Also when ever you make it to the race, come across the pit area, we have parking spots on the racer side fence. We actually just got 2 more for a total of 3. We are between the stands, you'll see a excursion pulling a red jeep Comanche, and then 2 94/95 F350 dually's those are our spots.
this will be one of the 350s.
If you have any troubles finding the track, or our spots shoot me a text 252-342-4940.
10-4 we are leaving here about 7-8ish, hopefully be in the area by 2ish.
Well this morning I had the heater core I put in last month blow out. Replaced it, seems ok. Hope it's not another underlying issue like a head gasket.
The one I put in the Ranger last Fall worked great all winter, now smells like it's pissing a little coolant. Inspection to follow...
Got coolant drained and refilled in Big Red. I could kick myself for not putting pet***** in the block last time...
The 350 got a little attention today. Pulled the doors off, the door seals, hinges and striker bolts. Taped up two door openings, got two more to go, just need to find another roll of tape. More sanding and just a little closer to priming the cab. Really getting restless on wanting to spray some color on everything. Also behind where I wanted to be. :/ But she's moving along which is better than nothing.
