it be mpg or the ability of my 7.3 to outpull my 5.4 even though its making much less hp.
A truck of the same weight, going faster up the same hill, is PRODUCING MORE HORSEPOWER. Just do the numbers on rear-wheel HP for the two trucks, and then tell me where this extra HP came from, if your 7.3 can't produce it.
5.4 was turning 3500 rpm(232 hp and 350 tq) and was in 3rd gear(1.61 tranny ratio) with 4.10 rear end(6.6 final drive ratio).
7.3 was turning 2k rpm(162 hp and 425 tq) and was in 4th gear(1.0 tranny ratio) with 4.10 rear end(4.10 final drive ratio).
run the numbers on those and tell me what you get. what i get sitting in the seat is the 5.4 will not hit 4th gear and the 7.3 hits 5th no problem.
both trucks also have the same size tires. 265/75 16's. both are regular cab long beds. i would say the weight is even too.
On the 5.4, the rear wheels are turning 530 RPM, which is 49.9 MPH, and are producing 2308 ft.lb. of torque.
On the 7.3, the rear wheels are turning 488 rpm, which is 45.9 MPH, and are producing 1743 ft.lb. of torque.
Since you like to talk in terms of torque rather than HP, please explain to me how the 7.3 is producing 565 ft.lb. (24%) less rear-wheel torque at very close to the same speed, and can still out-accelerate the 5.4.
Truthfully, I don't doubt that your 7.3 is outpulling your 5.4, I just think the 5.4 is producing less horsepower than you think it is.
The only thing I would add is that you solved for axle torque and I would just add in tractive force so the tire size will be included. In this case, both tires are the same so it doesn't matter for comparison purposes but it does show the amount of force the tires are actually exerting on the ground to move the truck. In this scenario, I came up with 1,751 for the 5.4 and 1,321 for the 7.3.
