Literallynothing's Build Thread
Old Jul 31, 2021 | 08:32 AM
  #331
literallynothing's Avatar
literallynothing
Originally Posted by Edgethis
I got it installed, I think I did have the factory obs bracket at one time. Pretty much just duplicated the other sides brackets and then modified accordingly to make the fit. The brackets mount on the front leaf spring bolts.
looks great! Hopefully it helps a bunch
Old Aug 1, 2021 | 07:02 PM
  #332
literallynothing
Truck is back together and running well. I do still have a boost leak… it’s the plenum. Specifically, the drivers side at the rear under the turbo pedestal. So I put the front of the truck back together since it’s driving well, and might pull the turbo and reseal it soon. But that says a lot to me about the kc balanced assembly. Able to easily hold 24psi even with a boost leak. Makes me excited to see what it can do with the leaks all sealed up
Old Aug 1, 2021 | 08:09 PM
  #333
Edgethis's Avatar
Edgethis
New plenums! Would be nice, but resealing is easy and far cheaper. Make sure you use the correct TA31 stuff and it'll be cake.
Old Aug 1, 2021 | 08:47 PM
  #334
literallynothing
for now it’ll just be a reseal, when I go to a T4 setup I’ll get new plenums to fit the larger intake y pipe diameter
Old Aug 2, 2021 | 05:20 AM
  #335
TheFecalFanatic's Avatar
TheFecalFanatic
Riff Raff has the o ring plenum for 2" intakes now too....
Old Aug 2, 2021 | 06:20 AM
  #336
Edgethis's Avatar
Edgethis
He wants to have his holes reamed out bigger then 2".
There has to be a market for the 2" plenums but id imagine most looking to go billet plenums already have upgraded to needing larger.
Old Aug 2, 2021 | 06:26 AM
  #337
TheFecalFanatic
Maybe, maybe not. If Clay released these last year I would have skipped the T4 idea altogether and went with a KC stage 1.
Old Aug 2, 2021 | 07:35 AM
  #338
Edgethis's Avatar
Edgethis
Wouldn't the larger plenums benefit the drop in KCs as well? Or is the larger plenum in the way?
Old Aug 2, 2021 | 07:40 AM
  #339
TheFecalFanatic
I think the only 3" plenums you can fit are the Irate ones since the obs and E99 turbo sit low in the valley. Could probably fit the stock SD plenums if you dented the back part of the hole too.
Old Aug 2, 2021 | 08:50 AM
  #340
literallynothing
Oh I know, if I wasn't planning on larger holes I would be ordering a set right now. But oh well, I'm going to leave it alone for a little while. My dog messed up her knee, so all fun stuff is now on hold until I pay someone to fix it, which will cost about 10x the price I paid to get the dog
Old Aug 2, 2021 | 08:57 AM
  #341
TheFecalFanatic
You and me both. My cat decided to eat part of a shower luffa and now she can't keep food down..... Thats going to be a fun bill
Old Aug 2, 2021 | 03:48 PM
  #342
literallynothing
Not fun at all. The same dog with the bum knee ate a large rock a few years ago... 4 days of laxatives finally got her to pass it through in the 11th hour before surgery
Old Aug 2, 2021 | 03:55 PM
  #343
literallynothing
Looking into some options for the pre pump side of the fuel as I change out my tank(s). With the new 38gal plastic tank out of the 6.0, I'm considering ditching the factory sending unit all together and going to a G&R sump which has an integrated return. If I do this, I'll add a Racor PS120-02 filter between the sump and the pump. Thinking with the addition of a plastic tank and a sump kit, I can never worry about a rusty tank, or broken sending unit on the front tank. When I eventually get around to grabbing a 38gal rear tank, I'll probably add a sump there too. I just need to take a look as I don't remember exactly where my tank selector valve is in relation to my fuel pump. It would be easier to install the filter kit on the pump side of the selector, but with how pricy those selectors are, I would be a little concerned running unfiltered fuel through the selector all the time, but in order to filter before the selector, I would need a filter for each tank. Any thoughts on which side of the selector I should filter? Also if anyone is currently running a pre-pump filter, what micron level are you filtering to?
Old Aug 2, 2021 | 05:01 PM
  #344
Edgethis's Avatar
Edgethis
My Cat water separator is 10 micron, thats pre pump. The post pump filter is 2 micron.
Old Aug 3, 2021 | 07:33 AM
  #345
TheFecalFanatic
There is a wix filter in the sticky section of the SD forum that filters as well as the shower heads. I don't run anything, I deleted the in tank stuff and rely on the pre pump filter after the selector without issues.
