When the obvious is not the real problem...
Old Aug 13, 2016 | 10:14 PM
PapaBearYuma's Avatar
PapaBearYuma
All my trucks had been really hard to cold-start, because the fuel boiled out of them. Starting with the yellow truck, I installed electric fuel pumps, and cold-starts got much easier
After a while, the yellow truck developed symptoms of "too much" fuel. Hard warm-starts, loss of power, occasional stalling, strong smell of fuel and back-firing. So I installed a fuel pressure regulator
After that, the problems got worse! Cold and hot starts became difficult, the fuel pressure was fluctuating at the carb, and it would die at stop signs. I had to "two-foot" it back home, and parked it overnight
Figuring I screwed something up with the regulator, I pulled it out, and plumbed it straight. Once back together, it wouldn't start at all!
I checked the flow and pressure at the carb, and they were both perfect. I pulled the float bowl to check for a stuck float or valve, but it was all good. I cleaned it anyway. Still no start
So I pulled a plug, and it was black with a soft soot. A little spray cleaner cleaned them right up, but still wouldn't start. The plugs had a few thousand miles on them, and a couple years, so I replaced the plugs, wires, rotor and distributor cap. Still no start
I rolled the engine over by hand to check the timing. The distributor and timing marks still lined up, so it didn't jump or excessively stretch the timing chain. Rotated distributor a bit forward and back. (Probably shouldn't have done that). Still no start
Basic troubleshooting: gas, spark, air
Getting gas-perhaps too much. The accelerator pump is fine. Valve, seat, float, spring and all that other stuff is fine. Not a gas problem
Air-air cleaner is clean, and it's off. Not an air problem
Spark-pulled the wire that runs from coil to cap. Crank the engine. Got spark, but it seemed weak. Pulled the coil from the copper truck for testing. Same story-has spark but seems weak
With nothing else left that would make sense, I pulled the ignition control module from the copper truck and dropped it in. The yellow truck then fired right up!
It runs, but a bit rough. Tomorrow I'll fix the timing, but I have to pull the a/c bracket to get to the distributor hold-down bolt. It'll have to wait, cuz it's 112 this afternoon, and everything, including tools, is too hot to touch
Old Aug 13, 2016 | 10:29 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Swapping the ing module is always the 1st troubleshooting test.
As far as the dizzy bolt access and the a/c bracket, get to modifying a old wrench (heat and bend) and a piece of round stock with a 90 bend for a handle.
Glad to hear you at least have it figured out.
Old Aug 13, 2016 | 10:58 PM
PapaBearYuma
Thanks for the tip on the wrench
Do you have a preferred source for the ignition module? I was looking at Autozone-they're about $40 with a lifetime warranty
I like to go OEM NOS, but eBay wasn't listing any
Old Aug 13, 2016 | 11:05 PM
77&79F250's Avatar
77&79F250
Ignition modules,74(black grommet) and 75 (green grommet) are year specific and will notinterchange.76to 79 (blue grommet) are interchangeable.
Ignition modules: 1974 is 1974 ONLY / 1975 is 1975 ONLY.
Blue module introduced in 1976 was used well into the 1990's. D4AZ-12A199-C 1974 only
Dura Spark ignition modules identified by a colored plastic insert located above where the wires feed out.
2others: One has a red plasticinsert, the other has a yellow or brown plastic insert.
Red module is D7AZ-12A199-A used in some CA vehicles ONLY.
D9AZ-12A199-C (replacedD8AZ-12A199-A). One of these modules is yellow, one is brown..Since the part number was replaced, I cannot recall which module was which color.
These modules were used in 1978/79 302 & 351M/W vehicles sold in high altitudes only. 351W: Passenger Cars & Econoline sonly.
1U2Z-12A199-AA (replaced 6AZ-12A199-B - D7AZ-12A199-B - D8VZ-12A199-A - D9VZ-12A199-A) ..Ignition Module -blue insert (Motorcraft DY-893)/ Available from Ford.
Myriad1976/90's FoMoCo vehicles.
GreenSales in OH.
Collectors Auto Supply in WA.
Haven Ford inKS.
Klimesh Motor Sales in IA.
Bob Allen Ford in KS.
Freese Motor Inc in IA.
Wesley Obsolete Parts in KY.
Dennis Carpenter Ford in NC.
No worried ND will come along here shortly and post exactly who has what and how many on the shelf.
Old Aug 13, 2016 | 11:20 PM
PapaBearYuma
Thanks for the part number-I just ordered two
Old Aug 13, 2016 | 11:31 PM
77&79F250's Avatar
77&79F250
You do know that all that info and a lot more is right here ALL the time? https://www.ford-trucks.com/forums/1...then-some.html
Old Aug 13, 2016 | 11:57 PM
lasermike's Avatar
lasermike
Another option for reaching the bolt is a crows foot. Fits the end of a 3/8" extension and looks like a open end wrench.
Less than $12 for a set of 7 at your favorite Chinese tool store. I'd think about the flare nut version as they hit more sides of the bolt head, reducing the chance of rounding the head.
Old Aug 14, 2016 | 12:02 AM
PapaBearYuma
That's a great tip-thanks Mike!
Old Aug 14, 2016 | 01:58 AM
lasermike's Avatar
lasermike
You are welcome.
I just googled distributor wrench and it turns out they are way cheaper than I thought so that's another option.
Old Aug 14, 2016 | 01:22 PM
PapaBearYuma
You are welcome.
I picked up a distributor wrench this morning. Adjusting the timing was so easy, I might do it just for fun! Should have got one years ago. Thanks!
Old Aug 14, 2016 | 10:46 PM
77&79F250's Avatar
77&79F250
I made mine in 4 min. lol Guess I should of included pics earlier, so here you go.
Old Aug 15, 2016 | 08:55 AM
PapaBearYuma
Nice work! Thanks for the pictures
Old Aug 15, 2016 | 10:34 AM
FORD~'s Avatar
FORD~
Nice fab. Thanks for posting.
Red77Ford
Aug 12, 2019 04:05 PM
justroll
Apr 28, 2019 06:33 PM
Chris Popanz
Nov 26, 2015 03:09 PM
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
SuperSnake
North Carolina Chapter
Sep 21, 2006 10:46 PM
