oil sending unit
Old Jul 5, 2001 | 01:25 AM
JEFFRYAN's Avatar
JEFFRYAN
oil sending unit
I have a 74 ford F-350 with a 460, I'm trying to replace the oil sending unit.Is a crowfoot wrench the only thing that can fit? If so does anyone know the size so I don't have to buy a complete set. Thanks for the help!!!
Old Jul 7, 2001 | 01:36 PM
Torky's Avatar
Torky
oil sending unit
On a 1970, it is 9/16. Although I didn't try it, I doubt a crowfoot would work on mine. The barrel of the sender is too big in diameter, don't think a crowfoot would reach under far enough. If you have the room to swing it, a 9/16 tubing wrench like used on steel fuel lines would be less likely to round it off than a open end wrench. The hex is up tight to the bottom of the sender body, so a tubing wrench could be slid on closer to the block over the threaded pipe portion, then lifted up to engage the hex.
Old Jul 7, 2001 | 09:30 PM
Torky's Avatar
Torky
oil sending unit
No, tubing wrench won't fit over the pipe part. Open end wrench worked.
Old Jul 8, 2001 | 01:00 PM
logan_85's Avatar
logan_85
oil sending unit
You buy a cresent wrench you have a full set of standard and metric in one tool! Acutually I have no clue what a crows foot wrech is, I'd imagine the bolt is either 1/2 or 9/16.
Logan
Old Jul 8, 2001 | 06:00 PM
Torky's Avatar
Torky
oil sending unit
FYI, A crows foot is like an open end wrench, holds across two flats. But where the handle would be, is a square hole so a extension from a socket set will fit there to drive it. It can be used where you can't get a straight shot with a socket, yet it will work where there is not enough room to swing a open end or box. The offset effect of a crows foot works good on carb mounting bolts, distrib hold down, etc.
Old Jul 8, 2001 | 10:45 PM
wxo's Avatar
wxo
oil sending unit
erik68
Jul 16, 2013 03:25 PM
off2sleep
Nov 24, 2009 07:51 PM
randle_ford
Sep 9, 2005 10:19 PM
herby1
Apr 17, 2003 07:37 PM
Boaz32
Nov 11, 2002 11:45 PM
