Hey guys, I have a question. I have a 76 f250 that has a Dana 60 rear and it's been blowing out oil so I replaced the front seal and it worked for a while but it's leaking really bad now so I think I must have some bearings going out making the seals go out. So I wondered about just swaping axles. Can I swap a 79 f250 extended cab Dana 60 over to my 76 f250 Highboy frame or would that not bolt right up? If you could help me out I'd much appreciate it.
The 78-9 60's bolt right in. I just had to move one shock mount on the frame when I swapped it into my 73. They are pretty rare so unless you already have one be prepared to pay top dollar unless you get real lucky
My vent tube was rusted shut when it first started leaking acouple months ago. So I replaced that and replaced the front seal behind the drive shaft. And it slowed down the leaking but it never stopped. But lastnight i got home and it had slung oil all be over the place and it was dripping pretty fast out of that front seal again. So I'd guess I've got bearings going out and making the seal go out. So is it cheaper to swap axles or rebuild the axle with bearings and seals? I've heard it's kinda had to shim the axles and stuff back up so I'm not sure if I'd be very good at doing that or not. So if I did swap axles it should all be the same I'd just have to move the shock brackets over to fit my narrower frame?
