42 2ton
Old Feb 4, 2017 | 05:31 PM
  #211
bernette's Avatar
bernette
back at it! started last saturday ,assembled the front end to see if any aligment issues. lines up pretty good. bought a gallon of furniture paint remover,was enought for the hood and right fender. so got them strip ,might if weather permits give them a shot of sand blast next saturday. to remove the surface rust. got a bit of welding to do and a few patches noting major. bad news is my young buddy is going back too school for a different trade. so he leaving in about 3 weeks for school. he will be back in 45 days for a 7 day brake so maybe then he said!
seems like theres a brown primer on the fender
Old Feb 4, 2017 | 08:08 PM
  #212
GB SISSON's Avatar
GB SISSON
Looks really great Bernette! Is your helper your kid? I have some experience with them coming and going.
Old Feb 5, 2017 | 10:19 AM
  #213
bernette's Avatar
bernette
no he,s a neighbour.
i,m gonna need some tips for my engine. i got good oil pressure ,going to take a compression test before disassemble. i think its got low compression. budget wise i hope reseal and gaskets, water pumps ,new rings. hoping i find no cracks! i plan adjustable valves and grind job. what gasket are better! how about crank bearings should i replace them! is the cam shaft bearing easy to do! rear oil seal anything special i can do to keep it leak free as possible. more to come!!!
Old Feb 5, 2017 | 10:27 AM
  #214
bernette's Avatar
bernette
the third picture is where the ford emblem was on the hood. you can almost read ford in the surface rust.
Old Feb 11, 2017 | 06:32 PM
  #215
bernette's Avatar
bernette
got the hood, fender and radiator cover sand blasted. partner is preparing hood i welded the radiator cover it was full of stress cracks.
Size:  146.0 KBName:  1942%20ford%20100_zpseci5yvcj.jpg
Old Feb 11, 2017 | 08:07 PM
  #216
56panelford's Avatar
56panelford
It's coming along Brian..
Old Feb 13, 2017 | 11:05 PM
  #217
GB SISSON's Avatar
GB SISSON
It's always great that just when winter is starting to drag out, you always show up with all your enthusiasm and jump in and get a bunch more accomplished! Three cheers for Bernette!
Old Feb 14, 2017 | 05:35 AM
  #218
bernette's Avatar
bernette
thanks for your encouragement john and gary!
Old Feb 16, 2017 | 07:24 AM
  #219
Joe777's Avatar
Joe777
X2. One of the few things I look forward to during the winter is updates on your build .
Old Feb 16, 2017 | 06:03 PM
  #220
bernette's Avatar
bernette
thanks joe! what color did you paint your inner fenders and radiator cover .
i need information on different hydrovac ! i talked to brent in ontario and he quoted me 700 to 900 to rebuilt my hydrovac. i don,t have to use the period correct hydrovac. i was thinking of installing something more available. i see different models in the 300ish range. but i,m not sure if they work with my brake system!!!
Old Feb 16, 2017 | 08:35 PM
  #221
Joe777's Avatar
Joe777
I used satin black for the inner fenders and radiator cover.
Old Feb 18, 2017 | 09:46 PM
  #222
bernette's Avatar
bernette
got a bit more done.hood painted inside and ready for paint outside.sandblasted the left fender grille and radiator support.
had a bit of extra paint ,not sure i will leave it blue.
Old Feb 20, 2017 | 07:04 PM
  #223
bernette's Avatar
bernette
started taking motor apart today . i,m going to need some advice! i check the compression ,it was from 80 to 90 lbs. theres a ridge at the top of the cylinder,but i don,t think i need to bore it. i was thinking stones and new rings. (not sure what i should use for rings). i tried to remove the valve keepers but there something that keeps it up in its groove. i was thinking of installing valve seals and a little paste grind , and then rechecking valve adjustment. hoping i stay within limits! whats the valve adjustment i should be seeing. my oil pressure was ok but i suppose i should get bearings while i,m there. inside of engine is sludged pretty bad,and the water jackets are rusted and dirty. i would need some sort of power wash. the closes engine rebuilder are 1 1/2 hrs away. so if i need i will go but unsure they are good in flatheads. didn,t see any apparent cracks so i guess its a good sign.
Old Feb 20, 2017 | 07:11 PM
  #224
bernette's Avatar
bernette
Old Feb 21, 2017 | 12:30 AM
  #225
Azryael's Avatar
Azryael
This truck is going to look amazing when it's finished. I love seeing these older trucks getting a proper resto and all the love they deserve!
That blue is fantastic.
