Engine removal pics
Old Oct 25, 2012 | 10:32 PM
  #766
run6.0run's Avatar
run6.0run
Sux to give up those metal clips n the rockers. It will really be a kicker if my rebuild doesn't go as planned huh. Well, I'm human.
Old Oct 25, 2012 | 10:36 PM
  #767
run6.0run's Avatar
run6.0run
It's only money I guess,,,, they make more every day. Ha ha
Old Oct 25, 2012 | 10:38 PM
  #768
run6.0run's Avatar
run6.0run
Ok, question on the front cover,,,, it prob wont come with the low pressure regulator huh? I've never taken that out. Anything complicated about it???
Old Oct 25, 2012 | 10:59 PM
  #769
m-chan68's Avatar
m-chan68
If you ordered the new front cover with the part number I gave you, it includes the LPOP regulator at the bottom of the cover. Assembling it should be self-explanatory once you see the parts.
Old Oct 25, 2012 | 11:05 PM
  #770
run6.0run's Avatar
run6.0run
I just looked at the quote. That isn't what I got. 5c3z6019bb. Well crap.
Old Oct 25, 2012 | 11:15 PM
  #771
run6.0run's Avatar
run6.0run
Should I reuse the bed plate bolts???
Old Oct 25, 2012 | 11:24 PM
  #772
run6.0run's Avatar
run6.0run
I should've wrote that number down. I gotta call em n get a branch tube ne ways. I'm gonna post a list if parts for this rebuild. It's a loooong list. I'm wondering if the bed plate bolts are tty.
Old Oct 25, 2012 | 11:30 PM
  #773
run6.0run's Avatar
run6.0run
I'm gonna have to send out 20 cases of beer when this is all done. I can't explain how much I appreciate everyone's input.
Old Oct 26, 2012 | 01:50 AM
  #774
Yahiko's Avatar
Yahiko
FYI : I like Diet Coke
Sean
Old Oct 26, 2012 | 07:51 AM
  #775
npccpartsman's Avatar
npccpartsman
Originally Posted by m-chan68
Regarding the metal rocker arm pivots, they are correct. The metal pivots were used only in 2003 and early to mid 2004 engines. Just as they are correct that the metal pivots are now obsolete. If I were going this deep into my engine, and could score a set of rocker arms with metal pivots, I would jump on it.
I'm glad I acquired a set for my motor build
Old Oct 26, 2012 | 08:40 AM
  #776
run6.0run's Avatar
run6.0run
I just added the lpop regulator and the branch tube to the order. It was cheaper, that way I didn't buy two front cover gaskets. I'm getting the overhaul kit. The bare front cover is like $260. $19 for the lpop regulator. $80 for the branch tube.
Also I got one ,,, tube????,,, of the ta29 stuff. Do you think that will be enough??? Hope so.
Old Oct 26, 2012 | 08:41 AM
  #777
MisterCMK's Avatar
MisterCMK
I might have to send you a DVR and a camera to set up out there while you build this thing.
Old Oct 26, 2012 | 08:54 AM
  #778
run6.0run's Avatar
run6.0run
I'm game. I wish I had a video camera. It'd b a long video. I do have a terra byte external hard drive
Old Oct 26, 2012 | 08:55 AM
  #779
run6.0run's Avatar
run6.0run
Run it by Tousley Lol. My order hasn't shipped yet.
Old Oct 26, 2012 | 09:23 AM
  #780
run6.0run's Avatar
run6.0run
Ok bouncing around,,,, ficm repair. I just called them. I'm wanting opinions on their 1 year compared to 2 year. I've always had 48.5 on it, and I would like to get the atlas 40 tune. It's 500 to get their whole hookup. That's a chunk. Would stock components in the ficm hold up to the atlas tune? Should I do the $500 as preventative maint??? I checked the oasis before buying the truck and am sure it's never had any flash done. I have the original flash from the factory. Is the extra 100 worth it for the 2 yr components??
