42 2ton
Old Apr 11, 2015 | 05:48 AM
  #106
bernette's Avatar
bernette
i got my parts from joe,s antique. real nice guy. start a built tread and post alot of pictures . looks like a nice truck. what year!
Old Apr 11, 2015 | 07:41 PM
  #107
bernette's Avatar
bernette
finally got truck out. installed gas tank ,electric gas pomp,and hood. seat and a few odds and ends. couldn,t park in it place ( its a plastic sheet),rain today! to much water! to lengthen drive shaft i used some exhaust pipe. its only to move it around,incase i find something wrong with engine ,when i reseal it. had a strange sound in engine,i think its the old gas pomp. i used a wooden stick and the noise seems to come from gas pomp. its not a knock, can,t really explain. iol pressure cold was over 50,by the time i parked it it was around 20lbs idle.
Old Nov 6, 2015 | 07:13 PM
  #108
bernette's Avatar
bernette
its time to start gathering parts,for next winter . i will be repairing front suspension and steering. and helper side door ,hopefull new front and rear windsheild,maybe some paint on cab. the guy who sold me his dad truck found a picture . its bernette who,s on top of the load.
Old Nov 6, 2015 | 07:45 PM
  #109
pns112500's Avatar
pns112500
'42
Old Nov 14, 2015 | 08:06 PM
  #110
f16qaguy's Avatar
f16qaguy
Nice build. Subscribed.
Old Feb 7, 2016 | 11:58 AM
  #111
56panelford's Avatar
56panelford
That's quite the undertaking you have committed yourself to Brian, think I'll stick to the smaller trucks. You are doing a real great job on it, nice work..
Old Feb 7, 2016 | 05:29 PM
  #112
white 66's Avatar
white 66
Great photo!
Old Feb 8, 2016 | 10:48 PM
  #113
GB SISSON's Avatar
GB SISSON
Looking good! I like the driveshaft. I have one with a top tube from a kid's swing-set welded in temporary. About 4 years ago..... Any pics of the interior?
Old Feb 9, 2016 | 03:24 AM
  #114
willowbilly3's Avatar
willowbilly3
Funny....I have Malwart swing set tubing in my rpu..
Old Feb 9, 2016 | 08:21 AM
  #115
GB SISSON's Avatar
GB SISSON
On the '60 panel I used a short tube from a cheap jackstand with the adjustment holes in it. Sometimes you find stuff like that and the swingset that aren't normal sizes and make great sleeves and spacers for pipe this IS. Mine never look as tidy as what Bernette is showing here, but he's shown us he no stranger to welding or body work. Holy cow, this thing was nothing I would ever consider tackling and now it's like new.
Old Feb 9, 2016 | 07:14 PM
  #116
bernette's Avatar
bernette
remove the snow on truck this evening. if everything goes well it will be inside friday!
Old Feb 13, 2016 | 07:28 PM
  #117
bernette's Avatar
bernette
started stripping this afternoon. so far i need piman arm ball is wore out. not sure on king pins they might be saved,left is tight except some minor up and down movement. right i,m not sure i know they tolerate some movement at the inspection i beleave 1/8! steering box will need attention. tie rods are solid but would need rubbers,the drag link is strange like if when the turned it with a pipewrench it squashed! brakes are ok,i got new cylinders and will get brake hoses. tommorrow i will finish removing spring leafs,theres alot of movement in the bushing. the left side spring had an extra leaf and yet it was leaning to the left. lets hope the old frame i bought comes in handy!!!
Old Feb 13, 2016 | 07:34 PM
  #118
bernette's Avatar
bernette
42 and 05 ford.
my drag link!
front cylinders
Old Feb 13, 2016 | 07:58 PM
  #119
newold46's Avatar
newold46
I would suggest that if you already have everything apart, you might want to do the king pins now with fenders, etc out of the way. All the rest will be new, why not those too??
Old Feb 13, 2016 | 08:12 PM
  #120
bernette's Avatar
bernette
i know what you mean! i,m kind of budgeting next winter will be expensive!!! but if there no good there no good!
