Sponsored by: Real Truck
Gas vs PSD
Old Jun 25, 2010 | 04:17 PM
  #5611
bill11012's Avatar
bill11012
Modular motor junkie
I would be there for the next test if it was not a 1,500 mile drive one way.
Old Jun 25, 2010 | 04:18 PM
  #5612
bill11012's Avatar
bill11012
Originally Posted by kx450frider617
And ive seen a 7.3 almost last 800k when a gasser will last 200k when taken care of.
There is one 5.4 that has close to 1,300,000 on it now.
Old Jun 25, 2010 | 04:24 PM
  #5613
kx450frider617's Avatar
kx450frider617
I want to see it. It's either a grandpa truck that had every recommended service done and meticulously maintained beyond belief or its so thrashed that it burns more oil than you can replace. But damn a 5.4, I know gearing has alot to do with it but I can't see an engine smaller than my 5.7 hemi in a truck that weighs 50% more than my quad cab 1500.
Old Jun 25, 2010 | 04:29 PM
  #5614
Lead Head's Avatar
Lead Head
Originally Posted by Jrfish007
And gas engines are designed to produce heat instead of power? Seriously, every engines is going to be designed to make as much power from the fuel they consume as they reasonably can.
Just FYI: The most efficient diesels on the road (which are not in trucks) only convert about 50% of the energy into power. PSD's are probably closer to 40-45% efficient. The 6.7 might be pushing closer to 47 or 48%, I'm not sure.
The most efficient land engine wishes it could be anywhere near 50% efficient. Most diesels are between 35-40% efficient, more automotive engines are probably around 35, which the biggest stationary diesels are around 40%. Most modern gassers are 25-30%.
The most efficient engine in the world is a gigantic ship engine, also the biggest engine in the world. Over 100,000HP. It uses compression ignition, but does not burn diesel. It burns bunker fuel (No. 6 fuel oil). It is basically one step up from road tar, and requires massive pre-heating before it is even remotely burnable in an ICE.
  #5615
bill11012's Avatar
bill11012
I want to see it.
Home
Not as high as I thought. Just 1,200,000.
Old Jun 25, 2010 | 04:47 PM
  #5616
krewat's Avatar
krewat
FTE Leadership Emeritus
Im saying if you ran an engine at its max TQ/ HP rpm constantly UNTIL i blows up, the one with lower rpm will last longer.
The one with the highest reciprocating weight, versus bearing size/rod size/wrist-pin size/etc/etc, would blow up first.
Old Jun 25, 2010 | 04:51 PM
  #5617
kx450frider617
AKA V10 haha. All the components on diesel engines are beefed up as well so the one with the higher RPM will, i'm sure.
Old Jun 25, 2010 | 04:52 PM
  #5618
Lead Head's Avatar
Lead Head
If a modern gasoline engine doesn't last at least 200,000 miles its a junk engine and not worth the metal it was cast with. Most modern gas engines will easily go 300,000 - 400,000 miles if not more. That 5.4 is a prime example of one too. The guy even went as high as 55,000 miles before an oil change!
Also, you have to keep a diesel well taken care of if you want it to last a long time as well. With their very tight ring/piston/cylinder clearances even the smallest amount of dirt that makes it past the air filter due to a leak (Some PSDs were famous for this) will quickly destroy the turbo and eat the cylinders. Same with oil, Diesels also need quite clean oil to stay happy (especially Power Strokes with their HEUI injection)
Do you even know what reciprocating means? Its back and forth motion. What goes back and fourth in an engine? The piston and rods. What engines usually have significantly heavier pistons and rods? Diesels. Heavier components feel the effects of high RPM much more then lighter components.
Lets take two engines, A 220HP stock 460, and the new 400HP 5.0 Mustang DOHC engine. The new Mustang engine has light weight components, yet can take 400HP and spin upto 7000 RPM. The 460 on the other hand has very heavy components, but realistically would not handle much more then 400-500HP on stock internals. Even if you kept that 460 at stock HP, trying to make it turn 7000 RPM on the stock internals would be disastrous. Their massive weight would rip themselves apart as they change direction going down the cylinders.
You riding a KX450F should know that, your bike like my CRF450 have very high revving engine (around 10,000 RPM redline), put out 50HP+ but still have very light weight internal components to handle those massive RPM
Old Jun 25, 2010 | 04:54 PM
  #5619
mountaineer27's Avatar
mountaineer27
one grain of sand will blow up a gasser just as fast
Old Jun 25, 2010 | 04:56 PM
  #5620
phillips91's Avatar
phillips91
Originally Posted by Crazy001
Hrmm...so lots of people think Andrew's 7.3L wasn't working right that day.
I hadn't thought about this before, but the whole time I was saying the problem with the 7.3 was that it was in 3rd gear at 1,500/1,600 rpms and wouldn't downshift to 2nd. Maybe the tranny was shifting fine, but the gear spacing was such that it didn't downshift because it was going too fast to be in the next lower gear......
Old Jun 25, 2010 | 05:02 PM
  #5621
Rush117's Avatar
Rush117
Home
Call me a crazy, but I don't believe that guy. I know what he claims but I'm skeptical. I think there'd be many more like him if it were anywhere near true.
Old Jun 25, 2010 | 05:03 PM
  #5622
Lead Head's Avatar
Lead Head
Ford even confirmed it was real, and had him tour the factory where his engine was made...
Old Jun 25, 2010 | 05:16 PM
  #5623
phillips91's Avatar
phillips91
One thing people seem to be forgetting in all of these high mileage debates is the length of time the engine is running and how many times it is shut off(cools off then has to heat back up). Then they always quote semi's with a million miles on them(like that has anything to do with our psd). Chances are that semi drove over 800 miles per day, on the interstate, never stopped, etc. Anything will run a million miles under those conditions. It's like a guy that drives 500 miles a day on the interstate comparing clutch wear with someone that is using theirs as a farm truck that pulls out and stops every 10 feet.
Old Jun 25, 2010 | 05:24 PM
  #5624
Rush117's Avatar
Rush117
That's great....still don't believe him. Correct me if I'm wrong but he is a courier, not an over the road guy.
Old Jun 25, 2010 | 05:29 PM
  #5625
Lead Head's Avatar
Lead Head
Like phillips91 said above, highway miles are very easy on engines. That guy with the million mile van is an expediter. Basically stuff that needs to get somewhere quick, even if it is a thousand miles away. Check out the company the guy works for: http://www.bolt-express.com/expedite/#gpm1_4
There is even a Volvo with 2.6 million miles on it. The guy drives about 80,000 miles a year in it. Mostly all pleasure driving on the highway.
