Official NCFTE Works Thread
Old May 13, 2016 | 03:58 PM
  #181
Benztechnc's Avatar
Benztechnc
Started on the steering gear box for the jeep last night. However had to take a beer break with Bob, since I don't have a pitman arm puller. I'll get back to it this weekend.
Bob, ignore the box of cotter pins in the back of the shot... I wouldn't really replace missing cotter pins.
Old May 14, 2016 | 06:59 AM
  #182
ubereal2's Avatar
ubereal2
You know how I feel about Cotter Pins
Old May 14, 2016 | 02:22 PM
  #183
77mud's Avatar
77mud
Finally took the time to fix the tie rod, ended up having to pickup a new adjustment sleeve aswell.
Just to give you a little idea of how bad it was, and I had straightened it some.
Old May 16, 2016 | 11:00 AM
  #184
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
Dang. Looks like my excursion front end. Glad you got it fixed.
Can anyone help me with some mild welding? I'll pay for supplies and time. I need to weld a few pieces of 14ga 1" square tube together. Real simple stuff. No long beads. No miter joints. I'll have all the material. I just don't have a welder.
I have the plans and parts list if that helps. I'm thinking it shouldnt take very long to do the welding. I need to drill some holes and other odds and ends but can handle that portion.
Thanks.
Old May 20, 2016 | 07:39 AM
  #185
Cracker289's Avatar
Cracker289
Thanks.
I can help you out but I have to warn you that I'm not a pro, I can't make those pretty beads like you see all the fancy TV stars doing
Old May 20, 2016 | 10:07 AM
  #186
ubereal2's Avatar
ubereal2
Can anyone help me with some mild welding? I'll pay for supplies and time. I need to weld a few pieces of 14ga 1" square tube together. Real simple stuff. No long beads. No miter joints. I'll have all the material. I just don't have a welder.Thanks.
I weld decentl just don't have a welder anymore.
Old May 21, 2016 | 10:56 AM
  #187
Cracker289's Avatar
Cracker289
I use flux core wire so it's never going to be as pretty as as pro! But I can stick 2 pieces of metal together and sometimes that's all you need to do
Old May 22, 2016 | 07:06 AM
  #188
ubereal2's Avatar
ubereal2
The welder I had used the flux core wire. It sure makes an ugly weld if you want to run beads.
Old May 22, 2016 | 02:15 PM
  #189
77mud's Avatar
77mud
Yes they do, I have a little 90 amp Flux wire welder from harbor freight, hard to make a pretty weld, but it works for the small stuff.
We also have a big 220 Lincoln stick welder but that don't get broke out often.
Old May 23, 2016 | 01:21 PM
  #190
ncheavymetal
FTE NC Chapter
Doesn't need to be pretty. Just needs to be square and hold.
It's 1" square, hollow tube and 1" angle. Need a couple of squares formed with tube and butt welded together with a support on each side. Should be pretty simple. I just don't have any equipment or skills. I figure I can grind any ugly off. The whole thing will be painted. And most of it will be covered in wood. So it won't show much.
Be glad to buy welding materials and pay in beer or food and help.
Old May 23, 2016 | 02:33 PM
  #191
Cracker289's Avatar
Cracker289
I can do it for you, you want to bring it by me or do I need to come by you?
Old May 23, 2016 | 04:13 PM
  #192
Benztechnc's Avatar
Benztechnc
Mine is also flux core, with the same issue. I won't do structural or welds that people will see with it. Ive been trying to get my hands on a shielding gas setup for a while now.
Old May 24, 2016 | 11:04 AM
  #193
ncheavymetal
FTE NC Chapter
Thanks John. When I get the materials together I'll send you a message and we can work out details. WP also said he could help out if other stuff falls through. Appreciate yall helping out. I'll be in touch and make it as easy on yall as possible.
Old May 24, 2016 | 05:53 PM
  #194
ubereal2's Avatar
ubereal2
I've been wanting to get that tube grill off of Ka'Bluey since I've gotten him back. So since I've been snagging parts as I could find them, and finally a pretty day outside with no rain I got busy.
Got the tube grill out, and straightened up the grill shell that somebody bent the heck out of, Grabbed a scuff pad, and set in one of the rocking chairs on the front porch and went at scuffing the plastic so the new paint would stick.
A couple/few later and I have the stock stuff back in.
Old May 24, 2016 | 06:12 PM
  #195
fuzzy1626's Avatar
fuzzy1626
Lookin gooooood, Bob.
