Looks good with those stainless exhaust tips! Did they fix up with the rear speaker trouble?
It's getting a complete detail, and checking out the stereo this coming up Thursday. Today the screen went completely blank, and the tinny music kept playing. I'm thinking it's a stereo issue.
It is from what I'm reading, otherwise it would be scrape pile bound because I wouldn't sink that much into a $430 car. Hopefully should just have to get back to TDC on the compression stroke and pull it apart. The belt is $12.99 and a new tensioner is about $50.
Broke the one on the Ranger ten years ago. Noninterference so it got new belt and tensioner and I put a water pump on it while I was in there. Easy job since it's all in the front.
This one is all in the front aswell. It sets in the car normal, has a driveshaft and is Rwd. May pull the radiator for a little extra room but everything I've seen is it is not necessary.
That 2.3 Liter Ford is a great little engine, and not bad at all to work on.
Got my truck running and driving for the first time today!!! Motor sounds good, transmission seems good, and the lights even work! I haven't been able to stop grinning for the last 5 hours!
