91 explorer won't start after accident
to anyone who would happen to share info it would be greatly appreciated:
i was involved in a fender bender yesterday 7-3 and for some reason my 91 explorer won't start now. nothing more than the bumper and quarter panels were hurt so i'm curious as to what it would be. if anyone has a suggestion to help or has had this problem befre please lend a hand it will be greatly appreciated. also i've heard rumors of a shut off switch in a 91 ford also wondering if that is true or not.
justin
justin
Yeah, there is a fuel pump shut off inertia switch located on the passenger side of your truck. If you pull the carpet back under the dashboard, you will see a little black box about 2" square with a white **** sticking up about 1/2" an inch. Press it back down and your fuel pump should fire up and the truck should start. Unless you broke the ignition module which is located in front of the battery.
thank you so much for the quick response. i went out and found the swtich and gave her a puch connected the battery and fired her up and she turned right over. again thank you for a quick response it was gonna be a long day withoiut a car plus with the holiday whats the fun in riding in your friends car? again thjank you!!!!!
