Crewcab Only Thread.
Old Jan 25, 2013 | 03:37 PM
  #2086
crash1's Avatar
crash1
A zf5 and e4od is the same bell housing on the later 460's
Originally Posted by cali77
Hey guys, I am new to this fourm so i would like to begin by saying thank you for creating such a useful tool!!! I currently own a 1977 Ford F250 crew cab (pics to follow) with a 400 6.6L and C6 transmission. I love the truck and recently rebuilt the engine (pics also to follow). I will be replacing the gear ratio soon due to the engine running on high Rpm at 55 MPH....
I did recently buy a gear vendors overdrive off of Craigslist but do not have the C6 transmission adapter. The unit came with the turbo 400 adapter. I need help finding the right adapter for my C6... does anyone know where I can buy one?
Thanks guys and keep an eye out for my pics!
Old Jan 30, 2013 | 07:06 PM
  #2087
blacktundra10's Avatar
blacktundra10
Need some help with fitting some nerf bars. I have a '75 cc, 4wd that is about to be fitted with some 35" tires. It's hard enough to get into now, but after the tires I will either need a ladder or bars. I'm looking at these from N-fab, but don't know how much fabricating I will have to do. Anyone have any experience with mounting these to our trucks?
Old Feb 2, 2013 | 02:16 AM
  #2088
70 Bronco TX's Avatar
70 Bronco TX
STARMILT: Your in box is full, so...
Did you ever make anything of the crew cab out of Silverton, TX? Just thought of it now and wondered if it turned out to something good.
Dan
Old Feb 5, 2013 | 08:52 PM
  #2089
grinnergetter's Avatar
grinnergetter
I'm working on my 72 CC and my truck has plates welded to the side of the frame.
90% looks pretty good with the exception of the area by the rear leaf hangers. I was removing CM's today and quite a bit of flaky rust fell out of there.
So, I have considered two options.
I can remove the plates and coat it with rust preventer then reweld the plates back on...which burns off the preventer...although that doesn't sound very fun.
I could soak it with rust converter(technically should be top coated) and I thought about seam sealing or welding the top edge to keep dirt from accumulating in between the plate and frame.
I'm planning on boxing the frame to some extent and I really want to keep the plates as the truck is getting a diesel.
Thoughts appreciated, Grin
Old Feb 11, 2013 | 02:06 AM
  #2090
Fameus's Avatar
Fameus
Hey guys, I'm new on here. Just bought a 74 f350 crew cab. Where do you guys buy your body parts like floor pans, cab corners ect.? I've looked on LCMtruck.com but the parts I seem to find are for all others except crew cabs. I wouldn't think that the cab corners are the same for crew cabs, correct me if I'm wrong.
Old Feb 11, 2013 | 09:21 AM
  #2091
fordtrucknut's Avatar
fordtrucknut
Cab corners are the same on a crew as the regular cab trucks...other parts it... just depends what piece you need...some things are crew specific like roofs...and are not reproduced at all
Old Feb 11, 2013 | 11:41 AM
  #2092
Pitcrw6's Avatar
Pitcrw6
Check out Dennis Carpenter also. Cab corners are the same but I think DC has a thicker metal. Someone will correct me if im wrong.
Old Feb 15, 2013 | 05:12 PM
  #2093
abyars111's Avatar
abyars111
Does anyone have any pics of a black crew cab? We are having a hard time deciding on a color for our 1970 Crew. We are thinking of black.
Old Feb 15, 2013 | 10:20 PM
  #2094
Higbean's Avatar
Higbean
Google. Easy.
black 1978 ford crew cab - Google Search
Old Feb 16, 2013 | 03:56 PM
  #2095
78bigunns's Avatar
78bigunns
What about a internal sealer/paint? Trying to picture what you're typing...but weld it up and leave a access hole you could plug up with a rubber or plastic plug?
Internal Frame Coating w/Spray Nozzle | Eastwood
Then top coat the outside.
Old Feb 17, 2013 | 06:11 PM
  #2096
crazyredneckanyhow's Avatar
crazyredneckanyhow
78bigunns can you measure how wide your rear tires are outside to outside?
Old Feb 17, 2013 | 07:08 PM
  #2097
78bigunns's Avatar
78bigunns
Right about 84". I couldn't get the tape to grab the edge of the tire, but it's dang close. Probably closer to 83" if you need it dead on.
I'll try again tomorrow when the wind isn't blowing.
Old Feb 17, 2013 | 07:26 PM
  #2098
crazyredneckanyhow
Ok. And youve just got a flare right? Ive got a pickup dually axle and im at 91" right now. Im gonna need a fender.
Old Feb 18, 2013 | 10:28 AM
  #2099
78bigunns's Avatar
78bigunns
Yessir. Someone said it was a bushwacker, but I have never looked into it.
Mine was originally C&C though, and those axles are narrower aren't they?
If I did the 4x4 conversion I was thinking of searching out a matched pair of axles, but then I'd need some fenders too if they were off a dually pickup versus a dually C&C.
At least thats what I thought anyhow. Still haven't made up my mind on that yet.
Old Feb 18, 2013 | 08:13 PM
  #2100
grinnergetter
Yea, sorry I might not have been clear enough....the plate is welded to the outside of the frame so there is no way to get the paint inbetween. I had to cut a small section off to mount the shackle hangers for the front leafs and it didn't look too bad...I think I'm going to leave it as is.
