Sponsored by: Real Truck
Gas vs PSD
Old Sep 26, 2009 | 11:15 AM
  #1966
KelVarnson's Avatar
KelVarnson
Originally Posted by Rush117
He doesn't come on until 10:00 pm. I am rarely driving around that late. Now if they'd swap Laura Ingraham and Mike Church, I'd be a King Dude listener!
I hate when they do that. And no one around here carries Glenn Beck, and I don't have cable, so I don't really know anything about that guy.
Lets assume a heavy trailer on the truck and after exhaustive math, we determine that it will take 7,000 lb ft of axle torque to get it moving up the hill. Speed is irrelevant because the hill is short and once we get to the top, the amount of force required will significantly decrease. So we have a truck with a 6.4, 3.11 1st gear ratio and a 3.73 diff. At 650 lb ft of torque at the flywheel, this truck will produce 7,540 lb ft of axle torque and the truck and trailer start climbing the hill.
Now lets put a V10 in the truck. With the same drivetrain and 457 lb ft of torque, this truck produces 5,301 lb ft at the axle and the truck starts moving backward. So lets fix this problem by giving the V10 4.30 gears. Now it produces 6,111 lb ft, still moving it backward. If we keep giving it steeper gears, we have to go over 4.88 to get our 7,000 lb ft. Just in case you're interested, the 6.4 with 4.30 gears will produce 8,692 lb ft. in this scenario.
The V10, however, will pull harder at 70 mph than the 6.4 will due to hp differences. Sometimes torque is better and sometimes hp is better.
That is a great example. And clearly, the diesel if going to have an easier time getting the load going.
My only nitpicking would be that you should be using the horsepower peaks for each engine to determine what the ultimate rear-wheel torque would be. Although it doesn't really matter in this example, because you'd have to spin the V10 way up to get there, and with a static non-moving load, that's going to mean a ton of torque converter loss.
Did they make V10's with manuals that had a granny gear, and if so, what was the ratio? 'Cause someone's going to jump in with that scenario, probably.
Old Sep 26, 2009 | 11:17 AM
  #1967
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by mudmaker
Here's one for ya Bill. Don't know how much it weighed, but when I let it down on my pickup I thought the hitch was going to hit the ground. Good think I have that heavy psd up front!
nice! how did you end up needing to towing it?
I have always wanted to do that with my V10, but I have never gotten the chance.
Old Sep 26, 2009 | 12:13 PM
  #1968
Broncoholic1's Avatar
Broncoholic1
My apology to Bill11012 I guess 17 is OK
Originally Posted by Broncoholic1
OK Just Stirrin the pot got a little crazy
17 == Not enuff gray material yet...
I just thought it irresponsible to tow 12K with a bumper, Then brag about it on the intraweb...
Carry On gentlemen.. I was beside myself thought he was at least 23 === My Bad...
Originally Posted by 04redstroker
So your sayin that because im under 23 that im dumber then you too? Not tryin to start anything, just tryin to under stand what your point is.
You do not tow 12K @ 95 on a bumper do you? Just spewing when you are 17 is a little overrated. Like the neg reps & all for others. Now I bet I get one
Sorry if I got your dander up. Lets all protect Bill...He can't drive 55...
Originally Posted by SteveBricks
Like Marc said - you need to slow your roll a bit, dude.....
It was a long night out pickin up the 79 F350 I over celebrated it was ain the shop..
Originally Posted by Crazy001
I joined FTE when I was 17.
Looks like I've been here 6 years longer than Broncoholic.....
If I keep it up I will get banned
Originally Posted by bill11012
nice! .
Sorry Bill if I offended you last night...I got my warning.
Carry On as usual. My Cummins will out pull your V10 My V10 too..
Old Sep 26, 2009 | 01:33 PM
  #1969
95_Dually's Avatar
95_Dually
That sure looks like a LOT of tongue weight. I don't know that I would have even tried that with my truck.
Old Sep 26, 2009 | 01:40 PM
  #1970
alchymist's Avatar
alchymist
"Mifflin Clay"
That's not a heavy load; this is:
Old Sep 26, 2009 | 01:49 PM
  #1971
95_Dually's Avatar
95_Dually
Somewhere there is a tire shop waiting for this to roll in so they can retire.
Old Sep 26, 2009 | 02:13 PM
  #1972
AlaskaJeff's Avatar
AlaskaJeff
Hay Alchymist where were you in SAC?
Old Sep 26, 2009 | 02:17 PM
  #1973
mudmaker's Avatar
mudmaker
You need a sirius. He is on the three hours prior to Wilkow. Great way to start my mornings!
It was a lot of tongue weight. When we had the trailer delivered we had to set on the back of the property so we would have room to set the batch plant up. Got tired of waiting for the toter to arrive so figured I would see if I could move it. I let the jack down and only had about 2 inches of clearance to the ground when the suspension finally quit squatting. I only had to move it about 300 yards. I should have taken the bets offered when I backed up to it, but honestly didn't think I had enough springs to keep it off the ground.
Old Sep 26, 2009 | 02:31 PM
  #1974
bill11012's Avatar
bill11012
Bill, it is ok that you are 17. We were all your age once. Believe me that in 17 more years your views will not be the same as they are today. You might even find yourself driving a diesel and liking it more than a gasser.
I have both an 83 460 and an 84 6.9 and the diesel is better
So that has kind of already happened, just not with the power stroke vs V10 thing.
Old Sep 26, 2009 | 02:39 PM
  #1975
bill11012's Avatar
bill11012
Its fine, You did not offend me.
I will not give you bad rep, I did that one time to that troll.
I am not going around doing that to everyone that says something i dislike.
Do you have a thread for the cummins swap?
I would love to see what you are doing with it.
And no, stock to stock a V10 will out pull it.
You saying that will makes me wander what you are doing to it.
Old Sep 26, 2009 | 02:42 PM
  #1976
bill11012's Avatar
bill11012
I would only do it with a DRW truck.
Old Sep 26, 2009 | 03:11 PM
  #1977
alchymist's Avatar
alchymist
"Mifflin Clay"
4135 Strat. Wing, later 39th Bomb Wing. Eglin AFB 1960-64
AFR Minn.-St. Paul Comm Sqdn 1973.
Old Sep 26, 2009 | 03:34 PM
  #1978
KelVarnson's Avatar
KelVarnson
Check out this load. It was on its way to our local nuke plant, but they had some kind of mechanical failure and had to leave it parked in our town for a night or two.
One truck pulling, two trucks pushing. You will notice that there are a couple of operator cabs on the rear of the rig. Each had a steering wheel, so I guess they can really manipulate this thing.
Old Sep 26, 2009 | 03:39 PM
  #1979
Rush117's Avatar
Rush117
So, let me ask again, what would happen if the V10 did have a 10 (or even a 6) speed transmission. Lets say a 5.1 first gear ratio, followed by 4.2, 3.4, 2.6, 1.1, and .7 od. (Nothing calculated, just grabbing mumbers).
In my example, a V10 with a 5.1 first gear would yield 8,693 lb ft of axle torque which is roughly equivalent to a 6.4 with 4.30 gears and a stock transmission. You give the V10 4.30 gears and it will produce a monstrous 10,022 lb ft at the axle. In fact, in my scenario, you wouldn't even need first gear to get moving. Second gear would get you moving even with 3.73's at the rear. You'd have an outstanding pulling machine with such a transmission. However, you'd still be operating at a higher rpm once you were moving at highway speeds, but that kind of power down low, what difference would it make?
I think the important thing that this thread has shown is that you have to go to extreme examples to show one is better than the other. There may be a few of us, myself not included, that go to those extremes. Either engine is fantastic in an SD.
Now with the 6.7 coming out, I may have to move up my 6.0 trade in schedule!
Old Sep 26, 2009 | 03:44 PM
  #1980
Tom's Avatar
Tom
That's the biggest heavy haul setup I've ever seen, KelVarnson!
Figure max 20,000 lbs for each axle, 14 axles...could weigh as much as 280,000 lbs for the whole rig, excluding power units.
Amazing.
