Literallynothing's Build Thread
Old Oct 3, 2021 | 03:47 PM
  #421
farmert's Avatar
farmert
Originally Posted by Hit Man X
Six speed has a cooler due to internal pump as I understand. Mind the line locations so you can replicate.
Does it use same flywheel and clutch setup? How about that spacer adapter?
The NBS trucks with the ZF6 did not use the dual mass pieces of crap that the ZF5s got. They used a single mass, and if I'm not mistaken the input shaft is larger than on 6 spd., I know the output shaft is larger. Also the ZF6 does not use the spacer between the block and the tranny that the ZF5 uses.
Old Oct 3, 2021 | 04:16 PM
  #422
427 fordman's Avatar
427 fordman
Nice find! I run 550 springs on mine. There is not much give. It hauls 18000 lbs nice, but empty it is rough. I don't drive it much though, just towing. It really isn't a lot worse than my stock 97, surprisingly. These trucks ride pretty rough in stock form anyway.
Old Oct 3, 2021 | 06:02 PM
  #423
literallynothing's Avatar
literallynothing
yep, I pulled the cooler lines before the trans. Uses a different flywheel/clutch than the zf5, and I have the correct adapter which is smaller than the zf5 adapter
  #424
literallynothing
that’s kind of my thought, how much worse than stock can it really be? Haha
Old Oct 3, 2021 | 06:03 PM
  #425
literallynothing
Oh, @Khan and @Hit Man X guess what the guy had laying around and gave me for free!
Brand new company 910 valve springs!
Old Oct 3, 2021 | 06:10 PM
  #426
TheFecalFanatic's Avatar
TheFecalFanatic
give me a ring when you want to bs and grab a beer and do valve springs. I still have that valve for the heater core block off if you want it
Old Oct 3, 2021 | 06:30 PM
  #427
literallynothing
Will do! I’m booked the next 3-4 weekends, but I’m hoping to do the springs, pushrods, and some misc uvc stuff before winter. I’ll definitely let you know when so that you can come drink my beer
Old Oct 3, 2021 | 06:34 PM
  #428
TheFecalFanatic
I'll let you do the heavy lifting on the springs! They aren't bad with the actual tool though. Should be easier a second time around since I've done them lol
Only problem child is #7. Have to remove the evap box
Old Oct 3, 2021 | 07:12 PM
  #429
literallynothing
Sounds like a plan! My last couple of projects my neighbor hung out and got frustrated watching me fail and just took over, so it wouldn’t surprise me if the same happened on this project haha
Old Oct 3, 2021 | 07:13 PM
  #430
TheFecalFanatic
Long as there is beer and good times involved we will get it done man!
Old Oct 12, 2021 | 02:37 PM
  #431
Hit Man X's Avatar
Hit Man X
Just saw this, glad to hear you have springs now!
Old Nov 26, 2021 | 09:56 PM
  #432
literallynothing
Well, the last month or so has been nuts in terms of how much garage time I’ve gotten (I suppose that tends to happen when you no longer have a girlfriend to entertain lol). First garage project was to organize the damn place. My roommate pulled the diffs out of his 4Runner in the middle before we moved in expecting parts in 2 weeks…. More like 4 months later it’s out. Left bay will always be for projects and tools. Middle bay is for the roommates 4Runner and major projects, and right bay is for the Tacoma unless the middle bay has a big project, then my roommate will park there. And the back portion is full of parts.
Almost immediately after it got organized and cleaned, a friends motor popped in is 1989 4Runner. Block should be back from the machine shop on Monday for reassembly.
AND, what you all would care about! This morning I was feeling unmotivated while babysitting trades at work, so I went online and printed the service manual for a 1999 ZF6. Came home and cracked it open. Rollers from bearings fell all over the place when I pulled the center section out. And holy hell, that thing is heavy. I’d guess the middle section is at least 225#. Got to the point where I need jaw pullers with 10” of reach. The ford puller is $330, so I’m going to see if I can make some extensions for the rental puller I grabbed from autozone. Can’t say I know what I’m doing, but it definitely has been a more simple process than I anticipated. The case will get pressure washed tomorrow, and hopefully I’ll finish pulling the gears and synchros off so I can order a rebuild kit that has everything I need!
Old Nov 27, 2021 | 09:59 AM
  #433
BBslider001's Avatar
BBslider001
Nice work on the garage....and the ZF-6 disassembly! Looking forward to seeing how it plays out.
Old Nov 27, 2021 | 10:05 AM
  #434
TheFecalFanatic
I want a ZF6.... I am just green with envy over here
Looks good though!
Old Nov 27, 2021 | 10:21 AM
  #435
Hit Man X's Avatar
Hit Man X
Thumbs up
Neat! Are you doing just bearings and syncros? Does it use three shift rails? I must be overlooking an internal for OD and R, as they are on the back side of the case. I can pick out gears 3 and 4 (direct) for sure as well as what I believe are 2 and 1, counting Low as its own separate. Low should be the largest gear on the mainshaft and 5 the smallest which I guess is right against the center support?
Getrag ODs (well the strong 265/6s) use a center plate like this ZF, which is a center support in that case.
I never finished my write up rebuilding my S5-47, maybe I should. 30k later or so, still no issues!
