Sponsored by: Real Truck
Gas vs PSD
Old Nov 22, 2010 | 03:17 PM
  #9376
t613's Avatar
t613
Originally Posted by bill11012
Well, I don't spend much time here.
The time I do spend is worth it for all the things I learn about these trucks.
Don't you mean as I pass?
Sure. You'll know it's me, because I'll be waving using ALL of my fingers!
Like I said, be happy with your gasser, I'll take my clacker any day.
Old Nov 22, 2010 | 03:21 PM
  #9377
t613's Avatar
t613
Getting rid of the stock 3.73s would help allot.
You have to remember that yours has much less power than the 05-10 V10s, and a tranny thats not as good.
You still have 60HP over the PSD that was sold that year.
And how much less torque than that same PSD? Are you saying that the v10 can't pull 3.73 gears? Funny, that's what mine has and it has all kinds of power!
Old Nov 22, 2010 | 03:40 PM
  #9378
ChargersFanInCO's Avatar
ChargersFanInCO
True that...And my 6.4 has 3.55 gears and runs like a scalded cat!
Old Nov 22, 2010 | 04:11 PM
  #9379
exiled's Avatar
exiled
I don't think jumping to 4:30s is going to make that much of an impact. Everything equal taller gears=lower topend speed. Taller gears=higher rpms at same speed. He's still going to gear search in cruise. Only way around that is to WOT. Now the gas hand is going to race to the bottom mark. Its just the nature of the beast.
Its not the case here but 01-03 7.3L closed the gap to only been 35 hp under the 6.8L of the same yrs. I don't why Ford waited so late to try to get something out of them.
Old Nov 22, 2010 | 04:16 PM
  #9380
bill11012's Avatar
bill11012
Modular motor junkie
Those are great gears for an engine with low RPM peak torque and peak HP.
The 5.4 and 6.8 pull the hardest at higher RPM. Running the same gears as a PSD holds them under peak power, where they hold your engines right where they want to be.
Needing gearing to match the engines RPM range does not make them weak.
Old Nov 22, 2010 | 04:26 PM
  #9381
bill11012's Avatar
bill11012
Originally Posted by exiled
I don't think jumping to 4:30s is going to make that much of an impact. Everything equal taller gears=lower topend speed. Taller gears=higher rpms at same speed. He's still going to gear search in cruise. Only way around that is to WOT. Now the gas hand is going to race to the bottom mark. Its just the nature of the beast .
The problem towing with 3.73s is that at 65, your RPMs are a little low for a hard pull. If you drop to second, it pulls hard at peak HP but is screaming.
You start gaining speed you back out of the gas when you get to the speed you want and then its back to third. Then it wants to drop to second again when it starts loosing speed.
4.30s or even 4.56s would make third a much better pulling gear.
I have run 75 towing 10,000 lbs into a head wind, and it would hold it ok but the gear searching from third to second and back again was pretty bad.
It feels like it needs a gear inbetween.
The Torqueshift is a much better towing tranny.
Yes, with the 6 speed.
I was talking about 4r100 V10 vs 4R100 7.3.
Old Nov 22, 2010 | 04:44 PM
  #9382
REXHOUND's Avatar
REXHOUND
The 2v 5.4 is better then the moose sounding v10 and is way better then the powerslowpoke...including the new 6.7
Old Nov 22, 2010 | 06:16 PM
  #9383
phillips91's Avatar
phillips91
Originally Posted by 2001400ex
Not necessarily, when you factor in fuel mileage. Getting 18 or 19 unloaded compared to 13 or 14 more than makes up for the difference. When talking ongoing costs, need to factor all that in.
Back when diesel was 2.65 and gas was 2.55 here I was one of the people vehemently defending the psd when it came to fuel costs. Here lately gas has been 2.63 and diesel 3.05 here, so my psd hasn't seen the road in 3 months.
Brother you are wasting your time. It'll never sink in. They don't realize the role tq has in work.
Having a lot of low end torque just means you can do the same work in a higher gear and at a lower rpm. My 7.3 has a lot more tq than my 5.4, but my 5.4 will run off and leave it loaded or unloaded. It just isn't in the same gear or at the same rpm. Tq is important when pulling a load, but it's tq in the form of tractive force and not engine tq. Im still more than willing to get together and do some pulling any time you are up this way. Any other stock engines are more than welcome to come along too.
Old Nov 22, 2010 | 06:20 PM
  #9384
ChargersFanInCO
I have run 75 towing 10,000 lbs into a head wind, and it would hold it ok but the gear searching from third to second and back again was pretty bad. It feels like it needs a gear inbetween.
75? In second gear? 75 what, kilometers KPH?
Old Nov 22, 2010 | 06:31 PM
  #9385
phillips91's Avatar
phillips91
I can be in 3rd(same gear ratio as his 2nd) and at 60 mph mine is turning 4,500 rpm. If I run it to 5,500 rpm I can get about 68 mph out of it. I have a 4.10 and Bill has a 3.73 in his, so I see no reason why he can't do 75 mph in 2nd gear.
Old Nov 22, 2010 | 06:38 PM
  #9386
ChargersFanInCO
With all the horsies ya'll got, you shouldn't have to be in 2nd gear screaming along at 75mph....or, .75mpg.... the more laughter ya'll give me, the happier I am I bought a diesel...lol
How ya' been? You've been SLACKING as of late in your moderator input...at least on this thread....
Old Nov 22, 2010 | 06:56 PM
  #9387
phillips91's Avatar
phillips91
We don't HAVE to run at those rpms, we are just saying our engines are capable of doing it. It's very rare that mine ever hits 4,000 rpm.
I have been slacking a bit the past week. I had an unfortunate event happen at home that required me to spend some time in the emergency room, so I haven't been online much. I go back to the dr tomorrow to see if I am going to need surgery. If I do, you all may be hearing quite a bit from me as I am confined to the couch for about a week straight lol.
Old Nov 22, 2010 | 07:01 PM
  #9388
ChargersFanInCO
Bill said he had to be in that gear...
Sorry to hear your wife whupped your butt and put you in the emergency room. (kidding) Hope all turns out good
Old Nov 22, 2010 | 07:03 PM
  #9389
phillips91's Avatar
phillips91
Bill runs 95 mph, uphill and wide open the entire way though lol.
Thanks. As of now it looks like everything is going to be ok. Just have to see if they will drop the charges against my wife
Old Nov 22, 2010 | 08:06 PM
  #9390
bill11012's Avatar
bill11012
At 75, I'm over peak HP in second and under peak torque in third.
Its the trans and rear gears, not the engine.
It still pulled it fine, just hunted for gears more than I like it to.
I was driving into a head wind and I got 7.7 MPGs that trip grossing 18,000 lbs.
