Squeaky Suspension
Old Jun 28, 2002 | 01:09 PM
Ortho's Avatar
Ortho
Post Squeaky Suspension
(originally posted in "Suspension," but no responses)
I own a 1995 Ford Explorer XLT (4WD) with about 85k miles on it.
During the last several months I've noticed progressively more squeaks
coming from underneath the vehicle. It's particularly noticeable when
I'm driving at moderate speeds (e.g. 30 mph) over a somewhat wavy or
bumpy road. I can also produce the the annoying sounds when the truck is parked by standing next to it and rocking it from side to side with my arms.
What are the likely parts that need to be replaced? I made a couple
calls to service stations and was told that none of the suspension parts on this model can be lubricated.
I'll appreciate any tips you can give me.
Old Jun 29, 2002 | 06:55 AM
akrenzer's Avatar
akrenzer
Squeaky Suspension
Could be ball joints. I have a '96 XLT that had bad ones last year.Pretty expensive(about $500 bucks , just for the lower ones)because they have to replace the entire control arm.Take it in to confirm the problem,then call around to find the best price.
Good Luck
Old Jul 5, 2002 | 05:42 PM
work2well's Avatar
work2well
Squeaky Suspension
Mine had a bad radius arm bushing, under the passenger's feet. Different people have their own ways of doing these the hard way, but there is an easy way, that only needs a pair of jacks.
Old Jul 6, 2002 | 09:06 AM
Ortho's Avatar
Ortho
Squeaky Suspension
Thanks for responses.
It is confirmed: it's bad lower-right ball joint. The dust boot has a gaping gash in it, and the joint sits almost half an inch lower than the other side.
When I got underneath that area and rocked the truck up and down, I could feel the vibration on the control arm around the ball joint as it squeaked. I took it into one shop for a diagnosis (without telling them of my own findings), and they confirmed my suspicions.
"akrenzer" said in an earlier post that the whole control has to be replaced, which is also what the Chilton manual says. But I called a couple of shops who said the lower ball joints are just pressed in, and can be replaced with the right equipment.
First quote: $250 (parts/labor)
Second quote: $225 (parts/labor)
Both shops said there's a 50/50 chance an alignment would be necessary after the work (another $60 to $90).
Old Jul 7, 2002 | 05:19 PM
kell3238's Avatar
kell3238
I have a 91 explorer with the bad front bushing. what was the easy way to replace it needing only a jack?
Old Jul 7, 2002 | 05:21 PM
tat8575's Avatar
tat8575
Squeaky Suspension
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 30, 2017 12:05 PM
AGrayson84
May 10, 2016 01:43 PM
TazInTrouble
Mar 18, 2016 07:14 AM
Stanislaw
Oct 7, 2015 05:27 AM
LaxPlaya21
6.7L Power Stroke Diesel
Nov 29, 2013 12:53 PM
