92 Explorer Overheating - TRIED EVERYTHING! HELP!
Old Jun 24, 2002 | 10:32 PM
J_Birk's Avatar
J_Birk
My daughter's 92 Explorer 4.0L engine is overheating to the point of boiling over! It happens after the engine has been running about 30 minutes. The temp gauge goes over to the L in Normal and when the motor is killed, it boils water and coolant out of the overflow plastic container. I have had the radiator cleaned, boiled out, and all leaks repaired. Thermostat has been replaced twice. New fan and clutch (Ford parts)and new water pump. No water in oil or out the exhaust. I am a mechanic and have talked with several other mechanics. I am to the point of calling it a blown head gasket. Any Help before I tear into the motor would be appreciated!
Old Jun 25, 2002 | 10:07 PM
proford460's Avatar
proford460
most likely a cracked head pull the plugs and look for green crud on plug
Old Jun 29, 2002 | 09:38 AM
J_Birk's Avatar
J_Birk
The plugs were fine. I tore into the motor and sent the heads to a shop that specializes in heads. The heads were warped! I got it all back together late yesterday evening. My daughter drove it last night and it never got past the "R" in normal. The Explorer has 160,000 miles on it an the inside of the motor looked new! When I replaced the plugs, I found out they were the original factory plugs! I hope this keeps her on the road for awhile.
Old Jun 29, 2002 | 03:33 PM
thebigblue92's Avatar
thebigblue92
tuxedobuttonquail
53
Jan 9, 2017 08:04 PM
48 Steel
Sep 30, 2015 10:54 AM
shawn1975
May 10, 2015 08:55 AM
bburrito
24
Sep 26, 2013 01:31 PM
maddogjohnson
13
Aug 11, 2012 01:28 AM
