Engine removal pics
Old Nov 1, 2012 | 02:58 PM
  #886
npccpartsman's Avatar
npccpartsman
Originally Posted by run6.0run
I like new parts.
LOL--don't we all???????
Nice.......VERY nice.
According to Rockauto that's the diesel condensor. They have a LOT of choices for less than $100 but the motorcraft is $222.
Old Nov 1, 2012 | 03:10 PM
  #887
craziejoker's Avatar
craziejoker
Yes, we all like NEW parts, but used parts are nice too! If they weren't, I'd be out of business!!!
Old Nov 1, 2012 | 03:14 PM
  #888
npccpartsman
Trust me......I sold LOTS of LKQ (not the brand) parts when I was in the bodyshop parts business, and as long as they are good quality I don't have a problem with them.
Old Nov 1, 2012 | 06:12 PM
  #889
Yahiko's Avatar
Yahiko
Anthony,
Please no orange CHEVY paint
Sean
Old Nov 1, 2012 | 06:22 PM
  #890
run6.0run's Avatar
run6.0run
Heck yes, I don't mind used parts, just a pain to find any here. Super dutys are rare in the yards.
Btw I've got the colors,,, red, blue, and burnt copper,,,, It sounds wierd, but the caps together looked, um, looked like something.... Lol. I will get a pic of them. I'd like to paint the covers with something clear,,, is that possible??? I'd like to have a barrier so it could be cleaned and the grime won't stain the fresh alum...
Old Nov 1, 2012 | 07:00 PM
  #891
Yahiko's Avatar
Yahiko
They make clear coat in cans. For that matter they make
a catalyzed clear coat in can that uses the moisture in the air
to kick it off.
Sean
Old Nov 1, 2012 | 07:53 PM
  #892
run6.0run's Avatar
run6.0run
I miss my truck..... Is it ever gonna be done?????
Old Nov 1, 2012 | 08:07 PM
  #893
m-chan68's Avatar
m-chan68
We're at 60 pages here. How many more until the conclusion? 40 more? Another 60 more?
Old Nov 1, 2012 | 08:11 PM
  #894
run6.0run's Avatar
run6.0run
Hollywood called, they're gonna make it n2 a movie!!! Lol. Eventually, I'm gonna run outta $$$
Old Nov 2, 2012 | 01:31 PM
  #895
run6.0run's Avatar
run6.0run
Ok,,, bed plate seal question...I'm confused because the manual says to cut the sealant from the front and rear covers so the sealant isn't pulled outta the bed plate,,, but there's nothing that says to add sealant on the ends of the bed plate seals before installing the bed plate. Should there be sealant added to the ends of the two bed plate seals before mounting the block n bed plate together??? I think I made cheezit frustrated on another post about this,,, but the bed plate isn't a place I wanna assume I'm doing it right.
Old Nov 2, 2012 | 02:50 PM
  #896
run6.0run's Avatar
run6.0run
Just sent the ficm,,, 475 lighter
I also just got containers to soak the lifters and the injectors.
I've got two front cover gaskets n two front crank seals. I'm gonna have a parts store even after this is done
Old Nov 2, 2012 | 04:40 PM
  #897
npccpartsman
Save me the extra stuff. I'm building an 04 motor so I'll need a few pieces......
Old Nov 2, 2012 | 04:41 PM
  #898
Yahiko's Avatar
Yahiko
WOW 60 Pages so far.
Anthony, I take it you looked in the DVD for this.
My little experiment failed and the backup did not
work when I tried it. I know I have some other tools and
will let you know when I get a good backup.
I think Cheezit was saying to use the Ford sealant and
not the stuff that you get at Autozone do to the amount
of the squish out so that you don't end up with too much
clearance between the bedplate and the block. Also when you
go to stick the pistons in make sure to protect the cylinder walls
from the connecting rod ends they will scratch bad. Some
cover over the end would help as you push it in. Then remove when
you mate it to the crank.
Sean
P.S. I thought that the flu shot was to keep you from getting it.
Old Nov 2, 2012 | 04:43 PM
  #899
npccpartsman
At 40 posts/page I'm only at 23--LOL.
Old Nov 2, 2012 | 04:48 PM
  #900
MisterCMK's Avatar
MisterCMK
Same here. I am on man settings.
