Sponsored by: Real Truck
Gas vs PSD
Old May 11, 2011 | 04:57 PM
  #11176
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by '89F2urd
the main reason the 6.8 isnt the most impressive gasser released by ford, is because of its low compression. they werent makin a high performance motor, rather somethin that would run on 87 and have the the torque at a low enough rpm that it could be used in a truck. its still around cuz of the horrible reputation of the 7.3's successors. if it were 10.5-11:1, or had a supercharger, it would be much more impressive (although i still wouldnt be impressed).
Actually, virtually all production modulars, the 4.6, the 5.4 AND the 6.8 are "low compression" running around 9:1 or slightly higher, and 9.8:1 in the VCT versions. The reason is, yes, they run 87 octane. What would you expect an automotive company to produce as a work horse? At 11:1 they'd need 93 octane (been there, done that).
And as for "still around" - there will ALWAYS be a gas-powered version of a light-duty truck unless something earth-shattering happens. The new 6.2L gasser is quite the machine too
Old May 11, 2011 | 05:02 PM
  #11177
'89F2urd's Avatar
'89F2urd
ok, if we're playin that game. . .my truck does all i need (and more) far better and cheaper than if it had a v10 in it.
Old May 11, 2011 | 05:06 PM
  #11178
'89F2urd's Avatar
'89F2urd
exactly my point. . . .all motors in all trucks from the factory come with low comp. . . .theyre not "high performance" oriented.
yea, but ford is the only one continuing their huge displacement gassers in their 3/4 and 1 ton applications. and theyre the only ones who have had severe problems with their diesels after the 7.3 (gotta have an option for the die hard ford guys that are scared of the 6.0 and 6.4, for good reason). we will see in the next couple years whether they continue the 6.8. its due for a "revision". . .so my point wasnt about why gassers are still around, it was about why the 6.8 is still around
responses red.
Old May 11, 2011 | 06:11 PM
  #11179
exiled's Avatar
exiled
I wasn't saying the 6.8 wasn't the most impressive engine put out by ford I was saying inch for inch it wasn't the most impressive of the modulars. I went a step further and even said because ford didn't do anything with them. I don't know what your getting at about 5252 rpms. I know that's where tq and hp cross but what's that got to do with Ford bolting 4v heads and a roots supercharger on a 5.4 and making 500 ftlbs of tq. 5252 is below the redline already. I admit I don't know what the rpm range is on that gt. I would like to think its higher and they use the supercharger to keep it from getting winded.
I reckon you can say rpm to rpm diesels make the best power. Then you get in the noise bleed section and the gaser really starts makeing it power.
Old May 11, 2011 | 06:47 PM
  #11180
exiled's Avatar
exiled
Originally Posted by Anomic
The problem with the "disiel can be geared logic" is once you get much past 411,430 area. Gasser running 3000+ rpm in top gear st highway speed, not ideal but will do it. The psd running 3000+ in top geAr how long until it overheats? Or worse
Which psd are you talking about? Any in general? Well this might be a trick question. I don't see either gaser or diesel running very long in "top" gear. I can't get the math worked out right now, but I'm thinking they both are going to downshift.
My speedo only goes to 100 mph. Wed of the tornados I pegged 100 mph for 45. Never came off it. I "think" I was pulling 2600-2700 rpm. Might be less. If my truck will stay in 5th @ 3k rpm I would say it'll do it for a while. I was pulling 900 deg egts. I hit 1000 on the little hills. Tranny ran slightly below 160.
I don't know what the top speed of a v10 is and if 3k rpms is in side of that.
Why do you think a psd will have a problem holding 3k rpms?
Old May 11, 2011 | 07:17 PM
  #11181
KelVarnson's Avatar
KelVarnson
Even if kerosene heaters didn't emit CO, they still deplete oxygen, and in a closed space, that means death, eventually.
Regarding diesels vs. gassers, all that matters to the truck and the load it is pulling is rear-wheel torque. Two trucks of the same weight pulling the same load up the same hill at the same speed are generating the exact same rear-wheel torque. By virtue of the fact that they are going the same speed, they are also generating the exact same horsepower. And the load doesn't care whether that power came from gasoline or diesel.
Engine torque numbers are mostly marketing hype, which apparently many people here have bought into. A high torque number just means that the engine makes its HP at lower RPMs. That is the great thing about diesels, they're turning slower to do the same work. Less fuel, less noise, less wear, etc.
I really like that about my 7.3, which is why it is my primary tow vehicle. But at 250 HP, it is anemic. My 330 HP 400 ft. lb. small-block GM will tow circles around it, but I hate using it because I don't like listening to that engine all wound up and burning all of that gas.
Now let's see, where did I put that Nomex suit?...
Old May 11, 2011 | 08:18 PM
  #11182
exiled's Avatar
exiled
I don't dispute burnt kero putting off co. Houses are built to breath. House are vented to circulate fesh air and hot air out. Can you burn more oxgen coming in I believe you coulf if you tried. I never tried.
Please show me your math on the trucks doing the same speed haveing same hp and same tq. That makes no sense to me. If physical size and shape and weight is the same, everything being the same but the drive train you could have truck 1 doing 65 turning 2k rpms and truck 2 turning 1800 rpms @65 mph. Difference here 1 truck is geared around 3:73 the other 4:11. This isn't actually figures its off the top of my head but should be close. Look at that engines tq to rpm range. You clearly see the tq and hp isn't the same. Now gear em both the same get the rpms the same. There's still a difference in the out put tq and hp of both engines.
Tq and hp isn't a ploy to sell you on an engine it is actually numbers to show the work ability of the engine. That's like saying the watt rateing on a light bulb is meaningless.we all know that it does. Hp and watt just about the same thing.
Old May 11, 2011 | 08:19 PM
  #11183
CampSpringsJohn's Avatar
CampSpringsJohn
As for gearing in a diesel, the 97 in my signature has 4:56 gears with an E40D automatic tranny. Check out the miles on it. It had 116,000 5 years ago when I bought it.
Old May 11, 2011 | 08:21 PM
  #11184
CampSpringsJohn
As for those afraid of the 6.4, check out this thread.
https://www.ford-trucks.com/forums/9...g-the-dpf.html
Old May 11, 2011 | 08:40 PM
  #11185
David N.'s Avatar
David N.
If they are both under the same load (same weight, same drag, same incline), and maintaining the same speed (neither accelerating or decelerating), then the hp/torque to the ground has to be the same from both. If it wasn't, then one truck would have to be changing speed. However, that doesn't mean that both or either are making max power. Unless it is a very heavy load and/or very steep hill, both are likely at part throttle.
Old May 11, 2011 | 08:48 PM
  #11186
David N.'s Avatar
David N.
And, IMO, medium-duty, too. I, and my coworkers, have noticed an increase in customers picking gas powered trucks (mostly class 4/5) in the last year or so. While certain types of companies have long chosen gas, we've noticed more of the those that have typically been diesel only opting for gas.
Old May 11, 2011 | 09:18 PM
  #11187
exiled's Avatar
exiled
That's makes no sense to me. I'm going to leave rearend out cause simpley I can't figure that out in my head. I can't remember right off but I think 5th gear on the torqshift tranny is .73 we'll use the 3v v10 and my 04 6.0l. Me and kevin going down the highway cruise set on 65. My tach is on 2k his is like 2100. I have 4.11s and he has 4:30s. The 6.0 is putting out 560 ftlb of tq @ 2200 so I'll just say imnputting out 500 ftlbs
Of tq to the tranny 500x.73= 365 put to the rearend. The v10 only makes 457 @ 3400? So what's fair to guess at 2100? 80%? Aight ill buy that. 457x.80=365.6 so 366x.73=267 sent to the rearend. Now if boyh trucks where geared the same then well there's your answer. There not so therrs another step. Maybe ill figure it out later or you'll show your math and it'll turn out I'm full of crap.
The advantage of high end tq is to take advantage of gearing.
Old May 11, 2011 | 09:27 PM
  #11188
David N.'s Avatar
David N.
The numbers you list are peak numbers. That's what the engines would make at that rpm at wide open throttle. Neither would be at WOT, though, so neither would be the maximum torque they could at that rpm. Instead, both are making some percentage--different for each engine--of the torque they are capable of.
If the trucks are identical with respect to truck/trailer weight and size, and are going the same speed on the same terrain, the the forces opposing each trucks motion have to be the same. If your engine was putting out more force than his, then one of you would be making more or less than enough power to equal the load you see. Either you would be speeding up, or he would be slowing down.
Old May 11, 2011 | 09:30 PM
  #11189
Johnny Langton's Avatar
Johnny Langton
Thank God, someone else that understands this.
JL
Old May 11, 2011 | 09:47 PM
  #11190
PorchFarms's Avatar
PorchFarms
JL
well if thats the case then the talk about hp doesn't work out either
