Sponsored by: Real Truck
Gas vs PSD
Old Jan 8, 2011 | 08:02 PM
  #10471
bucci's Avatar
bucci
Originally Posted by plgebbia
I will have approx 350 RWHP with the mods in my sig, and in that form will outrun a V10 easily, but will have very similar HP to the 3v v10. Care to explain?......
How could you have 350 hp at the rear wheels then say you have similar hp to a 3v V10 when a 3v V10 is rated at 362hp at the crank?
Old Jan 8, 2011 | 08:17 PM
  #10472
plgebbia's Avatar
plgebbia
Originally Posted by hughjazz
Do you even know how hp is achieved? It's calculated.
Sure your engine can twist a crank harder, but not nearly as fast.
That's the advantage,
Diesel's twist harder,
Gasser's twist faster.
You use gearing on a diesel to allow you to reach highway speed.
Yes, but less gearing than a comparable gasser.
It's simple, an engine with higher horsepower is capable of achieving more work.
Driver comfort aside, I prefer a diesel to tow heavy. imo it has superior towing characteristics.
Like????
My mistake, I will state it clearly now.
2006 v10 362 FWHP - 301.7 RWHP (approx) About 380 RWTQ
My sig truck 384 FWHP - 320 RWHP (approx) at least 650 RWTQ
My truck will easily outrun and outpull the V10 (by way more than the 18.3 HP diff.) Why???
Old Jan 8, 2011 | 08:27 PM
  #10473
Fishin76's Avatar
Fishin76
Like????
I'm assumming you mean at a1:1 trans ratio and the same rear gears? If so, thats the arguement is that gearing makes all the difference....
Old Jan 8, 2011 | 08:32 PM
  #10474
plgebbia's Avatar
plgebbia
I wasn't meaning that with the HP stated above. If my truck was stock, yes
I was trying to say that if I have the same HP as the V10, I will out pull it. Easily.
Old Jan 8, 2011 | 08:34 PM
  #10475
David N.'s Avatar
David N.
Like????
Given the numbers you state, you will be able to accelerate through first gear quicker than a V10 due to the torque advantage. Due to your inability to rev as high as a V10, you will have to shift sooner, though, and your acceleration advantage then ends. However you will have a noticeable lead by this point.
On a level road, both engines will have more than enough power to move the truck loaded to max GCWR to the speed limiter of the truck. On a large enough grade to max out both engines, your truck would probably have a 2-3 mph advantage due to the extra horsepower.
Old Jan 8, 2011 | 08:49 PM
  #10476
plgebbia's Avatar
plgebbia
Why does the advantage end here?
Old Jan 8, 2011 | 09:09 PM
  #10477
David N.'s Avatar
David N.
Because you run out of rpm and your truck has to shift. Your inability to rev to a higher rpm forces you to shift to a higher gear if you want to accelerate to the speeds the V10 will reach.
Old Jan 8, 2011 | 09:21 PM
  #10478
hughjazz's Avatar
hughjazz
Ok let's look at it this way, you don't like using gears in the discussion of which engine is more powerful?
Let's have a race, we use 3:73 diff if you want, and lock it in first gear on the transmission.
we can race for 5 miles, and see who crosses the line first.
Not fair?
Both trucks use gears and gearing to make them as useful as possible to suit the engine.
Diesels have more grunt, so they use lower gears to allow the truck to make the best use of the engines charastics.
The Gasser makes more power at higher speed, so it uses gearing to allow it to rev up a little.
Why does that make it weaker?
Old Jan 8, 2011 | 09:46 PM
  #10479
X_Hemi_Guy's Avatar
X_Hemi_Guy
I love the BLOCK feature...I just wish it worked on quoted messages too!...the useless arguments people are making about gearing are something that is ridiculous...FORD gave the trucks gears and transmissions...why is it so difficult to understand that the FORD engineers KNEW the limitations of the engines and mated it with the PROPER GEARING to get the job done...
When was the last time you saw a motor alone laying on the road pulling a trailer?...how crazy of an image is that?...
To state that using the hardware that the people that KNOW and DESIGNED these motors is taking advantage is just plain foolish...
I do wish that my blocks worked on the quotes too...
Old Jan 8, 2011 | 10:02 PM
  #10480
Snowseeker's Avatar
Snowseeker
Funny stuff in here!
It goes from who can pull a trailer faster up a hill to who has more hp to who gets the best mileage to who can get up to 70mph first.
V10's just need two more cylinders to get the same job done.
Old Jan 8, 2011 | 10:11 PM
  #10481
Kajtek1's Avatar
Kajtek1
And double the tank size
Old Jan 8, 2011 | 11:50 PM
  #10482
hughjazz's Avatar
hughjazz
And 2 weeks less in the shop every year.
Old Jan 9, 2011 | 11:57 AM
  #10483
Kajtek1's Avatar
Kajtek1
2 weeks is spark plugs replacement on V10
Old Jan 9, 2011 | 12:06 PM
  #10484
kx450frider617's Avatar
kx450frider617
I know what you are trying to say, HP sells cars, TQ wins races and no one here gets that haha.
Old Jan 9, 2011 | 01:54 PM
  #10485
plgebbia's Avatar
plgebbia
You don't seem to get it. Just because I have to shift sooner doesn't mean I lose my torque advantage
Not fair?
Agreed!
Agreed!
Because it does NOT have as much power to begin with, and has to use extra gearing to make up for that!
I agree! They all need gearing, but a less powerful engine needs more gearing, that's why the Ford engineers gave it more
Duh.... But motor power has something to do with it, or why don't we all run 4cyl. with monstrous gearing?
And a lot more rpms, and more gearing.
You evidently get it
