Literallynothing's Build Thread
Old Jul 10, 2021 | 12:02 PM
  #271
literallynothing's Avatar
literallynothing
Originally Posted by z31freakify
IMO I would do a stock rebuild with ARP head studs, unless you plan on pushing big power then start looking more into the higher end of stuff.
if you can source cheap I would do super duty fuel system, it's reliable and from what I've read it's more than capable of supporting 400hp+
I have an Irate Diesel system with regulated return already, unless you’re talking about something internal that I didn’t know was different between the SD and OBS trucks?
Old Jul 10, 2021 | 12:23 PM
  #272
Edgethis's Avatar
Edgethis
Thats what he's talking about. Nothing internal.
I agree that a basic rebuild with some preventative parts like the dipstick adapter are the best option.
Big power requires big money on these engines. A set of ported heads is like $5500!
Old Jul 10, 2021 | 01:13 PM
  #273
literallynothing
yeah that’s what my research last night showed me… seems like it’s a basic rebuild and then turbo and injectors are really all you can do before you have to shell out $10k+ to make more power
Old Jul 10, 2021 | 02:12 PM
  #274
Hit Man X's Avatar
Hit Man X
Have all the rods balanced within a reasonable weight, +/- 1g is pretty common I believe. Small end has bushings, cheap to replace. ARP rod bolts requires big end resized, easy. Then entire rotating assy balanced. ARP main studs will require a basic line hone of the mains.
One of our members, 427fordman I think, showed how far out of balance a stock bottom end is from the factory. Shocking really.
I would put my cash there, can do turbo and injectors later.
Old Jul 10, 2021 | 02:30 PM
  #275
TheFecalFanatic's Avatar
TheFecalFanatic
Should get de lipped pistons too. I just had welding rod catch under the lip and bend through the GP hole while trying to find TDC on my engine. Freaked me out pretty bad when it didn't want to come back out...
Old Jul 10, 2021 | 03:31 PM
  #276
literallynothing
I was actually just starting to think about getting things rebalanced. Found out there is a race motor builder 20 mins from me that has good reviews and does all sorts of machine work and balancing
I thought I read somewhere that delipped pistons are for like 600+ hp motors and can cause excessive smoke? Maybe that was something else I read about
Old Jul 10, 2021 | 04:12 PM
  #277
Hit Man X's Avatar
Hit Man X
I remember from my 6.4 days, all aftermarket short blocks it was highly recommended for hot spot reduction as I recall on piston face. We did Maxxforce 7s usually.
All I know is put cash into bottom end. Rest can always be done later.
7.3forever is doing a serious build too I recall.
Old Jul 10, 2021 | 08:06 PM
  #278
TheFecalFanatic
@7.3 forever's build is awesome. Got some serious engine and truck **** going on over there.
Old Jul 10, 2021 | 08:57 PM
  #279
Edgethis's Avatar
Edgethis
You all got some pretty sweet builds going on! Heck, Spring Man has 2! Mines boring and not even in the 7.3 forum. Mods said it wasn't cool enough.
Old Jul 10, 2021 | 09:12 PM
  #280
TheFecalFanatic
That megacab of yours would have been drooled over in this forum..
Old Jul 11, 2021 | 11:28 AM
  #281
oldbird1965's Avatar
oldbird1965
I was worried about something like that so I just used a straw.
Old Jul 11, 2021 | 11:31 AM
  #282
oldbird1965
I don't know what I'm talking about but a piston coated will help with heat, I think. I blew a hole in a piston once so If I ever rebuild I would get the coating.
Old Jul 11, 2021 | 11:32 AM
  #283
TheFecalFanatic
Did you stick it down the GP hole or the injector cup?
Old Jul 11, 2021 | 11:57 AM
  #284
oldbird1965
Injector cup hole I think, its been awhile.
Old Jul 11, 2021 | 06:02 PM
  #285
literallynothing
After reading through his thread, I think I’m going to buy another long block for cheap and build that and just drop it in since I’m basically doing all new accessories anyways excluding turbo, injectors, and HPOP. Might be able to get a decent chunk back by selling the old motor
