Crewcab Only Thread.
Old Nov 9, 2012 | 01:43 PM
  #1966
Moonpie6899's Avatar
Moonpie6899
Thank you for the correction crazy redneck, not sure how I came up with 155 when the 150 is right on the door plaque. Lol.
Old Nov 9, 2012 | 02:36 PM
  #1967
73f250highboy's Avatar
73f250highboy
isnt the rear glass the same as the front? lol
Old Nov 9, 2012 | 08:12 PM
  #1968
crazyredneckanyhow's Avatar
crazyredneckanyhow
Id kill to have either of those trucks
Old Nov 10, 2012 | 02:09 AM
  #1969
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I had a guy that was gong to drive down from Iowa to get one of them a while ago, he never showed up? They have been in my local JY for years loosing parts every so often.
Both have titles and would be sold for the current $ on the lb for steel, I imagine. They are located in Humansville Missouri, want there #?
Old Nov 10, 2012 | 06:08 AM
  #1970
crazyredneckanyhow
Yeah. Doubt itll work out but it doesnt hurt to try.
Old Nov 10, 2012 | 09:45 AM
  #1971
77&79F250's Avatar
77&79F250
Scott's Salvage Yard
Address: 3406 South 30th Road, Humansville, MO 65674
Phone: (417) 754-2305
The women that answer the phone have no idea what is out in the yard, (cause there is so much) but you can ask about a title and if you wanted to buy a complete truck what it might cost.
All you need now is a truck, trailer, time and cash and its yours. Depending on when it is I can meet you there and help load it, and get the rear door panels back to you.
It not that bad a drive from WV, bring enough trailer and cash for both.....
Old Nov 11, 2012 | 12:14 PM
  #1972
InfoWarrior's Avatar
InfoWarrior
Opinions/Suggestions Wanted: F250 SuperCab 4x4 Resto
Hey Guys,
I just bought a '76 F250 SuperCab Shortbed 4x4 w/a 460. It received a shorter VIN when the salvage title was issued to the previous owner but I'm guessing it was originally a reg cab long bed originally. Here is the VIN so maybe you guys can tell me what this means I have if that's even possible with a salvage title: (F10YKD049xx) I believe it to be either a '77 or '78 cab and was switched to a short bed. I think the gas tank on it is a 17 gal and I would like to put the oversized tank for sale from LMC Truck on it to increase my range. I plan to relocate the spare for it to fit. Can you guys tell me if this should fit given the info I have provided and if so, do you have any helpful hints for this project?
I am also stripping down the paint, gonna inhibit the rust with some product that you suggest and have painted in the spring. Gonna grind down the little **** that hold the clips on and finish w/out the trim down the side. I am taking pics and intend to start a tread on my project when I get a little more time but needs a little help in the meantime. I plan to remove the back set and either raise it up on a box for my amps and sub unless you guys have some other seat suggestions that might have merit. Probably just gonna recover the fold down bench seat in front instead of buckets or something more modern because my girl likes to ride bitch...and I wouldn't want to rock that boat.
Again, any suggestions you have would be appreciated.
Thx
Newbie Edit: Sorry Guys...just realized this was CrewCabs only...I just have a lowly SuperCab...my bad.
Old Nov 11, 2012 | 03:09 PM
  #1973
crazyredneckanyhow
Picking this up next weekend. traded an 89 model 60 front and 300 cash for it.
Old Nov 11, 2012 | 04:51 PM
  #1974
Pitcrw6's Avatar
Pitcrw6
Nice. Does it run?
Old Nov 11, 2012 | 04:53 PM
  #1975
crazyredneckanyhow
negative. itll be getting a 12v cummins anyway. The nice thing is that other than the floors needing patched theres no rust holes. Most likely ill clean up the surface rust and let it go the way it is.
Old Nov 11, 2012 | 04:56 PM
  #1976
crazyredneckanyhow
Got a tailgate the same color blue waiting here for it.
Old Nov 11, 2012 | 05:00 PM
  #1977
Pitcrw6's Avatar
Pitcrw6
Its a shame that people let these trucks get that way.
Old Nov 11, 2012 | 05:07 PM
  #1978
crazyredneckanyhow
yeah. ill clean it up after i get the motor swap done. its got a 44/60 with 410s. no drivetrain in it. 4" lift and 36s
Old Nov 12, 2012 | 02:27 AM
  #1979
77&79F250's Avatar
77&79F250
Still a good deal IMO. In your first pic the front end (body panels/hood&fenders) looks to be sagging. The dent line is off or is it just me?
Old Nov 12, 2012 | 05:44 AM
  #1980
crazyredneckanyhow
He did a body swap and said the body isnt bolted down. Im guessing some of the bushings are missing.
